Old 10-09-2007, 04:45 AM   #1
WRX401
Member#: 36696
BLACK
Default Need some advise on hybrid build.
Let me know if this setup will get me in the 300hp range if not what hp will I be in? Iím doing a hybrid build. Thanks
Stock EJ25 short block from Subaru, with stock 2.0 head
750cc injector, fuel rail and 255 fuel pump
18g8cm turbo, stand alone computer system
up pipe, down pipe, intake and exhaust
upgraded TMIC
Not sure if I should upgrade the stock turbo manifold to a higher performance one? Let me know what you guys think.
WRX401 is offline   Reply With Quote
Old 10-09-2007, 12:23 PM   #2
rustyzipper
Member#: 79175
2004 FXT
Red
Should be fine, I personally would go with bigger injectors so you dont have to fool with them again when you decide that you are tired of that 18G. Might also want to think of an EWG setup to let that little guy breathe up top. Or Sti cams in the 2.0 heads. 0.02
rustyzipper is offline   Reply With Quote
Old 10-09-2007, 06:12 PM   #3
WRX401
Member#: 36696
BLACK
I was thinking about STI cams or 06 wrx cams also. You have any idea how much they would run me? I'm pretty sure I'll need a stronger set of valve springs and retainer also right? Why would it be better to with an EWG? Thanks in advance.
Old 10-09-2007, 11:26 PM   #4
rustyzipper
Member#: 79175
2004 FXT
Red
You could probably pic up some nice used ones from the Classifieds forum here , but you have to be quick about it. Springs and retainers is always a good idea when going with a more aggressive cam. The EWG is not per se "better" ,just one more way to get the most out of your upper RPM power. If you are pulling the motor , I would go with the cams. You can always add the EWG to the setup later. This will allow the 18G to hold boost easier up top.
Old 10-11-2007, 07:23 PM   #5
jbwrx
Member#: 86274
. Andrewtech
Gold Club Member
I would guess that setup would be good for around 350 hp. I have a hybrib motor with a vf43 and supporting mods and I put dow 315whp and 335 wtq.
jbwrx is offline   Reply With Quote
Old 10-23-2007, 12:10 PM   #6
jonhybrid
Member#: 126519
18g 2.5l hybrid
upgraded TMIC
What head gaskets are you going with
jonhybrid is offline   Reply With Quote
Old 10-23-2007, 09:52 PM   #7
WRX401
Member#: 36696
BLACK
planning on using the stock 2.5 head gasket from subaru or is it better if so go with something else??
Old 10-23-2007, 09:55 PM   #8
WRX401
Member#: 36696
BLACK
Did you go with after market cams also or did you use the ej20 cams?
Going with Full race GT35 twinscroll.. need some advise on motor upgrades?? Moes07sti Built Motor Discussion 26 01-07-2010 02:02 PM
Need some advise on what to buy (06-07) WRX vs STI GTIzzle07 General Community 55 06-16-2009 10:14 PM
Need some advise on my heads fordfabwiz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-11-2008 11:33 AM
Need some advise on my setup... CeeLowe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-10-2004 08:14 PM
New to the club, need some advise on suspensions ZMANNH25rs Brakes, Steering & Suspension 3 08-17-2001 03:05 PM
