Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Old 10-10-2007, 06:13 AM   #1
GrimmSpeed
Vendor Sales Rating: (212)
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Default GrimmSpeed Up Pipe Release Group Buy
To introduce our new GrimmSpeed Up Pipe we are starting a group buy.
You are looking at the same outstanding quality as our other exhaust pieces. Folks, this is by far the nicest up pipe i have seen to date(and i've seen almost every other up pipe on the market).
- massiave SS flanges
- minimal internal steps for maximum flow
- inlet port diameter is matched exactly(but yet with a little bit of play for movement during install) to the gasket for the best flow possible.
- complete stainless steel construction
- optional ceramic coating
- weight reduction over stock piece
- flex joint that is NOT located in the bend which adds life expectancy to the flex section. many other up pipes have a flex right in a sharp bend so all the exhaust/turbulence is hitting up against it.
- reduce turbo lag
- +10whp gain
- increase exhaust flow to turbo
Adding a non-cat'd up pipe is one of the first things you should do to your Subaru. Arguably one of the best $/HP ratios. Due to emission reasons Subaru has to but very restrictive cats in the exhaust system. With the GrimmSpeed up pipe these cats are eliminated. Another great feature of the GrimmSpeed up pipe is that the inlet is gasket matched so you have a perfectly smoothed out exhaust flow compared to the big step that that tiny stock inlet has.
The GrimmSpeed up pipe is specifically created without an EGT bung. The ecu does not use the egt sensor for air/fuel adjustments. You do not need the egt sensor. If you would like to keep tabs on EGT temperatures the correct place to do it is on the exhaust manifold right after the exhaust ports, this is the only place where the correct temperatures can be taken.
Applications:
02-07 WRX
04-07 STi
04-07 LGT
04-07 FXT
04-07 Baja T
GROUP BUY DETAILS
Dates: Group Buy will end on October 26th
Pricing Tiers
1-5 Participants: 164.99
6-12 Participants: 159.99
13-19 Participants: 154.99
20+ Participants: 144.99
OFFICIAL LIST:
1. Pain++ - w/ blue coating
2. rexXNXmotion - w/ black coating
3. Daishi00 - w/ black coating
4. Mars_D - w/ black coating
5. boost junkie - w/ black coating
6. 1cugoblack - w/ black coatin & w/ both gaskets
7. sekretskwirl
8. kurokaze - w/ black coating & w/ both gaskets
9. kts262
10. sharkmonkey - w/ black coating
11. trick000 - w/ black coating & w/ both gaskets
12. rutchard - w/ black coating & w/ both gaskets
13. 12SECWAGON - w/ both gaskets
14. Mechie3 - w/ blue coating
15. wrexz - w/ black coating
16. BLACKALICIOUS WRX - w/ both gaskets
17. gundamwrx - w/ black coating & w/ both gaskets
18. bluemanchu - w/ black coating & w/ both gaskets
19. jermany755 - w/ black coating & w/ both gaskets
20. InsatiableAmos - w/ black coating
21. silver-duck - w/ black coating & w/ both gaskets
22. brain juice - w/ black coating & w/ both gaskets
23. pignoseSTI - w/ black coating
24. 05cgm - w/ black coating & w/ both gaskets
25. cre8ive - w/ black coating & w/ both gaskets
26. ZackyFarms - w/ black coating & w/ both gaskets
27. SubeN'Siren - w/blue coating
28.
29.
30.
As an option we can treat the pipes with our Ceramic Thermal Coating for $20. Shipping to the lower 48 states will be $10. We also carry the RemFlex Graphite Up pipe gaskets... up pipe>turbo is 15.99 and the manifold>turbo is 15.99. We recommend getting the graphite gaskets to ensure you have a leak free system.
As stated in the thread we have sold out completely in the first week so everyone past #5 on the list will have a 2 week delay in shipping as we will need to make another batch. we apologize for the inconvenience but we didnt expect this high of demand.
Justin Grimm
www.grimmspeed.com
AIM: GrimmSpd
we port down the pipe to flange connection so there is absolutely the smoothest exhaust flow as possible. something the competitors definitely DONT do.
GrimmSpeed is online now   Reply With Quote
Old 10-10-2007, 07:39 AM   #2
Mechie3
Member Sales Rating: (51)
Member#: 120152
I posted in the other thread that'll probably be closed as asked. Do you have dyno graphs? I want to see how the spool is affected, if possible, on an 06.
Mechie3 is offline   Reply With Quote
Old 10-10-2007, 07:40 AM   #3
T_A_C_H
Member Sales Rating: (58)
Member#: 100196
2007 STI
Let me be the first to say NICE!!
