Old 10-09-2007, 12:14 PM   #1
mcrawford
Member#: 142601
2006 STI
Rally Blue
Default High Pitch Grinding Sound When Shifting Into 4th Gear
2006 sti, 15k miles...
Sometimes when I'm shifting into 4th gear i hear a high pitch gear-grinding sound.
The best way I can describe the sound is like when you are drilling in drywall screws and your get to the very end of the screw going into the drywall/stud... it makes a 1/2 second *ehnt* noise... which means you can't screw it in any further... make sense?
My mechanic told me that when you press the clutch sometimes there is a possibility that air is getting in there in which case the hydraulics to not fully engaging the clutch ???
Does this make any sense? Wouldn't it then do it all the time?
I'm confused.. it's only done this about 5 times so far over the past few months...
Your thoughts?
mcrawford is offline   Reply With Quote
Old 10-09-2007, 12:15 PM   #2
boostdog
Member#: 149752
07 wrx tr
rr tuned stg2 [email protected]
I would take it to the dealer and let them look at it...there is no way air is in there like that....that's just stupid!
boostdog is offline   Reply With Quote
Old 10-09-2007, 12:47 PM   #3
djsniggedy
Member#: 102157
What you lookin at
willis?
Is this at high speed or just calm regular driving? Possibly a worn syncro? I know wrx's have a high speed 4-5 grind occasionally...but I'm not sure about your case.
djsniggedy is offline   Reply With Quote
Old 10-09-2007, 01:10 PM   #4
mcrawford
Member#: 142601
2006 STI
Rally Blue
Yes! High speed only... accelerating onto hwy usually after engine is hot...
shifting into 4th gear issues WheelieMonster Transmission (AT/MT) & Driveline 21 08-17-2009 03:52 PM
I get an odd grinding noise when throwing into 4th Gear? VIRULENT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 04-25-2007 10:55 AM
Clunking sound when shifting into second high rpm!!? ThrawlWRX Transmission (AT/MT) & Driveline 8 06-01-2005 01:56 AM
Transmission grind when shifting into 4th. ShaneC Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 06-19-2004 01:24 PM
Light grinding sound when shifting to 2nd, 3rd gear. Be afraid. Siper2 Transmission (AT/MT) & Driveline 12 08-14-2002 02:27 AM
