Old 10-07-2007, 07:59 PM   #1
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
Default what size pistons for a sleeved 2.5 ltr
Hey guys,
im looking at getting some pistons for my build.. Then engine will be flange top sleeved..
What size pistons would u guys recomend?? 100mm or 102mm the pistons will be CP with swain tech coating from ron at axis..
And the benefits and drawbacks of either size??
Thanks in advance
tino is offline   Reply With Quote
Old 10-07-2007, 09:35 PM   #2
twigg107
Member#: 119718
2008 STI
Depends.... whats the final bore? Its best too ask who's doing the engine work what too get.
twigg107 is offline   Reply With Quote
Old 10-07-2007, 09:41 PM   #3
tino
Top Scoob 019
Member#: 43630
The final bore will be suited to wot ever pistons i choose, as i will be sleeving the block. Thus there wont be an issue with the standard liners in terms of thickness.
But will a 102mm piston provide alot more compared to a 100 mm piston..
Old 10-07-2007, 10:01 PM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
I did 99.5mm in my first sleeved block and 100mm in my new sleeved block. The plan on going a little smaller than what is available on the market is to ensure I could have the block re-honed in the event of a failure. Well guess what.............. yep the block with the 99.5mm's died so i'm having it re-honed for 100mm's
As for power.... can't say.
mick_the_ginge is offline   Reply With Quote
Old 10-08-2007, 08:09 AM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
do the 99.5's..
just like mick..incase something happens
you can upsize to the 100's
and if somethings again you can
upsize to 102's..
Old 10-08-2007, 09:58 AM   #6
tino
Top Scoob 019
Member#: 43630
Originally Posted by jaxscuby View Post
do the 99.5's..
upsize to 102's..
But my block will be sleeved, so it shall be alot stronger compared to the standard liners..
plus i dont want to be rebuilding this engine every so often, i want it to last...
i think the 100s would be the go thus far..
Old 10-08-2007, 10:45 AM   #7
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Who said anything about the pistons or the sleeves breaking?
Read this -> http://forums.nasioc.com/forums/show....php?t=1244905
100's will be fine as that will still give you room to re-build. A built block does not mean indestructable so you should be planning a re-build at some point
Old 10-08-2007, 11:33 AM   #8
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
you can also do 101.6 and 102
Old 10-08-2007, 06:09 PM   #9
shvrdavid
Member#: 86078
2005 Sti
4094R Twin Scroll
I would start out with the smallest piston that the sleeve can do, that way you have more sleeve to bore in the future...
shvrdavid is offline   Reply With Quote
Old 10-08-2007, 06:12 PM   #10
STEALTH-WRX
Member#: 7822
Multi layer snot green
I would start with a 99.5mm as you can use an off the shelf piston from whomever makes them. Then if you ever hurt it you can go to the next off the shelf one that is 100mm. This way you dont have to spend 20%+ more on a custom piston.
STEALTH-WRX is offline   Reply With Quote
Old 10-08-2007, 08:41 PM   #11
tino
Top Scoob 019
Member#: 43630
Thanks for the imput guys, under rons suggestion ill stick with the 100mm..
Old 10-08-2007, 08:48 PM   #12
tino
Top Scoob 019
Member#: 43630
Geez looked like a rod bearing failure there, sorry to hear.. What size bolts did u use??
Old 10-09-2007, 12:22 AM   #13
bboy
Member#: 56468
04 Improved STI
Dirty White
Gasket is 101.6 mm, not sure if you'd need to trim or not, if you were to go above that.
Old 10-10-2007, 06:42 AM   #14
TJL Performance
Vendor
Member#: 134406
2004 STI
2.6L GT35R in works...
We do 102mm sleeved blocks with great success. No issues with 600+WHP
set up's.
TJL Performance is offline   Reply With Quote
Old 10-10-2007, 11:43 AM   #15
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
set up's.
Great, but what if something does happen? then what, he goes to 103's (which I know are available) leaving the sleeves thin?
My argument has *nothing* to do with will they work, it's all about planning. I'm pointing out that just having a built block does not mean it's indestructable so planning for a rebuild from the start is good insurance and makes good sense.
How much real HP difference are you going to see on 100's vs 102's? From my experience it's about the same as what you can get from running a different hotside on the turbo or different cams.
TJL how many of these setups have you done? Lets try and quantify what the resulting car has been used for, street, drag, track because this makes a difference.
Old 10-10-2007, 12:14 PM   #16
Member#: 106514
Mick also remember you can remove sleeves and install new. I have never had to do this, but it can be done if need be, at least on the blocks I provide.
- J.
Jeremy@Cobb is offline   Reply With Quote
Old 10-10-2007, 12:17 PM   #17
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Hi Jeremy, correct but if tino is like me and other owners we don't have $$$ laying around and the sleeving machine cost is one of the bigger bills.
OK, enough said from me. Cheers
Old 10-10-2007, 12:25 PM   #18
Member#: 106514
Im just trying to offer some insight and possible solutions.
I have never had to do this process, but I look at it this way.
Of all the parts that go into a sleeved block replacing a sleeve or two or all would be alot cheaper than starting over with a new block.
Remember this should be after a couple rebuilds in which you can remachine the sleeves.
- J.
Old 10-10-2007, 01:24 PM   #19
TJL Performance
Vendor
Member#: 134406
2004 STI
This is what we offer for big turbo applications. Helps spool up and adds
little torque to bottom end. If something happens, we can offer for example 102.1mm to fix the problem....
Personally I wouldn't go much bigger than 102.5mm
We can custom order headgaskets up to 103mm, no problem.
fs v2 ap for 2.5 ltr 395 blackrod punishment SCIC Private Classifieds 3 07-10-2009 01:57 AM
('93-'01) What to look for in a 2.5 RS teamzzyzx Impreza Forum 11 11-21-2003 09:51 AM
What size rear spkrs on '02 2.5? blackbok Car Audio, Video & Security 2 11-19-2001 02:14 AM
('93-'01) got about $300 what to get for a 99 2.5 PEARLBLK99RS Impreza Forum 15 10-17-2001 03:16 AM
dropping in a 2.2 or a 2.5 ltr into an older impreza with a 1.8 BeAn Normally Aspirated Powertrain 2 03-22-2001 12:18 AM
