Old 10-10-2007, 12:08 PM   #1
JCooper702
Member#: 151669
2005 WTB 05 STi, pst
wtb sti, my car was total
Default Upgrading to Stage 2 Reflash Question
I'm taking my subaru from stock to stage 2, and I plan to reflash using opensource and tactrix. My question is after I put on everything (uppipe, downpipe, TBE) Should I flash right then, or should I just start it up to check for leaks, which will probably throw CELs, and THEN reflash to stage 2?
JCooper702 is offline   Reply With Quote
Old 10-10-2007, 12:13 PM   #2
Giganticprune
Member#: 147662
2006 wrx tr stage 2
id start up and check for leaks first, i had no problems running around without a tune after i got rid of my cats (except for a CEL and my cruise control not working, but that didnt come about till a day and a half after i put on the parts) drove around for 2 or 3 weeks without a tune, no problems
Giganticprune is offline   Reply With Quote
Old 10-10-2007, 03:47 PM   #3
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
^^^What he said. Make sure it is mechanically sound before flashing it. Most Stage 2 maps have the O2 CEL and Fuel cap CEL disabled in my experience.
/brox
Broxma is offline   Reply With Quote
Old 10-10-2007, 05:11 PM   #4
harrison88
Member#: 127639
06 T REX No Rear
Cupholder :(
I just went ahead and flashed stage2
you can still check for leaks and what not
don't forget to take logs!
harrison88 is offline   Reply With Quote
Old 10-11-2007, 10:01 AM   #5
Murf_68
Member#: 71191
2005 WRX Wagon
Platinum Silver Metallic
+1
With the new piping and old calibration you might find your boost is all over the place. If you do drive without the reflash, make sure to log or at least monitor your boost. Do the same after the reflash to make sure everything seems in order.
Have fun!
Mark
Murf_68 is offline   Reply With Quote
Have accessport on my wrx running stage 1 gonna upgrade to stage 2 some questions Cobb2006WRXJR AccessPort 10 11-19-2009 07:18 PM
upgrade to stage 2! inpuressa Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 11-13-2006 09:10 PM
AP Question. Going to Stage 2...when did you reflash you ECU? Edvig Engine Management & Tuning 6 12-27-2005 09:24 PM
Those who upgraded from Cobb stage 2 to stage 2.5 WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 41 07-29-2004 04:56 PM
cobb stage 2 reflash questions... wrX-RTD Engine Management & Tuning 12 10-07-2003 11:34 PM
