Welcome to the North American Subaru Impreza Owners Club Friday July 3, 2015
Old 10-08-2007, 08:41 PM   #1
2002SUBIE
Member#: 154877
2002 WRX,07 LGT
WHITE,BLUE
Unhappy Short Ram Intake Question?
What Brand Of Short Ram Intake Is Good For Keeping The Hot Air Out And Will Clear Front Mount Intercooler Piping?
2002SUBIE is offline   Reply With Quote
Old 10-08-2007, 09:20 PM   #2
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
no short ram in itself is good at keeping hot air out. You'll probably have to either mod a commercially available heatshield, or fab your own.
anickode is offline   Reply With Quote
Old 10-08-2007, 09:25 PM   #3
jack klompus
Member#: 152885
2014 Malibu LTZ
short ram should be renamed hot air intake. Stick with the stock intake system.
jack klompus is offline   Reply With Quote
Old 10-08-2007, 10:45 PM   #4
The Blue Pilot
Member#: 101880
2012 Mustang GT
K&N typhoon intake system comes with a heat shield as an option. Get it and it should block out most of the hot air.
As far as one with clearing the front mount piping...I don't know, however usually the front mounts require their own specific intakes, normally being cold air.
The Blue Pilot is offline   Reply With Quote
Old 10-08-2007, 10:49 PM   #5
S&S_IS
Member#: 152871
trying to figure out how he's planning on using the ' ram air effect' under a speed of 500mph??
S&S_IS is offline   Reply With Quote
Old 10-09-2007, 12:04 AM   #6
KingOfSiam
Member#: 84636
2005 WRX (automatic)
Crystal Gray
You're confusing this with a ramjet. Totally different concepts.
KingOfSiam is offline   Reply With Quote
Old 10-09-2007, 02:12 AM   #7
HinshawWRX
Medium Frank
Member#: 140114
2014 Porsche
GT3 (Currently on Fire)
I'm confused as why people are telling him to keep the stocker if hes asking about a front mount....
Old 10-09-2007, 12:24 PM   #8
romanlynch
Member#: 126684
02 wrx
PLATINUM silver baby
edit : nevermind
romanlynch is offline   Reply With Quote
Old 10-09-2007, 12:52 PM   #9
doridori
Member#: 95733
2002 GGAA - Big 16G
I'd have said ramjet if I meant ramjet.
this 'ram air effect' that people are so wanton to toss around like it's some magic power adder is just typical of how 'rice' and marketing have superceeded the laws of physics.. at 100mph,with the port in the very leading edge of the bumper, in clean air, with no bends in the CAI.. you get in the 10th of a psi range of an increase in pressure.. you'd be further ahead putting in one of those E-bay bilge fans they sell as ' superchargers '
doridori is offline   Reply With Quote
Old 10-12-2007, 10:23 PM   #10
2002SUBIE
Member#: 154877
2002 WRX,07 LGT
WHITE,BLUE
right now the car has an injen intake on it.it sucks alot of hot air but stays away from the fmic piping.what brand of intake are some of you running that clear the fmic piping and decrease hot air intake?
Old 10-12-2007, 11:09 PM   #11
anickode
Member#: 141633
2002 WRX Wagon
Shiny new silver!!!
nothing will decrease hot air intake if it doesn't have a heat shield around it. Best thing to do would be save yourself the $$ and fabricate your own custom heatshield that works around the IC piping.
Old 10-12-2007, 11:25 PM   #12
jamesnobrakes
Member#: 140999
2004 WRX Wagon
No, you have to be flying around 250kts (280mph?) to get any real compression effect, and even then it's not great until you pick up more speed. I'm a pilot and you aren't getting a "ram" effect at all if you aren't traveling at these speeds.
Your stock subie intake simply does a better job of getting colder air, and the commonly labled "short ram" intake "can" allow the engine to breathe better with possibly more airflow, but if it's significantly hotter air then there's no point, and under the hood of a subie there is some seriously hot air.
jamesnobrakes is offline   Reply With Quote
Old 10-13-2007, 09:41 AM   #13
2002SUBIE
Member#: 154877
2002 WRX,07 LGT
WHITE,BLUE
will a spt intake with the heat shield clear fmic piping?
Old 10-13-2007, 12:02 PM   #14
StarDogChampion
Member#: 10276
2001 Impreza RS
2002 WRX, 2012 535i
I was just going to mention that. Some have gotten the SPT to fit with the SSAC fmic, but i dont know if they were able to fit the heat shield as well.
StarDogChampion is offline   Reply With Quote
Old 10-13-2007, 01:52 PM   #15
2002SUBIE
Member#: 154877
2002 WRX,07 LGT
WHITE,BLUE
thanks.maybe i will try that or fabricate a shield
Old 10-13-2007, 02:35 PM   #16
B00st3dWRX
Member#: 140978
02 WRX WRB
i-Nertia Dynamics
doesnt matter if your sucking in hot or cold, its gonna get super heated by the turbo anyways and if you are running an FMIC then that should take care of your cooling concerns. I run a greddy Short ram and works perfect, clears my intercooler piping and have had no problems with MAF readings. If you want added cooling run some intercooler squirters or a N02 set-up.
B00st3dWRX is offline   Reply With Quote
short ram intake question ttatsumi Legacy Forum 11 05-09-2006 10:33 PM
Short ram intake question subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 02-01-2006 08:26 PM
Short ram intake question subeforlife2002 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-19-2006 02:17 AM
short ram intake question dj00crusty Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 06-02-2005 07:53 PM
Short ram intake question gumby1976 Normally Aspirated Powertrain 5 04-01-2003 06:47 AM
