Old 10-08-2007, 10:00 PM   #1
dlusion2000
Member#: 118636
2004 35th SE Sedan
Sea Mist Green
Default help installing amp
'04 Legacy sedan. trying to install audio system and trying to find an easy way to thread the power wire from the engine bay into the trunk. can't find anywhere to bring the wire through the firewall into the passenger cabin. and would like to take the lazy way out and just have someone tell me a good way to get the wires to the amp in the trunk from the passenger cabin(although i think i already know what i am gonna do for that one). any help would be appreciated, thanks
dlusion2000 is offline   Reply With Quote
Old 10-08-2007, 10:57 PM   #2
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Follow he big bundle of cables that goes through the wall and down the side of the car by the door sill. There's usually enough room to squeeze your power wire through the same path...
janikphoto is offline   Reply With Quote
Old 10-09-2007, 05:27 PM   #3
weezor
Member#: 126605
2000 Legacy GT BE
If it's an automatic there should be a rubber plug in the firewall where the clutch would go. Just pull back the carpet under the pedals and you should see it. When I did mine I the first time I ran the cables along the edge of the carpet all the way to the trunk. I didn't like it so I ended up pulling the seats/carpet/everything so that everything is nicely tucked away.
weezor is offline   Reply With Quote
Old 10-09-2007, 05:47 PM   #4
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
yep, theres a hole right in front of the pedals.
fibuz is offline   Reply With Quote
Old 10-10-2007, 12:55 AM   #5
janikphoto
Member#: 10471
2000 BMW Z3
be careful about running it near the pedals. You don't want to crimp or pinch it...
I might be selling my car soon, and the only thing worse than running the wire is removing it (becuase you don't have a stereo to listen to after all your hard work). I dread having to pull out the seats and panels to remove all my stuff...
Old 10-15-2007, 05:56 PM   #6
dlusion2000
Member#: 118636
2004 35th SE Sedan
Sea Mist Green
it is a manual so no go on the plug. I have the wires running into the trunk now, just need to get through the firewall. I'm about to drill a hole and then caulk it up, but I would like to find a better way. I found where the wires go through from the engine bay end, only problem is there is a rubber gasket (no big deal) but then on the other end the damn ventilation system is in the way. I have the whole dash and everything taken apart and the ducts sit right in front if where the wires come through.
Old 10-15-2007, 06:17 PM   #7
GotTurbo
Member#: 64186
1998 A MONSTER
SOON BMW STEEL GREY
If I remeber correftly if you go to thr passenger side and pull back the carpet you will see your ecu. on the firwall above the ecu you should see a hole you can put ur cable through. I found it when put my batter in the trunk. i can take pics tonight and post them tommorow if you want.
-Matt
look at the pic on the bottm left where the beam goes into the firewall there is a whole u can barely see. thats the one I used for my wiring and my boost controler.
hope that helps
GotTurbo is offline   Reply With Quote
Old 10-15-2007, 08:29 PM   #8
dlusion2000
Member#: 118636
2004 35th SE Sedan
Sea Mist Green
thank you, that helped a lot. I assume you meant the hole where the AC water drain hose comes through, because that is the one I used. everything is all hooked up and sweeeet.
Old 10-15-2007, 08:29 PM   #9
janikphoto
Member#: 10471
2000 BMW Z3
Originally Posted by dlusion2000 View Post
I have the wires running into the trunk now, just need to get through the firewall. I'm about to drill a hole and then caulk it up, but I would like to find a better way...
You should drill the hole and use a plastic or hard rubber grommet. Use a size just big enough for the wire and grommet. If you go the calk route, use a silicon caulk and not a latex one. Marine Goop is good.
Help installing amp and sub anyone? JustinM88 Texas Impreza Club Forum -- TXIC 17 10-21-2008 09:34 AM
n00b needing help installing amp/sub with stock HU jojotherider Car Audio, Video & Security 1 07-14-2006 03:02 AM
Help installing amp and sub wrx112 Car Audio, Video & Security 1 10-20-2003 11:52 PM
Installation Help... Sub/Amp and Tweeters joltdudeuc Car Audio, Video & Security 10 02-07-2002 01:43 AM
Installed amp, but I have a problem. Help! Cjchaps Car Audio, Video & Security 8 08-27-2001 04:22 PM
