Old 10-10-2007, 01:00 AM   #1
gecko77799
Member#: 142470
Default Hit gas hard from dead stop and goes nowhere
I've had this problem for a while where I'm at a stoplight and hit the gas...sometimes hard/quick and the car goes nowhere. There are no signs of it dying as the engine runs fine but after I let off the gas for a few seconds and slowly put my foot into it then it'll take off. It's a 95 Impreza 2.2 Automatic. It's also a slug, especially for a 2.2. I did a head gasket job and cleaned carbon off the pistons heads about 10k miles ago. I've also put on a different TPS with no change in performance. Any ideas?
Also, when I take sharp turns there is a lurching/popping noise. WTH....I've replaced both front CVs. Help please.
gecko77799 is offline   Reply With Quote
Old 10-10-2007, 02:32 AM   #2
0deucedub
Member#: 148030
2002 PSM Bugeye
:-o
change your auto fluid, and oil filter. make sure theres no leaks around tranny oil pan.
0deucedub is offline   Reply With Quote
Old 10-10-2007, 03:00 AM   #3
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
Might be your torque converter going bad, or it could be that you have a clogged fuel filter. Have you changed your plugs and wires lately? Also, check all your grounds on the engine harness.
MeanEditor is offline   Reply With Quote
Old 10-10-2007, 09:25 AM   #4
el_guapo
Member#: 132038
funk er chicks
serious bidness
I used to have the same problem with a Volkswagon I had. It about got me killed several times. It turned out to be the transmission was low on fluid. I couldn't check it on that car because the transmission was sealed and required special tools to check the fluid level or add fluid. When the fluid was replaced, the problem went away.
Good luck........
el_guapo is offline   Reply With Quote
Old 10-10-2007, 09:55 AM   #5
irishSCOOBY
Member#: 161400
2005 impreza wrx rep
blue
that used to happen on my old impreza, it was just a 97, 1.6 GL, it turned out it was because i had a "sports air filter" turns out it didnt help the performance, i put back in the standard one and it took off again!!
irishSCOOBY is offline   Reply With Quote
Old 10-11-2007, 02:19 AM   #6
gecko77799
Member#: 142470
The transmission filter and trans oil were changed about 12k ago. Trans fluid is at correct level.
Fuel filter is only 9 months old. Plugs and wires are new. Any way of figuring out if it is the torque converter and would it only do it on slow sharp turns? When I put my foot into it and I'm already at a decent speed some days it acts like it has all the go in the world. Other times it will either delay really bad or not accellerate at all.....just maintain speed. Don't know about the harness grounds....figured if it's plugged in I shouldn't see and CEL codes and I don't.
irish- I do have a cone filter that is kinda clogging....I know I've needed to clean it or put the stock box back in....guess I'll try that next for sure. Appreciate it.....sometimes I just need someone to smack me.
Old 10-11-2007, 04:56 AM   #7
Pimpfoot
Member#: 147395
2007 WRX impreza TR
check the fluids in your rear. My 95 L coupe used to jerk and pop when id go around sharp corners. I sold it to a buddy of mine who did some work on it and told me that the rear was almost completely dry.
Pimpfoot is offline   Reply With Quote
Old 10-11-2007, 05:47 AM   #8
MeanEditor
Member#: 123139
1993 Turbo L Wagon
RED
I am going to say then that youhave a bad ground somewhere and it is really unlikely that it would throw a code. My question is, why do you think it's the transmission? Usually a loss of power is an engine issue so unless the tq coverter is going out there is no real reason to lose power there.
Do you have a CAI? If so do you run through puddles, is your MAF sensor clean? Also, check your compression, see if there is oil in your water or water in your oil, did you re-toque your heads properly... could be many things here. I would almost take it to a service shop and pay the $75 for an hour of diagnostic.
Old 10-12-2007, 12:19 AM   #9
gecko77799
Member#: 142470
Will definitely check the rear this weekend.
Mean- I don't think it's the transmission....just replying to a couple ideas above. Would one of those ground kits fix the grounding issue or is that something I'm going to have to trace? Figured it would be some sort of sensor or engine issue but haven't been able to pinpoint it. Yes - CAI. No puddles. Sensor is clean but am going to put the stock box back on this weekend. No water in oil/oil in water. Retorqued heads per specs in correct bolt order and everything.
Thanks everyone who have given me some good ideas so far.
Old 10-15-2007, 08:44 PM   #10
gecko77799
Member#: 142470
Checked the fluid on the differentials....they are good. Put the stock air box back in with a new filter....minor performance improvement but the car still seems to lack quite a bit of power that it is capable of. MAF is clean. Car still pops on slow turns like getting out of the drive way or slow corners.
Any other ideas? How do I check ground on the harness? Everything is plugged in and doesn't look loose. How do I pinpoint/test if the torque converter is the issue? Thanks.
Hard Shifting into 1st from dead stop zippydoc Transmission (AT/MT) & Driveline 20 01-28-2007 01:11 PM
Car goes nowhere when giving a little gas baileypicks24 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-22-2004 04:22 PM
wrx from dead stop, in first gear easing off the clutch, hitting the clutch point wrxxtc Service & Maintenance 3 06-30-2002 03:49 PM
Interesting noise (rear diff?) from dead stop SJGWRX Transmission (AT/MT) & Driveline 0 01-20-2002 09:32 AM
How to launch from dead stop ac_gohan Normally Aspirated Powertrain 12 03-01-2001 04:28 PM
