Old 10-07-2007, 12:04 AM   #1
JustA4
Member#: 58210
2004 35r STi
186mph - standing mile!
News EngineLogics Built Motor + GT35r
Here's my graphs of a conservative tune done on a Motor/Tune by EngineLogics. The car pulls VERY hard. Was able to run 179.8 mph in a standing mile competition this weekend w/a stiff headwind (believe it's capable of 185). For reference, the C6 Z06s were in the high 160s in the same standing mile. The exhaust pulse can be felt over 6' from the rear of the car, it's amazing.
Here's my putz around town graph: Pump w/Alky 25psi
And here's for when I'm in a hurry: C16 w/Alky 27psi
Engine Parts List
Short Block:
EngineLogics Chrome Molly Flanged 3 step Iron Ductile Sleeves
99 mm Forged CP Pistons with 8.8:1 compression ratio
Pauter Connecting Rods
ACL Racing Bearings
10000 RPM Balanced Crank
Arp Block Stud Kit
EngineLogics Pinned 2.5 Block
EngineLogics High Volume Oil Pump
Cylinder Heads:
EngineLogics Prepped 37 mm NicleVac Intake valves
EngineLogics Prepped 33 mm Inconel Exhaust valves
EngineLogics Profiled Intake and Exhaust cams
EngineLogics Titanium retainers and 68 lb Valve Spring Kit
EngineLogics Custom Made Adjustable Cam Gears
EngineLogics Port Job (Intake Flows 305 CFM Exhaust flows 235 CFM Airspeed in intake average is 345 FT/sec)
Gates Racing Timing Belt
Commetic Head Gasket
ARP Head Stud Kit
AVCS Removed
Intake Tract:
Tumblers Removed
Port Matched Tumblers to head
Port Matched Intake Manifold to Tumblers
Reshaped Intake Manifold Entry
Exhaust Tract
Perrin Equal Length Header
3" APS Single Tip Exhaust
Polydyn Ceramic Coatings
Tial 44mm Wastegate
Turbo:
EngineLogics Spec'd GT3584
Perrin Rotated Mount kit
Tial 44mm Bov
Perrin "Signature Edition" FMIC
DTEC Boost Controller
Fuel:
1635 cc Bosch
EngineLogics High Flow Fuel Rail Set with port contoured fittings
Walbro 255 Fuel Pump
Aeromotive Rising Rate Adjustable Fuel Pressure Regulator set at 43.5 base pressure
SMC single nozzle Alky Injection kit with # 10 nozzle
Engine Management:
Hydra Nemesis W/ Brad's (Silvialost) Custom Tuning
Have a few pics I took of some of the custom work Chris did during the build:
Adjustable Cam Gears:
Pinned the block:
TopFeed Fuel Rails:
Ported Tumblers:
JustA4 is offline   Reply With Quote
Old 10-07-2007, 01:31 AM   #2
Remnex
Member#: 83790
Are the cams off or not dialed in? I would think with all that motor work you would carry torque and HP till redline no problem. I have an 07 and I hold HP and torque way longer on a 35r.
Any ideas, or am I off base?
Remnex is offline   Reply With Quote
Old 10-07-2007, 09:44 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
cams, intake, manifold or head work could be the cause from what I see on the list...
personally I think its cams or just their adjustment...
Old 10-07-2007, 09:57 AM   #4
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
awesome set up!! throw on another fuel pump and turn the boost up to 35 with c16 and see what happens...congrats on a great set up!
blowbyu24 is offline   Reply With Quote
Old 10-07-2007, 11:25 AM   #5
BuggeyEYED
Member#: 101691
97 Supra TT
SOLD - 35r bug/hawkeye
crazy setup but......only 483 on 25lbs? isnt that kinda low?
BuggeyEYED is offline   Reply With Quote
Old 10-07-2007, 11:30 AM   #6
H-Town Wrx
Member#: 71520
1996 Nissan 240sx SE
Uh yeah it's Blue.
Stock STI's dyno at about 210-220 on this dyno. For reference.
H-Town Wrx is offline   Reply With Quote
Old 10-07-2007, 11:40 AM   #7
Badazzcr
Member#: 67693
4 Making them
faster then anyone else.
somethings not right, shouldn't fall of that hard up top.
