Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 10-09-2007, 06:53 PM   #1
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
2003 Corvette ZO6 400whp
Default 07 STi Track Results
I ran a 12.788 @ 105.65mph with a 1.763 60'.
Only mods are TBE and AP tune by XXTuning, full interior
It was unsually warm too, at Epping, NH dragway, mid to high 80's on Saturday afternoon.
Here's the slip.
Hopefully with a litte more practice I can chop it down to a 12.6.
DC5edSTI is offline   Reply With Quote
Old 10-09-2007, 07:02 PM   #2
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
driving is on point but it needs more trap, i know you can drive and shift - so log and see if any timing is being pulled or some sort of leak......the 1/8th is a little low too, what are your shift points?
i see cars with your mods go 107-110 in this area, also make sure you shift 5th and see if your trap goes up
bren wrx is offline   Reply With Quote
Old 10-09-2007, 07:27 PM   #3
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
Shift points are redline in 1st / 6700rpm in 2nd / 6krpm in 3rd and 4th which puts me into 5th a few hundred rpms before the end of the 1/4.
When I was at a different track a few weeks ago my traps were 106-107, but 1/4 times was 13 flat.
I know I still need a lot of practice hustling this car down the strip... I'm sure someone with more experience could rip this car.
Old 10-09-2007, 07:57 PM   #4
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
run the gears out a little harder, everything about your run is great outside of the 1/8 and 1/4 traps.
Old 10-09-2007, 08:53 PM   #5
wrxwhat
Member#: 87653
500 hp STI / 1100hp
Supra T / Stock G35
I shifted at 7k in every gear with the same mods and ran a 12.50 @ 110..
shift high
wrxwhat is offline   Reply With Quote
Old 10-09-2007, 09:20 PM   #6
Jhovany
Member#: 137317
2006 STI
Rally Blue
what kind of fuel you running when you made this particular run?
Jhovany is offline   Reply With Quote
Old 10-10-2007, 12:11 AM   #7
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
Thanks bren, I want to get my traps up too.
Old 10-10-2007, 12:12 AM   #8
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
shift high
I'll give it a shot. THis was actually the one and only run I got in that day at the track, because it was so busy with some events I'm somehow overlooked.
So I plan to go back soon so I back it up with another run, and I'll give it a shot.
Pump 93oct gas from whatever the nearest name brand station to the track was.
Old 10-10-2007, 02:33 AM   #9
06BlackSTIwith550WHP
Member#: 116325
2006 BLACK STI
UR Rotated GT30R
DOES YOUR CAR PULL HARDER IN 4TH AT 6000-6500 RPMS OR 5TH AT 4600-5000 RPM? WHY ARE YOU SHIFTING 5TH WHEN YOU CAN REV OUT 4TH GEAR!!!!! your trap will go up if you dont shift fifth silly
06BlackSTIwith550WHP is offline   Reply With Quote
Old 10-10-2007, 02:21 PM   #10
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
Was the caps really necessary?
I'm shifting 5th in 1/4 based on peoples suggestions... like bren suggested above, and others I was talking to at the track that were having success shifting 5th.
And I listened because redlining 4th at a different track the other week only picked up 1-2mph... but kept me in the 13s flat.
And based on my butt dyno it does pulls harder in 5th at 5krpm then in 4th at 6krpm.
Old 10-10-2007, 02:23 PM   #11
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Seems like you gotta bang those gears a bit harder. Your trap speed is highly dependent on how quickly you shift.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 10-10-2007, 02:28 PM   #12
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
-- Ed
That's what I thought... which why I mentioned that I need practice still.
My weakness is really on the 1-2 and 2-3 shift...
But practice makes perfect and hopefully my next visit in a few weeks will reflect that.
I'm just happy I'm finally outta the 13s.... lol
Old 10-10-2007, 06:52 PM   #13
STi Mikey
Member#: 114631
2009 GTR, 735whp
13' Benz, 15' WRX
Whats up man, glad to see that you are getting the hang of launching the car.
Im going to the track this weekend, pm me if you wanna come.
p.s., your traps should increase 1-3 mph taking into consideration saturday will be about 50 degrees
STi Mikey is offline   Reply With Quote
Old 10-10-2007, 08:18 PM   #14
UltimateLurker
Member#: 82488
06 Lotus Exige
A 1.7 60' and 8.1 8th mile is spot on for a good driver/your mods. 12.7, however, is a little low, especially for warmer weather. Expect to run a 12.5 in cooler weather, and lower than that if you'll do some weight-reduction mods.
UltimateLurker is offline   Reply With Quote
Old 10-10-2007, 11:19 PM   #15
GhoSTI
Member#: 86488
2004 STi
constructive help in ppb? wow...
honestly, practice alot on the street, i dont mean go racing, but practice your shifting, you would be amazed at how much better you get when you bang gears for fun.
GhoSTI is offline   Reply With Quote
Old 10-11-2007, 12:20 AM   #16
subaru222
Member#: 92967
2009 wrx hatch
dark grey metallic
wow slip looks great good job
subaru222 is offline   Reply With Quote
Old 10-11-2007, 10:28 AM   #17
Gfunk720
Member#: 42549
E92 M3 M\\\
VW Sportvagon Oilburner
Nice work man...
Redding crew represent!
Gfunk720 is offline   Reply With Quote
Old 10-11-2007, 11:17 AM   #18
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
That is a bit slow for your WHP numbers. Only 105 traps? Your 60 ft is fine...
Edit, read all the other comments. Take a look at your tune and see where WHP falls off. Most 07's tuned correctly will pull all the way to redline. So shift right before the limitter. Shift hard and fast. You shuld not have to shift to 5th. If anything run through the traps banging the limitter in 4th.
For comparison, there are stock 07's trapping 104.
gabedude is offline   Reply With Quote
Old 10-11-2007, 09:03 PM   #19
bren wrx
Member#: 59454
'10 E92 M3 M-DCT
brentuning.com/blog
i commented in the other thread of his, his tune makes less up top then the OTS tune. Chris said it was running too lean OTS.
Old 10-13-2007, 04:16 PM   #20
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
Thanks for the comments everyone.
Originally Posted by Gfunk720 View Post
Nice work man...
lol... hell yea!!
Here's my dyno plot, and the one Bren is refering to in the post above. It feels much stronger in the middle then up top according to the butt dyno.
I will be going back to the track in a couple weeks and will be trying running it straight through to the limiter at the same track.
David's 2008 STi - AMR S1 (Stage 1) TRACK RESULTS! AMR Proven Power Bragging 38 08-18-2009 10:13 PM
2008 Subaru STi - AMR STAGE 1 (AMR-S1) - Track Results VIDEO!!! :) AMR Proven Power Bragging 63 06-25-2008 02:00 AM
07 STI - P&L Motorsports Parts and Tune ( and track results! ) Super Nintendo Proven Power Bragging 17 06-10-2008 01:57 PM
2008 AMR STi - 100octane mix + TRACK RESULTS!!! AMR Proven Power Bragging 34 03-14-2008 11:15 AM
My 07 STI Track Results Foo_Blyat Proven Power Bragging 69 10-25-2007 06:57 PM
