Old 10-09-2007, 01:49 AM   #1
Jhovany
Member#: 137317
2006 STI
Rally Blue
Default Personal Best
Just wanted to share and get opinions of what you guys thought of this. This was back in June Sorry for the long delay and crappy image. This run was also done at 5000ft elevation. I am Car#11
Car mods:
list of mods:
APS SR56 turbo
APS 70mm CAI
APS turbo inlet
APS DR525 FMIC
APS fuel rails
APS 50/50 BPV
APS TGV deletes
Invidia DP
HKS Hi-Power Exhaust
Cobb Accessport (protuned at 19psi 91oct)
Jhovany is offline   Reply With Quote
Old 10-09-2007, 11:17 AM   #2
blowbyu24
Member#: 84482
2005 STI.UR gt4088r
E85 pro comp sti
thats a lot of mods for only a 12.6
just more practice and you will get it lower
blowbyu24 is offline   Reply With Quote
Old 10-09-2007, 11:21 AM   #3
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 12.8@105mph
seems like the car ran out of steam at the 1000 ft mark.. any idea what those times/mph were? you deff. had the car beat all the way to the 1/8 mile......maybe shift better??? i don't know something does not add up....what were you running against? and how much hp/tq are you making?
boostdog is offline   Reply With Quote
Old 10-09-2007, 11:27 AM   #4
rxkid
Member#: 122544
02 bugeyes
needs a clear coat BAD
def should be hittin lower numbers. keep practicing and you shall get em.
rxkid is offline   Reply With Quote
Old 10-09-2007, 11:30 AM   #5
karl750
Member#: 100977
2004 VF30 WRX
12.96@103.7mph 1.84 60'
That 108 trap shows the car has some power, but i would think with your launch (which i think is decent) and your trap that you should have a lower ET. Maybe it's the extra shift in the 6-speed. Personally i'd be happy with that run and it looks like it was a good race. If you want a quicker ET, get that launch into the 1.7s and i think you could run a 12.4.
karl750 is offline   Reply With Quote
Old 10-09-2007, 01:58 PM   #6
stu
Member#: 25768
35R bugeye
Awdsome
are you flatfoot shifting. needs something. your traps should be higher.
stu is offline   Reply With Quote
Old 10-09-2007, 06:57 PM   #7
Jhovany
Member#: 137317
2006 STI
Rally Blue
I believe (if i remember correctly) I shifted into 5th ALMOST crossing the finish
Old 10-09-2007, 06:58 PM   #8
Jhovany
Member#: 137317
2006 STI
Rally Blue
I am making 335whp and 319lbs/ft torque on 91oct at 19psi
Old 10-09-2007, 07:23 PM   #9
SueBaroo
Member#: 140838
2007 Forester 2.5X
Had: 03 WRX/06 STi/08 Leg
Weird, the guy with the 07 STi w/ only a TBE and tune is running almost the same w/ way less mods...He's on the left...
SueBaroo is offline   Reply With Quote
Old 10-09-2007, 08:34 PM   #10
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
The 07's have some longer gears, this has been discussed. They also make some insane power when tuned. The OP is also at 5000ft elevation, let's not forget that. Congrats on a personal best, I would think you could get sub 12.4 passes out of that if you can get the 60ft down and dial in shift points (maybe they're not perfect where they are).
wrxfactor is offline   Reply With Quote
Old 10-09-2007, 08:59 PM   #11
MJU1983
Member#: 14364
2003 WRX, '06 Armada
05 Vette & 05 STi (sold)
5,000 ft...can no one read? lol
That plus pump 91 results in a pretty good run if you ask me.
MJU1983 is offline   Reply With Quote
Old 10-09-2007, 09:04 PM   #12
Jhovany
Member#: 137317
2006 STI
Rally Blue
Awesome! So my time is not TERRIBLY bad? Congrats to that guy that ran a 12.7!!!! Yeah Im not that great of a driver but im working on it!
Old 10-09-2007, 09:51 PM   #13
MJU1983
Member#: 14364
No, were you in Albuquerque?
http://www.nhra.com/tech_specs/altitude.html
Old 10-09-2007, 10:08 PM   #14
hotrod
Member#: 14141
2002 Impreza WRX
e85forum.net
Area 51 dragway is in Roswell and is listed as 3700 ft altitude.
For a turbocharged car you need to use the 1/2 correction factors so his
12.669 @ 108.68 corrects for altitude to a 12.445 @ 110.505 run near sealevel.
Not bad times for altitude, it took us over 5 years for someone to run anything faster than a low 12 here at Denver and 5800 ft altitude.
As far as the 60' time, you should be able to get that down in the mid 1.7x with a bit of practice but altitude makes it more difficult to get a good launch than it is at sea level due to its effects on the turbocharger. (it takes longer to build boost and the turbo has to work significantly harder to make the same boost).
Larry
hotrod is offline   Reply With Quote
Old 10-09-2007, 11:15 PM   #15
Scuba Steve
Member#: 35543
04 GT35R STi+E85
10.87@130 @5800ft elv.
Larry
So true, but I did manage a 12.6@108 at Bandi with just an 18G, D/P and MBC back in 04 .
Scuba Steve is offline   Reply With Quote
New Personal Best brokeawd Alaskan Impreza Club Forum -- AKIC 2 06-10-2002 01:43 AM
New personal best 1/4 mile time- with a slipping clutch even! dug-e-fresh Factory 2.0L Turbo Powertrain 31 05-06-2002 03:14 PM
New Personal Best 1/4 mile time... Bighurt1 Factory 2.0L Turbo Powertrain 26 04-15-2002 08:26 PM
Message Board Statistics All times are GMT -4. The time now is 07:00 PM.
