Old 01-16-2002, 03:34 PM   #1
WRxednEffect
Member#: 13105
Default which o2 sensor to use with upipe and autometer a/f guage
should i just get a standard boshe one? im not sure? Or does autometer make one?
WRxednEffect is offline   Reply With Quote
Old 01-16-2002, 05:19 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
Any 1V switching oxygen sensor should work. Since the Autometer gauge doesn't have any provision for driving a sensor heater, you can get by with a single wire oxygen sensor. I think this is an example: http://www.napaonline.com/cgi-bin/nc...rfnbr=15599361.
Jon [in CT] is offline   Reply With Quote
Old 01-16-2002, 05:30 PM   #3
WRxednEffect
Member#: 13105
I ordered teh autometer one, 2244
Old 01-16-2002, 05:45 PM   #4
bobgrice
Member#: 10627
2002 WRX Sedan
Platinum Silver Metallic
I, too, purchased the AutoMeter O2. I agree with Jon that any 1V O2 sensor should work.
I don't have it handy (I'm traveling this week) and I haven't installed it yet, but I thought the AutoMeter sensor does have a heating element. It has, I believe, four wires, which would tell me that it does probably have a heater.
I think the AM unit costs more than the single wire (actually, I'm sure of it). But, if you don't get a heated unit, it will take longer to get accurate results from the sensor.
Not that it will be terribly accurate to start with, since it's a narrow band sensor. It is inexpensive and, at least in my opinion, not a bad thing to have along with an EGT gauge to compare and contrast the two. These gauges are the best way to see iff you're headed towards running lean. Note I said headed towards. Once you get there, a lot of times, it's too late.
bobgrice is offline   Reply With Quote
Which valve stems to use with Gold Advan RS? GeneralTsou Tire & Wheel 5 05-28-2010 11:57 AM
Best knock sensor to use with Turbo XS Knocklite Grant Hendricks Other Engine Management 1 08-28-2009 04:09 AM
Which Stainless Lines to use with 05+ LGT brakes on wrx lazybummm Brakes, Steering & Suspension 0 11-10-2007 08:04 PM
Knocklite question, what sensor to use with it? Cyclops Engine Management & Tuning 6 08-08-2007 03:04 PM
Which o2 sensor to tap? markeddy Electrical & Lighting 7 03-28-2007 04:46 PM
