Old 10-08-2007, 10:57 PM   #1
virpacalis
Member#: 19214
'07 STI
in the slow lane
Default 07 STI with DP on 93
Andy at Verocious in Wilmington, DE installed and Protuned the following: a Cobb catted downpipe and heat shield, a Walbro fuel pump, and a Prodrive boost control solenoid. The car is still quiet but much smoother and quicker. I'm very satisfied with the crew at Verocious and RallySport Direct which delivered the parts.
virpacalis is offline   Reply With Quote
Old 10-09-2007, 12:54 AM   #2
wuuusaa
Member#: 92894
2015 Wrx
i presume you running a stock cbe?
Old 10-09-2007, 01:12 AM   #3
jordanretro1223
Member#: 143039
2007 STI
Satin White Pearl
Very nice, if you're logging it now after the tune, what are they looking like, AFR's? Any knock of any sort?
Just curious since it is an 07...
jordanretro1223 is offline   Reply With Quote
Old 10-09-2007, 01:13 AM   #4
wRxbeater11
Member#: 12682
Wow, deff high for those mods. congrats
wRxbeater11 is offline   Reply With Quote
Old 10-09-2007, 01:40 AM   #5
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
Yuck... SOmeone does not know how to tune the KNock correction system on the ecu. Its knocking pretty bad around 6300.
CLark
AZScoobie is offline   Reply With Quote
Old 10-09-2007, 01:50 AM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
CLark
You read my mind
Equilibrium Tuning is offline   Reply With Quote
Old 10-09-2007, 10:21 AM   #7
nxttruck2002
Member#: 90879
I don't think someone knows how to tune the '07 ecu's...
nxttruck2002 is offline   Reply With Quote
Old 10-09-2007, 12:44 PM   #8
SinistiR
Member#: 58733
2004 STi
This is Andy from Verocious. I would completly agree that it looks like the DAM is dropping from knock. I am trying to post a log of the run now showing absolutly no knock and the motor taking full advance over the full rpm range. I am having trouble posting the datalog, so if anyone can help me I would appreciate it. I think the issue is with my dyno electronics. I have been losing the signal from my rpm pickup and drum pick up sensors the last week and it is getting worse.
Actually I am quite fond of the 07 ECU's
SinistiR is offline   Reply With Quote
Old 10-09-2007, 01:06 PM   #9
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by SinistiR View Post
This is Andy from Verocious. I would completly agree that it looks like the DAM is dropping from knock. I am trying to post a log of the run now showing absolutly no knock and the motor taking full advance over the full rpm range. I think the issue is with my dyno electronics. I have been losing the signal from my rpm pickup and drum pick up sensors the last week and it is getting worse.
You realize that in the 07 ECU's knock will NOT be represented by a drop in the DAM or even in the Learned Ignition value that you log? Check out your total ignition advance around 6300... see a nice sudden dip?
-- Ed
Old 10-09-2007, 01:45 PM   #10
SinistiR
Member#: 58733
2004 STi
Ed
There is no sudden dip in timing. It does lose about a degree right there, but I had to smooth out the drop through the load ranges as rpm increased.
On a side note I also monitor knock via an earpiece and amplifier I made.
Old 10-09-2007, 02:03 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Ed
Losing 1-1.5 degrees is generally what a knock event will look like on the 07's.
After the drop, the ECU will continue to advance the timing .5* at a time. Compare that dip with what your maps are actually calling for and you'll likely see a discrepancy.
Thanks
-- Ed
Old 10-09-2007, 03:24 PM   #12
virpacalis
Member#: 19214
'07 STI
in the slow lane
That's right.
Old 10-09-2007, 03:35 PM   #13
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Thanks
-- Ed
Default is -1.4* and the step without the knock signal present is .35*
Gabe
gabedude is offline   Reply With Quote
Old 10-09-2007, 03:38 PM   #14
gabedude
Member#: 10108
07 STI
I bet it was running out of fuel or he did not adjust the ETC to hold the throttle open till fuel cut.
Gabe
Old 10-09-2007, 04:16 PM   #15
SinistiR
Member#: 58733
2004 STi
The last three rpm break points for throttle are set to 6900, 7150 and 7200. Duty cycles are 100% until 7150 and fall to 25% at 7200. Rev limit is set to 7200.
The car has an upgraded fuel pump, and running 89-90% DC.
When I view the gear ratios instead of power and torque in WinPep. At the same time power drops, the gear ratio goes crazy and ossilates all over the place. Its not smooth like a slipping clutch. I have never observed this happening before.
Old 10-09-2007, 06:03 PM   #16
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
Gabe
yup thats it right there
bren wrx is offline   Reply With Quote
Old 10-09-2007, 08:02 PM   #17
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That sounds odd... possibly just a dyno issue. If you can do a couple on-road pulls I could plot them in my road dyno for you
-- Ed
Old 10-09-2007, 11:35 PM   #18
wuuusaa
Member#: 92894
2015 Wrx
Originally Posted by virpacalis View Post
That's right.
how did you get that to mate up? i thought cobb dp's are full 3'?
got pics of exhaust set up?
thanks
Old 10-12-2007, 11:03 PM   #19
virpacalis
Member#: 19214
'07 STI
in the slow lane
thanks
No pics, no leaks, clean fit. It mates up to the OEM stuff exactly.
Old 10-12-2007, 11:12 PM   #20
virpacalis
Member#: 19214
'07 STI
in the slow lane
Because of responses to my original post, I asked Andy to look at my car again. His professionalism and helpfulness are most impressive. He offered to strap it down again and do a few more pulls. The car is still nice and quiet but even quicker and smoother. Here's what I ended up with:
Old 10-13-2007, 12:29 PM   #21
JDubD
Member#: 123730
2006 STi
I had my car tuned by Andy and the results were amazing. With a tbe and equal length headers, he tuned open ecu for 295awhp and 378lb/ft of torque. Not to mention almost 300 miles per tank. I know this is a little off topic but Andy is an excellent tuner with alot of knowledge. Just my .02
JDubD is offline   Reply With Quote
DP question... sti stock dp on wrx... don't know whats wrong... byrin Newbies & FAQs 5 12-26-2008 06:10 PM
Problem with DP on 05 sti mark.j86 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-10-2008 09:46 AM
07 STi Limited - Stage II 93 pump gas Dyno Flash Proven Power Bragging 25 10-16-2007 10:49 PM
Ball Park WHP #s on an 07 STi with mods? zakSti Newbies & FAQs 8 05-18-2007 07:42 PM
can you install an acess port on 07 sti with ecutek reflash. jhook AccessPort 0 04-20-2007 06:39 PM
