Old 10-10-2007, 01:14 AM   #1
Vish
Member#: 149559
Default Is warranty worth it? '05 sti
I just bought an used '05 wrx sti with only 15k miles. excellent condition.
bumper to bumper warranty is 36k miles/3years
powertrain is 60k miles/5years
But.. I went ahead and got the extended warranty for it, +4 years (until 2011) or up to 90k miles. Is it worth it? (it was almost $2k !!) I still have 30 days to cancel the extended warranty contract with no fees and get a full refund.. should I cancel?
The dealer talked me into getting it because there was only about 6 months left on the bumper to bumper warranty, but the power train warranty was still available for another 2 years.
Vish is offline   Reply With Quote
Old 10-10-2007, 08:22 AM   #2
Hondaslayer
Brain Stew
Member#: 4562
1998 Forester,lifted
1975 VW Westfalia tin top
You bought a Subaru Added Security contract and not a fly by night aftermarket one, right? If so it certainly can't hurt to have.
If it is a fly by night operation run far away!
You did get the Gold plan, correct? If not upgrade, the difference in price is completely worth it.
Old 10-10-2007, 10:11 AM   #3
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
Correct me if I'm wrong, but the warranty you bought is NOT a Subaru warranty? Yes?
None-the-less, do some research on this warranty company before you decide to cancel it, to make sure that they are reputable.
My experience is as follows:
1986 Fiero -- bought an aftermarket extended warranty (in 1988 when I bought the car) for $800. Excercised said warranty to replace the a/c compressor and/or any related parts, including freon (R-12). Warranty paid for itself.
2001 Focus -- bought an extended warranty through Ford for about $1,000. A/C stopped working -- dealer misdiagnosed and replaced a/c compressor and related parts. Ended up being a broken wire. None-the-less an a/c compressor is expensive, especially if it is due to the repair shops misdiagnosis and error -- how would I know that they didn't screw up? Shifter cable broke 2x -- had replaced both times. Had the RR window regulator/motor assembly replaced. The extended warranty paid more than I paid for it based on retail repair prices.
2006 WRX -- bought an extended warranty through Subaru for basically the drivetrain (engine, turbo, transmission, drive components, rear end) because I've never owned a Subaru. I will keep it (or have no choice at this point but to keep it).
Just make sure that you fully understand what this aftermarket extended warrranty does and does not cover. If you have to pay out-of-pocket first, then submit a claim for reimbursement and possibly less a deductible, can you afford to do so? Will they cover all [valid] claims?
Since the warranty cost you almost $2k, you have to look at what it covers. If it covers expensive items (e.g. engine; turbo; etc.) that fail due to non-abuse and/or modification, then yes, it's worth it.
If it sort-of covers items, meaning that there are a lot of exceptions, etc., then it may not be worth it.
Also, are you willing to assume some level of risk? Can you afford to pay out $2k later down the road if something breaks? If you can, then cancel this warranty.
Good luck and do some [more] research.
Old 10-10-2007, 11:14 AM   #4
woody06967
Member#: 110330
2007 STI Limited
2012 MDX 2012 Golf TDI
I never thought they were worthwhile until I had my entire longblock replaced under warranty this summer. $1200 <<< $6500
woody06967 is offline   Reply With Quote
Old 10-10-2007, 12:22 PM   #5
Barry
Member#: 11554
2011 STI
WRB SEDAN
Many dealers will discount the Gold factory warranty.........I suggest you ask your dealer if he can do better on the $$$$$. BTW, if you do not use the warranty you will get a pro-rated refund.
Barry is offline   Reply With Quote
Old 10-10-2007, 12:33 PM   #6
shemoves
Member#: 80663
1997 Outback
That is a tough call. If you are planning on doing any mods or taking the car to the track at all then I would definitely not keep it. If you are very good about keeping up with regular maintanance, as detailed in the owner's manual (not just oil changes), then it might be worth it. However, what all does it actually cover that the powertrain warranty does not? You might only be adding one year to something you already have...which IMO, would be a complete waste.
Personally, I would spend the money on getting a complete leak-down test on the motor and solid regular maintanance.
If you do decide to keep it, make sure you get in writing that previously existing conditions or mods (before you bought the car) will have no bearing on future warranty claims.
shemoves is offline   Reply With Quote
Old 10-10-2007, 01:08 PM   #7
Hondaslayer
Brain Stew
Member#: 4562
Does not matter, the contract clearly states that it covers the vehicle in factory original condition and that maintenance / abuse do have bearing on claims.
Old 10-11-2007, 12:59 PM   #8
Matt
Allergic to turbos
Member#: 181
Two Subarus and
a truck
I bought one for our '05 Outback and its already paid for itself. After 36k miles and the bumper to bumper warranty expired I've had two wheel bearings, overhead console, and headlights have been replaced.
As long as you don't go mod crazy, it is worth it.
Matt is offline   Reply With Quote
Old 10-12-2007, 09:35 AM   #9
Hondaslayer
Brain Stew
Member#: 4562
Wheel bearings are 5/60
Old 10-12-2007, 09:45 AM   #10
infox
Member#: 140413
truth, bought a 03 legacy with 55k, got the gold 100k extended warranty + free lifetime oil changes for $900 after taxes
infox is offline   Reply With Quote
Is an extended warranty worth it? inspectorgadget Newbies & FAQs 29 05-22-2007 05:25 PM
Extended Warranty worth it? gleinz New England Impreza Club Forum -- NESIC 22 04-13-2004 09:01 AM
extended warranty worth it? APSBLUEREX Bay Area Impreza Club Forum -- BAIC 11 01-10-2003 06:20 AM
Is the 7 year extended warranty worth it? Yasin Service & Maintenance 8 09-10-2002 04:47 PM
Extended Warranty - Worth IT? GTMAN General Forum Archive 7 12-27-2000 10:43 AM
Message Board Statistics All times are GMT -4. The time now is 06:32 AM.
