Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 10-07-2007, 09:21 PM   #1
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
Default do i or do i not??
PROBLEM SOLVED!!! 04 wrx, header, up, dp, exhaust, intake, perrin hoses.
if i am getting tuned for all of this, do i need a 255? i would like some opinions please, the tuner says get it, i know i am going to eventually need it down the line, but the question is
DO I ACTALLY NEED IT FOR THESE MODS?
shootinsoobie is offline   Reply With Quote
Old 10-07-2007, 09:29 PM   #2
THEVERGE
Member#: 127421
2002 Subaru WRX
I would say no. Your not really adding anything that would warrant a pump upgrade.
It couldn't hurt for any future mods you have planned, though.
THEVERGE is offline   Reply With Quote
Old 10-07-2007, 09:33 PM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Not needed. Not yet.
/Brox
Broxma is offline   Reply With Quote
Old 10-07-2007, 09:50 PM   #4
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
thx fellers. it eases my mind to know this
Old 10-08-2007, 02:04 AM   #5
Casey
Member#: 82371
2002 IMPREZA
22 psi @ 2600rpm
If the tuner says get it, then get it.
Casey is offline   Reply With Quote
Old 10-08-2007, 03:20 AM   #6
dynamix
Member#: 122603
is it worth the expense of a potential blown engine for the small cost of a 255 pump? I cant believe that you would not want to follow the advise of the tuner.
dynamix is offline   Reply With Quote
Old 10-08-2007, 08:59 AM   #7
PrecisionPB
Member#: 131769
2004 Impreza WRX
Black Mica
+1 to not needed, yet. However for the minimal cost, its a nice margin of safety.
PrecisionPB is offline   Reply With Quote
Old 10-08-2007, 10:55 AM   #8
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
problem solved.... im getting an sti pump from a friend till i need something larger...thanks for the help/constructive criticizm
Old 10-08-2007, 11:17 AM   #9
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
sti pump does not flow 255lph..
Old 10-08-2007, 12:07 PM   #10
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
^^ i know this, but it is better than stock wrx pump and will be good until i upgage turbo. thank you for your concern
Old 10-10-2007, 02:33 PM   #11
t4nk
Member#: 129905
2005 WRB WRX
2003 F-350SD, 7.3PSD
uhm beleive it. his mods don't come close to needing a fuel pump upgrade..
i ran 19psi on my stock pump, he's running stage 2 (16-17). he's fine.. especially with the STi pump
t4nk is offline   Reply With Quote
Old 10-10-2007, 03:14 PM   #12
KAX
Member#: 63292
2000 Subaru 2.5RS
2002 WRX powered
pump isnt really necessary until bigger injectors are necessary. no point pumping more fuel to injectors that still flow 440cc
KAX is offline   Reply With Quote
Old 10-10-2007, 03:26 PM   #13
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
The way I look at it, he may not need it, but if he trusts a tuner with his car and the tuner says get it then he should either A) Get the pump or B) get a different tuner since he isn't gonna listen to him anyway.
scraggy is offline   Reply With Quote
Old 10-10-2007, 03:29 PM   #14
t4nk
Member#: 129905
2005 WRB WRX
dude.. what is the point of the pump? there is NOTHING he is listing that is going to come close to exceeding his stock injectors.
and all tuners are not the same, ive met some that say "you need this, you need that" to rake in more money. its rare.. but it happens.
he does not need a bigger pump, period.
Old 10-10-2007, 03:46 PM   #15
scraggy
Member#: 136384
06 WRX
Thats what I mean, not all tuners are the same, just like not all cars are exactly the same. 255's are pretty cheap as it is, and I doubt the tuner is making much money on it anyway.
If a tuner suggests you should get something, and you trust him to tune your car for power, you should at least follow his wishes when it comes to supporting upgrades.
He could always find another tuner that says he doesnt need one. That way, if the motor goes for some unkown reason, his tuner can't say "Welp, shoulda listened and got that fuel pump"
I DO NOT THINK HE NEEDS ONE
Just pointing out an opinion of mine. When I used to tune Honda's for people, and I thought the customer needed something beforehand, I would not tune until he got it, regardless of where he purchased it. Especially if I thought he needed a pump.
Old 10-11-2007, 08:11 PM   #16
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
having extra pump capacity can also help with quickly increasing fuel demands during transient conditions.
Old 10-12-2007, 06:08 AM   #17
dynamix
Member#: 122603
I dont know why you are getting stressed over a very small cost of a fuel pump. You will need it sooner or later - why not put it in now for a bit of piece of mind. At least then you know it will definitely be supplying the extra fuel needed.
Old 10-15-2007, 06:54 PM   #18
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
thank you guys for all youre input, it has actually helped and wanted to say thanks. i understand that i dont actually need one but as far as volume of flow in extreme conditions i think i would rather be safe than sorrry. my friend fell through with the sti pump so i am going with the walbro.
thanks again and if someone that posted b4 this post is reading,
THANK YOU FOR THE HELP!!
Opinion Do this or not to do this Mechkiller31st Interior & Exterior Modification 17 12-24-2004 01:01 PM
Do it, or not? Unsung Boxer Off-Topic 41 10-30-2004 04:49 PM
so do i do her or not? wrxinmn Off-Topic 51 07-13-2004 03:54 AM
Should I do it or not? TBOD Off-Topic 74 07-12-2004 08:19 PM
STi deal. Do it or not? totald Texas Impreza Club Forum -- TXIC 38 04-23-2004 09:33 PM