Badazzcr is offline   Reply With Quote
Old 10-07-2007, 12:10 PM   #8
smokey07
Member#: 151683
^^ what he said...... annnnd im quite sure it aint runnin away from a c6Z at any point over 100...
badass car tho no doubt
smokey07 is offline   Reply With Quote
Old 10-07-2007, 01:27 PM   #9
WRXCJS
Member#: 142059
2010 STi
Those are some nicely ported TGV's, Good work.
WRXCJS is offline   Reply With Quote
Old 10-07-2007, 01:41 PM   #10
JustA4
Member#: 58210
2004 35r STi
I wouldn't be soo sure, I might agree with you more in the 140+ range. The numbers will be posted along side the car make/model in a few weeks. Only speeds given are those at the end of the Mile. No breakdown to tell where I must be blowing the doors off the C6 Z enough to still beat them by over 10mph at the end of the mile. Don't underestimate our Lil Subbies. I wasn't "launching" the car off the line. C6Z's are suweeet, just posted their averages for reference to speeds being attained yesterday.
The car is going back on the dyno for some cam adjustment. Texas Mile came up quickly and we weren't able to do all the adjustment/tuning we'd like. Car is conservative, but VERY powerful.
Old 10-07-2007, 01:51 PM   #11
battousai
Member#: 44977
2015 Mustang GT
Nice to see this car back in action
battousai is offline   Reply With Quote
Old 10-07-2007, 02:03 PM   #12
JustA4
Member#: 58210
2004 35r STi
Here's the graph of just C16 & 27pds boost:
All HP figures are supported with mathematical calculation.
Example:
516.6 WHP C16 Dyno Pull on Oct. 1, 2007
Temp. during final pull: 89 degrees
Barometric Pressure: 30.22
Humidity: 59%
To calculate the HP support at 68% duty cycle with 1635 cc Injectors, use the following calculation:
1.)Divide the injector size in cc by 10.50 to get injector size in lb. 1635 / 10.5 = 155.78 lb
2.)Multiply the injector size in lb with the injector duty cycle 155.78 * 0.68 = 105.93
3.)Divide the result with the B.S.F.C (Brake Specific Fuel Consumption) 105.93/.6 = 176.55 flywheel hp per injector
With an estimate of 27% drivetrain loss, the WHP can now be calculated:
1.)Multiply the flywheel Hp with 0.73 (27%) 176.55 * 0.73 = 128.88 wheel HP per Injector
Therefore 4 injectors at a 68% duty cycle will be able to produce 128.88 * 4 = 515.52 wheel HP (+/- 3% is OK)
NOTE: BSFC = NA engines use 0.5 and S/C or Turbo engines, use 0.6.(Turbo engines run lower AFRís than NA engines, therefore; a higher B.S.F.C. is required.
Why was a 27% drive train loss used?
A stock 2004 STI is advertised to have 300 HP flywheel.
The average WHP produced on a DynoDynamic dyno for 40+ bone stock STIís was 220 wheel HP.
220 divide by 300 = .73 which indicates 27%
Using this math calculation, you can tell when somebody cannot be make the power they're claiming. Would like to see people list duty cycle and fuel pressure used in their setups more often.
Old 10-07-2007, 02:32 PM   #13
smokey07
Member#: 151683
does all that mean it wants more boost??? and why does it fallllll sooo hard past 7k???
Old 10-07-2007, 07:55 PM   #14
cpturbo
Member#: 49175
2004 STI
There must be some significant differences between the GT3582 with a .82 housing and this turbo (listed as a GT3584). What compressor wheel do you have and what exhaust housing A/R do you have?
Also, I highly recommend that you re-think your fuel pump set-up!!
Wow, nice car.
cpturbo is offline   Reply With Quote
Old 10-07-2007, 10:28 PM   #15
modaddict
Member#: 95840
sold to a good bud
awaiting next car
4th gear dyno run?
what was the CF on the dyno?
modaddict is offline   Reply With Quote
Old 10-08-2007, 02:39 PM   #16
JustA4
Member#: 58210
2004 35r STi
Originally Posted by modaddict View Post
4th gear dyno run?
