Old 10-09-2007, 03:40 AM   #1
dontgiva
Member#: 105098
07 OBP WRX
Bangbus
Default non synthetic to synthetic oil?
just changed the oil today at 1k miles. used subaru NONsynthetic oil. was wondering if it would be ok once i hit 3xxxx miles that i began using synthetic oil.
thanks
dontgiva is offline   Reply With Quote
Old 10-09-2007, 08:34 AM   #2
Runnamukk
Member#: 158020
96-7 LOB
Green,White
Would be fine to switch to synthetic oils anytime.
Runnamukk is offline   Reply With Quote
Old 10-09-2007, 09:48 AM   #3
bluesubie
Member#: 767
04 FXT
But do not be lured into the misconception that your engine is completely broken in and you will have better protection. At 3,000 miles, your engine will still have high wear metals and that lowers the viscosity of the oil.
Using the proper viscosity for your conditions is probably the most important factor over "when to switch to synthetic".
-Dennis
Old 10-10-2007, 11:17 PM   #4
garboplateNY88
Member#: 134113
05 LEGACYGT
247hp 300tq retuned STM
Post
I would wait to 10,000 miles before you use sys oil. Engine got's to break in.
garboplateNY88 is offline   Reply With Quote
Old 10-11-2007, 12:45 AM   #5
Impresario
Member#: 344
2004 Impreza WRX
Java Black Pearl
From the Unabomber Oil FAQ:
http://forums.nasioc.com/forums/show...&highlight=faq
If I want to use synthetic, when should I switch?
This is a hotly debated topic and you will find many convincing arguments for waiting a certain amount of miles or oil change cycles. There is no evidence that one particular time is best, so switch to synthetic when you feel is best, be it at 10,000 miles or 10 miles.
My car has XX,000 miles on it, can I switch over to synthetic?
Yes. Some recommend an engine oil flush prior to the synthetic conversion. An engine flush is usually a very thin oil designed to remove old oil deposits. There are many convincing arguments as to whether this step is required or not. Arguably the best engine flush treatment is Auto-RX.
Impresario is offline   Reply With Quote
Old 10-11-2007, 01:44 AM   #6
cnguyen
Member#: 119209
had my oil changed to Castrol Syntec from 1K. Haven't really burned or dropped the oil level since. Must have lucked out with a good engine.
cnguyen is offline   Reply With Quote
Old 10-12-2007, 01:58 PM   #7
drivin blind
Member#: 73043
2011 STI/2010 370Z
Black/Black Cherry
I've run Syntec 5-30 since 2nd oil change. Haven't used a drop between changes. ( I keep a close eye on my oil/fluid levels). RP
drivin blind is offline   Reply With Quote
Can you switch from part synthetic to regular oil sweetdang Legacy Forum 6 10-25-2008 08:39 PM
switch from synthetic to regular oil at 84K miles? dpitkin Service & Maintenance 8 06-28-2007 10:05 PM
mobile 1 synthetic to regular oil... guynexdoor Newbies & FAQs 14 07-04-2006 03:37 AM
going from synthetic to regular oil...good? TKRbeast Newbies & FAQs 23 12-17-2004 07:36 PM
Switching back from synthetic to regular oil mibobe Newbies & FAQs 9 07-16-2002 04:52 PM
