Old 10-07-2007, 03:35 PM   #1
altima04
Member#: 104134
2006 STI
Default 06 sti just got back from drag strip, Results:
Well to tell u the truth i went very very excited to the track and came back extremely dissapointed, so much so that i am bout to just stop modding and not even mess wit it anymore.Temp was bout 90 ish degrees, lots of humidity. Mods are FMIC, BOV, CAI, Turbo inlet, fuel pump, TBE, cobb AP tuned at 335 AWHP and 328 Lbs. Tq. My best run which was a while back was only on a TBE untuned, i ran 13.3.
1st run:
R/t: .076
60: 1.859
330: 5.612
1/8: 8.687
MPH: 80.30
1000: 11.294
1/4: 13.506
MPH: 102.87
2nd Run: Mis shifted on fifth
.117
2.075
5.987
9.139
78.18
11.795
14.047
100.54
3rd Run:
-.011
1.868
5.707
8.803
79.28
11.430
13.747
96.92
4th Run: (Grinded second gear)
-.274
1.983
6.314
9.561
76.51
12.257
14.555
98.38
5th run: (Second gear would not go in again!!! rrggg)
.152
1.999
6.321
9.648
74.89
12.370
14.649
99.55
6th run: (Unbolted exhaust at downpipe)
.123
1.881
5.760
8.876
78.96
11.492
13.712
101.90
I spend tons of time and money tryin to get everything right and i did not even beat my best time. Can anyone see where i went wrong on these runs? I let the car cool for bout 20 min per run, actuallly there were two runs where i let cool down for an hour and i put a bag of ice on manifold. I launched at bout 5500 RPM and i DID NOT release PSI from my tires, i dont think that makes much of a difference. My friend wit a N/A rsx has a TSX motor and ended up running 12.6!!!!!! He had slicks, and his 60 ft was like 1.8, and his trap speed was 108! I dont understand what im doing wrong, any HELPFUL advice would be truly appreciated!
altima04 is offline   Reply With Quote
Old 10-07-2007, 04:30 PM   #2
BBaller018
Member#: 100465
08' legacy
quartz silver
Alot of people are probably going to tell you to lose the BOV, but i doubt that's going to have that much affect on your Times or Mph. The only thing I could think of would be to adjust your shifting points. Head to the track again when it cools down and it isn't so humid. You'll probably get some better times
BBaller018 is offline   Reply With Quote
Old 10-07-2007, 04:35 PM   #3
Jhovany
Member#: 137317
2006 STI
Rally Blue
Well first of all man (not to be mean but)....dont start comparing your runs and car to a totally different car!!! It could have been a number of things unfortunetly.....it could have been the weather (the temp and humidity), the way the track was prepped! Check all your piping especially since you have a FMIC. Im not too sure about this but......I have heard that a FMIC on stock turbo is worthless and also your BOV there.
Jhovany is offline   Reply With Quote
Old 10-07-2007, 04:36 PM   #4
Paul
Member#: 56203
00 RSTI Coupe
Twin Scroll 2.5XTR EJ207
Have you raced your buddys rsx on the street? If hes alot faster then you there is def something wrong with the car....tune, boost leak, compression, ect
Old 10-07-2007, 04:40 PM   #5
Jhovany
Member#: 137317
2006 STI
Rally Blue
^^^And they say NASIOC is against STREET RACING!!!!!
Old 10-07-2007, 04:44 PM   #6
DigitalPunk
Member#: 124236
2006 WRX Built EJ257
Version 8 Twinscroll
is your bov recirculating?
DigitalPunk is offline   Reply With Quote
Old 10-07-2007, 04:47 PM   #7
Paul
Member#: 56203
00 RSTI Coupe
they are
Old 10-07-2007, 04:48 PM   #8
the1&only
Member#: 147829
what was the weather like when you ran your 13.2 with just tbe???
the1&only is offline   Reply With Quote
Old 10-07-2007, 04:58 PM   #9
hybooststi
Member#: 83843
STI/EVO
Let me drive it like i stole it Enrique!!! pm you some helpful info.
k.c.
hybooststi is offline   Reply With Quote
Old 10-07-2007, 05:04 PM   #10
hybooststi
Member#: 83843
STI/EVO
true. but i think i have an idea
Old 10-07-2007, 05:15 PM   #11
altima04
Member#: 104134
2006 STI
i was tuned WITH the fmic, and i have the aps bov which my tuner said was good. Me and him have always been at it, he is my biggest rival, and thats why i wanted to break into the 12's but i dont really think the temp had much to do with it cuz my friend ran 20's until he started popping those 12's!
