Old 10-08-2007, 11:07 PM   #1
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Default Tranny flush hard?
I think I need to flush my tranny on my 98 legacy brighton, is it hard? what kind of fluid do I need? Because sometimes it's feels kinda rough to get it in gear.
Zac86 is offline   Reply With Quote
Old 10-08-2007, 11:10 PM   #2
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
it culd just be low, or the torque converter could be oing bad. But yeah, start with a drain and filter replacement. It is not too hard to do. Just remove some bolts, clean up the pan to remove all the residue that settled in it, replace filter, replace gasket, bolt back up and fill. It is a very messy job, though. Wear OLD clothes...
janikphoto is offline   Reply With Quote
Old 10-08-2007, 11:25 PM   #3
Zac86
Member#: 136919
ABP
I have a 5spd
Old 10-09-2007, 10:00 AM   #4
janikphoto
Member#: 10471
2000 BMW Z3
Originally Posted by Zac86 View Post
I have a 5spd
Oh, when I think of tranny flush, I think of an auto. To change out the gear oil isn't hard on almost any manual trans. You just remove the filler plug and siphon out the old stuff. Pump new stuff back in and close it up...
Old 10-09-2007, 10:22 AM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
A tranny flush means that you take a machine and flush out the transmission - that's pretty much only done on an automatic tranny, FYI. Just changing out the gear oil isn't hard at all. Just like an engine oil change - drain, drain, drain some more, and then fill 'er up. It's hard to get it all out, so fill it up with approximately what you drained. The dipstick is near the back of the engine bay, sticking out of the transmission.
There are a number of routes you could go for tranny fluid. Among two reccomendations are doing Uncle Scotty's cocktail (search for it here on Nasioc) or the Redline Lightweight Shockproof/ Gear oil mixture. I forget the ratio of gear oil to Shockproof.
Wiscon_Mark is offline   Reply With Quote
Old 04-10-2009, 07:51 PM   #6
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
no one has a picture of the tranny oil plug by any chance do they? i want to change my transmission oil with extra S and have the fluid just dont have the time to seek out the plug. also, how do i syphon my tranny oil out? isnt it just like the oil pan where the plug is towards the bottom so the gear oil just pours out?
gunny11218 is offline   Reply With Quote
Old 04-10-2009, 08:18 PM   #7
2.5GTLegacy
Member#: 111219
Check your owners manual or a Haynes manual.
2.5GTLegacy is offline   Reply With Quote
Old 04-10-2009, 08:33 PM   #8
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
do you know and are just telling me to read? what if i told you i "lost" my owners manual...
Old 04-11-2009, 08:12 AM   #9
Huffer
Member#: 36735
99 GF8 Impreza 2.0
2= 1998 BD + BK Legacy GT
It's on the bottom of the tranny. If you know where the ENGINE OIL drain plug is - it isn't that one.
Huffer is offline   Reply With Quote
Old 04-11-2009, 10:56 AM   #10
that one legacy
Member#: 103665
the manual transmission drain plug has a giant square cut into it, and faces straight down from the bottom of the transmission case. i think you use a 1/2" drive ratchet to loosen it (insert the ratchet directly into the square hole, don't use a socket), it's been a while since i changed the tranny fluid in mine so i forget the wrench size. but yeah, just take the plug off and let the old oil drain out. then wipe all the shavings off the inside part of the plug (which is magnetic and catches all the little metal shavings that are floating around in the oil), and then replace it when the fluid stops coming out. put it on tight, but not too tight. pretty much just do it like you would do the oil drain plug.
then get inside the engine bay and look towards the back of the engine, on the passenger side of the car. you might need to remove the intake arm to get a really good look at it, but the dip stick is a small yellow one stuck right on top of the transmission. take that thing out, insert your funnel (get a long neck one, or at least one with a hose attached), and pour in about 4.2 quarts of your favorite gear oil. 75-90 weight is the recommended type, i use Mobil 1 myself, but everyone has their opinion on what is best.
that one legacy is offline   Reply With Quote
Old 04-11-2009, 12:10 PM   #11
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
exactly what i was looking for ^^^ thank you kindly sir *tips hat* i will post results when i am finished, my fluid of choice is subaru's imfamous Extra SSS
Old 04-11-2009, 01:24 PM   #12
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
is that it?
seems to be the lowest point on my transmission and the only bolt on the bottom of it, too.