T_A_C_H is offline   Reply With Quote
Old 10-10-2007, 08:00 AM   #4
Pain++
Member#: 88289
2006 WRX: Stage 2
Urine-soaked Subway Car
Alright, these look great! Bump, and count me in.
Pain++ is offline   Reply With Quote
Old 10-10-2007, 12:56 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
i personally dont have any in shop dynos with the 06 but i have seen other nasioc'rs dynos when comparing the 06 non-cat'd stock up pipe and an aftermarket piece and there are definitely gains to be had. if you look inside your 06 up pipe there are some nasty narrow sections in there. alsp the inlet on the stock pipes are ridiculously small.
thanks! its even sexier in person
Old 10-10-2007, 01:20 PM   #6
RexXNXmotion
Member Sales Rating: (6)
Member#: 132241
MBP
Please add me to the list. Up-pipe + Coating, Thanks
RexXNXmotion is offline   Reply With Quote
Old 10-10-2007, 02:06 PM   #7
r0n
Member Sales Rating: (19)
Member#: 91839
Looks badass guys, gj!
r0n is offline   Reply With Quote
Old 10-10-2007, 04:37 PM   #8
Pain++
Member#: 88289
2006 WRX: Stage 2
oops, coat mine as well!
Blue, to match the headers/xpipe i'll be buying
Old 10-10-2007, 06:51 PM   #9
Daishi00
Member#: 78952
2005 WRX
CGM
I'm in. Ceramic coating for me as well.
Daishi00 is offline   Reply With Quote
Old 10-11-2007, 12:54 AM   #10
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
got you added, thanks Rex!!
thats what we shoot for.
Justin
Old 10-11-2007, 12:52 PM   #11
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
ok..updated your order info.
Justin
Old 10-11-2007, 03:50 PM   #12
RexXNXmotion
Member#: 132241
MBP
Come on guys lets get this price lower! Bump
Old 10-11-2007, 05:27 PM   #13
Pain++
Member#: 88289
2006 WRX: Stage 2
+1 for a cheap pipe from a good company!
Old 10-11-2007, 08:13 PM   #14
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
updated you as well daishi00. you guys sure have been keeping me busy with PMs in regards to this group buy...now sign up and stop trolling my PM box
Old 10-11-2007, 11:04 PM   #15
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
yeah lets go!
Old 10-12-2007, 12:57 AM   #16
All4bSpinnin
Member Sales Rating: (10)
Member#: 99102
09 135i 6MT FBO
Twin Turbo!
^take 80-120 flapper wheel to that, then a little cross buff action... nice smooth glossy finish for a super great product
All4bSpinnin is offline   Reply With Quote
Old 10-12-2007, 01:19 AM   #17
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
you should be a porter!...however i'm one step ahead of you, just didnt take any pics of it.
Old 10-12-2007, 09:08 AM   #18
Pain++
Member#: 88289
2006 WRX: Stage 2
Do eet!
Old 10-13-2007, 12:26 AM   #19
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
got a few coated tonight guys....looks REALLLYY nice!!!
Old 10-15-2007, 11:18 AM   #20
Mars_D
Member Sales Rating: (21)
Member#: 90480
2005 9-2x
Add me to this GB, black coating as well please.
Mars_D is offline   Reply With Quote
Old 10-15-2007, 02:45 PM   #21
pignoseSTI
Member Sales Rating: (13)
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
is the pipe diameter larger than stock?
pignoseSTI is offline   Reply With Quote
Old 10-15-2007, 08:33 PM   #22
boost junkie
Top Scoob 009
Member Sales Rating: (48)
Member#: 68273
2012 WRX
GD Race Car in progress
I'm in, put me down for one with black coating
boost junkie is offline   Reply With Quote
Old 10-15-2007, 08:33 PM   #23
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
added you to the list mars. its good to hear from you again
Old 10-15-2007, 09:32 PM   #24
distorto
Top Scoob 024
Member Sales Rating: (14)
Member#: 56364
RIP stompr :(
bagged vulvva
i am kind of a polydyn whore, i love their gold color. is it safe to have them coat it with it having a flex section?
distorto is offline   Reply With Quote
Old 10-15-2007, 10:15 PM   #25
Pain++
Member#: 88289
2006 WRX: Stage 2
Bump it up! for a good price, and saving me money
GrimmSpeed Phenolic Manifold Spacer Group Buy Reason01 Legacy Forum 92 01-15-2011 04:54 PM
GrimmSpeed Air/Oil Separator - Group Buy GrimmSpeed Vendor 'Group Buy' Classifieds 536 03-06-2010 12:51 PM
SSR Re-release Group Buy!!! Gruppe-S Vendor 'Group Buy' Classifieds 40 02-22-2006 09:55 PM