4th gear pulls & The CF (Correction Factor) for the dyno run was zero. The atmospheric correction factor was 1.043
Old 10-08-2007, 03:02 PM   #17
Big_Hitter
Member#: 10831
2011 Ferd Ranger 4x4
2009 FXT VF52/E85
Paul, what are the equations with alky?
Big_Hitter is offline   Reply With Quote
Old 10-08-2007, 06:46 PM   #18
young j
Member#: 144478
2005 sti
wr blue
impressive! i didnt know the guys at "EL" build custom engines.
does anyone know if they can work on rotaries?
i called and the guy with the accent said yes but im still scheptical.
a bad tune will fry apex seals preety quick.
young j is offline   Reply With Quote
Old 10-08-2007, 06:52 PM   #19
Big_Hitter
Member#: 10831
2009 FXT VF52/E85
^^ the guy with the "accent" , aka Chris, knows his isht
they stand by their work 100%
Old 10-08-2007, 10:04 PM   #20
WRX4eva
Member#: 103343
2004 2.5 Hybrid 6spd
Rotated Manifold/35R
I honestly can't imagine what it would feel like driving that beast. Grats on those numbers.
WRX4eva is offline   Reply With Quote
Old 10-08-2007, 11:25 PM   #21
Remnex
Member#: 83790
Something just isn't right. I can hit those numbers with no motor work other than a balance and forged pistons. The car falls on it's face after 6k. Why is that?
Old 10-09-2007, 01:31 AM   #22
texas05sti
Member#: 126242
2005 STi/2012 GTR
TXIC's most loved
I was also at the Mile this weekend....the stock C6 ZO6 that was pitting with us ran a max of 168. Paul's car is nuts.
texas05sti is offline   Reply With Quote
Old 10-09-2007, 01:44 AM   #23
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Great results at the mile. However. Something is not right up top. I think some time adjusting the cams will help. Maybe the tune. But its falling super hard up top. Lots of lag, a big hit and then it falls down hard. I think some more time spent with tuning could net some serious power below and above the curve.
Cya
Clark
AZScoobie is offline   Reply With Quote
Old 10-09-2007, 10:53 AM   #24
JustA4
Member#: 58210
2004 35r STi
Cya
Clark
Thanks. We're going to play with the Cams now that we have some more time to use the dyno.
Old 10-09-2007, 09:38 PM   #25
EngineLogics
Member#: 98944
04 STi
First I would like to thank JUSTA4 for trusting us to do the engine built for him. It can not be easy to give your pride and joy to someone that does not follow main stream in their engine builds.
Secondly we would like to thank the Subaru community for the great response and positive comments towards this post.
We kept in mind that our customer does not have an unlimited budged so when time came to experiment we did so with caution, approval and full customer understanding of what might happen if things go wrong. We would rather caution on the side of safe than blowing things up at someone elseís expense.
Many things on this engine setup are not standard or average, especially the cam setup. With absolute minimum time to our availability we chose to caution on the safe and moderate side. We wanted to see how the engine reacts under actual race conditions and are very pleased with the result. Peak power at 8000 rpm is not always desirable; it is therefore the objective to have various setups for various events.
In the not too distant future we will be moving to a more aggressive cam timing setup and we believe that the engine will respond well. Although we would like to see the car go a lot faster we do not live in a dream world and know that the aerodynamics effects is catching up rapidly.
Cost is always the determining factor of how hard and fast you want to play
EngineLogics is offline   Reply With Quote
2004 WRX STI for sale built motor gt35r turbo tech145 Private Vehicle 'For Sale' Classifieds 18 03-05-2010 04:24 PM
02 WRX - Built Motor -GT35R - Pump Gas - 441WHP/375 WTQ Benchmark Tuning Proven Power Bragging 35 05-08-2009 06:21 PM
suggestions on tune on built motor with gt35r scutzi128 UTEC 4 03-10-2008 11:14 PM
Legacy GT35R with Built Motor (pics included / dial-up beware) CT_STi Proven Power Bragging 60 05-07-2006 08:28 PM
GT35r/DPR stage 4 AVCS cams/Built motor..91 Octane MARKGSTI Proven Power Bragging 84 11-15-2005 07:35 PM