Old 04-11-2009, 03:52 PM   #13
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
yep! that was the one. extra s activate!
but seriously,its gorgeous, im outside, using wifi, talking to you guys, working on cars, enjoying the weather, listen to some good music, drinking beer. this day is fantastic!
Old 04-11-2009, 06:03 PM   #14
that one legacy
Member#: 103665
hmmm, looks like maybe some of the subaru manual trannies use a 17mm or possibly a 19mm bolt then for the drain plug (which should still be magnetized. i know my automatic uses a 19mm, but i swear my manual uses the 1/2" drive hole...i'll have to check it out next time i'm down there.
and i know what you mean about being able to just do everything at once. unfortunately my wi-fi doesn't go out to the parking lot of my apartment complex, but i've been working on my cars too. just replaced the a/c belt adjuster on the white car (which i broke because i forgot to loosen the old one when i was tightening the belt down), and installed a rear wiper on the red car (which is a brighton, so it didn't come with one). now i get to swap the steering wheel on the white car (for a leather one from a GT limited!)!
Old 04-11-2009, 07:06 PM   #15
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
For the newer Subaru's, you actually need to use a Torx T-70 to remove your Transmission drain plugs...
This way your local Jiffy Lube grease monkey wont accidentally drain your tranny fluid when you only wanted your engines motor oil changed.
Jonathan is offline   Reply With Quote
Old 04-14-2009, 06:28 PM   #16
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
ea that bolt was a 21 believe it or not. Is there anything SLE I can do to make my transmission feel and shift better fluid did. Great deal on quality of the shifts but iS there anything else that you guys would recommend?
Old 04-18-2009, 03:55 PM   #17
that one legacy
Member#: 103665
i'm still learning this myself. i only bought this car back in October '08, so i haven't really had it long enough to experiment much with it. that, plus it was down for 2 months when the clutch failed and i had to save up to get it replaced.
i originally had the regular old valvoline 75w90 gear oil in it, but then switched to straight pennzoil synchromesh because the gears are grinding. next i'm going with straight Mobil 1, which is what i always use in my automatic.
Old 04-20-2009, 12:07 PM   #18
Huffer
Member#: 36735
99 GF8 Impreza 2.0
Check the band adjustments on the tranny...a simple adjustment can make a world of difference.
Old 04-20-2009, 02:58 PM   #19
gunny11218
Member#: 186959
2012 WRX sedan
Limited WRB
what is the band adjustment exactly? Where do I locate it?
Old 04-20-2009, 06:05 PM   #20
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Band adjustment is on a automatic transmission. There is no adjustment for manuals. It adjusts the brake bands inside the 4eat which the transmission uses to slow down and stop different internal moving parts (planetary gears, sun gear, ring gear). This is what the transmission uses to have multiple drive ratios (gears, or 1st, 2nd, so on).
See:
http://en.wikipedia.org/wiki/Automatic_transmission
-and-
http://auto.howstuffworks.com/automa...ansmission.htm
fastenova is offline   Reply With Quote
Old 04-21-2009, 08:11 AM   #21
Huffer
Member#: 36735
99 GF8 Impreza 2.0
^^ my bad. Didn't see 3rd post down.
Old 04-21-2009, 10:53 AM   #22
fastenova
Member#: 38829
Not your usual 1997
Legacy GT
Happens to the best of us!
I needed to look up that info anyway because I was talking to somebody about how automatic trannies work and couldn't remember the name out the outer gear (ring gear)
Tranny flush. total PITA? the_poser Texas Impreza Club Forum -- TXIC 4 09-01-2007 09:17 PM
Tranny flush question for 02 wrx Subynut Service & Maintenance 8 05-02-2007 06:48 PM
Tranny Flush Question nerdydorkus Transmission (AT/MT) & Driveline 3 05-14-2006 01:40 AM
Fuel filter and tranny flush kodakeos Service & Maintenance 11 08-20-2004 11:36 PM
place to get a tranny flush? [mr.]impreza Bay Area Impreza Club Forum -- BAIC 4 03-31-2002 04:25 AM