Old 10-07-2007, 05:26 PM   #12
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Your 60ft time sucks. You should be able to hit 1.6-1.7 pretty easily. What are your DCCD settings/launch habits?
cucamelsmd15 is offline   Reply With Quote
Old 10-07-2007, 05:34 PM   #13
altima04
Member#: 104134
2006 STI
DCCD is on AUTO and launching bout 5500
Old 10-07-2007, 05:43 PM   #14
TurboDXsti
Member#: 106671
2006 Sti
grey
nest time set your DCCD all to the rear , i got some consistent 1.6 60" 's like that
TurboDXsti is offline   Reply With Quote
Old 10-07-2007, 05:50 PM   #15
ExpO
Member#: 115819
2006 vf39 R0mRa1DeR
Darknessess Wagon
Something is wrong... those look like stage 2 2.5l wrx slips. And trap speed fluctuating by 7 mph?? wtf.
Check for boost leaks and log it.
It also looks like you really need to work on your driving if you want good numbers.
+1 on the fmic/bov being worthless on a vf39.
ExpO is offline   Reply With Quote
Old 10-07-2007, 05:58 PM   #16
cucamelsmd15
Member#: 122980
Zing!
Old 10-07-2007, 06:22 PM   #17
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
Originally Posted by cucamelsmd15 View Post
Zing!
...I cut 1.63's on auto, and with full rear I usually lose 2mph.
wrxwhat is offline   Reply With Quote
Old 10-07-2007, 06:25 PM   #18
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
somethings up... those traps are REALLY low
Equilibrium Tuning is offline   Reply With Quote
Old 10-07-2007, 06:41 PM   #19
albie1kanobi
Member#: 101607
06 Subaru STi
hey altima04 im in the same boat as you. my mods are similar except i have TBE, headers, bigger tmic, meth (50/50), fuel pump, +1 plugs and a protune but yet i can only hit 101 traps, with a best of 13.1, and all were 1.7 60ft.
but when i was on OTS map with just a TBE i was hitting 104 traps.
i think my tune is F***** up.
albie1kanobi is offline   Reply With Quote
Old 10-07-2007, 06:45 PM   #20
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
LOL, god damn guys, what's wrong???
Old 10-07-2007, 06:50 PM   #21
altima04
Member#: 104134
2006 STI
i really have no idea. I dont have the street tuner software i was tuned at agile and it seemed to go well. I dont know whats wrong i think it could be my driving. But when im on the street i beat a lot of cars that will prob beat me on the track i dont know what it could be.
Old 10-07-2007, 09:39 PM   #22
scoobienoobienoo
Member#: 110247
You just can't drive. That is exactly what is wrong. You missed shifts on 3 out of 6 runs and not a single 60' less than high 1.8x's.
Practice. If I had to guess, you are pussing out on the line and letting the revs down before you let your clutch out....Either that or you are letting the clutch out before you rev it up all the way. Watch some video, I bet you any amount of money your front end comes back down off the line from bogging the motor.
scoobienoobienoo is offline   Reply With Quote
Old 10-08-2007, 08:41 AM   #23
sluflyer06
Member#: 111641
2014 BRZ Ltd - DGM
E30 318is
you just need practice IMO, its all in the launch.
sluflyer06 is offline   Reply With Quote
Old 10-08-2007, 10:10 AM   #24
turbobaby
Member#: 102564
05 STi
BLUE
definitely check for boost leaks, try dynoing again. Your car is not making full power. That trap is too low for the power you are supposedly making.
turbobaby is offline   Reply With Quote
Old 10-08-2007, 12:29 PM   #25
thunder_sti
Member#: 68315
04 Stock internals
520awhp-C16 425awhp-93o
Your Mods looks very familiar. Since I have a friend w/ same et. issues.
1st get rid'of:
FMIC, BOV, CAI - Once you do should be in the 12.8 range.
thunder_sti is offline   Reply With Quote
06 WRX VF43 swap just got back from Agile HSBabyFace Proven Power Bragging 38 04-07-2009 12:20 AM
Just got back from the drag strip! 04fpgreensti Mid Atlantic Impreza Club -- MAIC 7 04-03-2008 10:07 AM
Just got back from Scooby dealer 06 sti has new manifold check out pic hauvis News & Rumors 74 08-18-2005 04:49 PM
I just got back from my first time at a strip club, ever. JGard Off-Topic 32 02-07-2004 01:45 PM
just got back.. Illegal Drags!! BeAn North West Impreza Club Forum -- NWIC 17 10-27-2000 08:37 AM
