Old 10-10-2007, 01:47 PM   #1
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Default Anyone running a gt30r or gt35r on a wrx hybrid
Im lookin into doing a wrx hybrid setup. 257 shortblock and 2.0 heads with some kind of cams. ( alot of ppl like the sti cams) Does any run the 30r or 35r on this setup? if so what kinda power are you making and what is your head setup?
thanks
99subi is offline   Reply With Quote
Old 10-10-2007, 02:05 PM   #2
wrx nig
Member#: 159864
03 RHD Bugeye STi
with Volk winter wheels
people have run those turbos on ej255's. wouldnt see why you shouldnt be able to do a hybrid setup.
wrx nig is offline   Reply With Quote
Old 10-10-2007, 02:38 PM   #3
poormansporsche
Member#: 79798
Brydon on RS25 was running at GT35R on a setup like that. Made pretty sick power.
cheers
poorman
poormansporsche is offline   Reply With Quote
Old 10-10-2007, 03:09 PM   #4
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
Wow i juist found it over there. he did make good power. seems that the stock wrx heads and the fuel pump were holding him back a bit.
Old 10-10-2007, 05:39 PM   #5
rustyzipper
Member#: 79175
2004 FXT
Red
I will be doing this build in the upcoming months , so I guess i will find out in do time.
rustyzipper is offline   Reply With Quote
Old 10-10-2007, 11:00 PM   #6
tino
Top Scoob 019
Member#: 43630
2004 GT40R-built 2.5
604 whp @1.8 BAR on VP109
im in the process of this build... about a months time all should be known.
GT35R 0.82 AR with a fully built 2.5 (sleeves, pistons, rods etc) and 2.0ltr STI V7 heads ported and with cosworth 278/274 AVCS cams...
But ive seen someone push 320 kw atw with the 2.5 and standard sti 2.0ltr heads with a GT35R and 25psi
tino is offline   Reply With Quote
Old 10-11-2007, 02:15 AM   #7
Kosmic
Member#: 99140
GD Racing chassis
Slowly in construction
He! he! KiloWatt Where you from?
320kw = 430HP
Kosmic is offline   Reply With Quote
Old 10-11-2007, 11:01 AM   #8
Huff
Member#: 103020
2004 WRX/STi Swap
Java Black Pearl
I'm running a stock block sti with jdm v7 heads. GT30r I made 370whp & 329tq at 21 psi on pump 93, and 434whp & 394 tq on c16. The limiting factor was the compression ratio believed to be 9.6:1.
Huff is offline   Reply With Quote
Old 10-11-2007, 01:04 PM   #9
breathinez
Member#: 79859
2002 384 whp
332.5 lbs
Isn't it better to have some big cams in there to let the turbo breathe? Wouldn't STi cams be a little small or atleast a limiting factor for a 30 or 35?
breathinez is offline   Reply With Quote
Old 10-11-2007, 01:30 PM   #10
wuuusaa
Member#: 92894
2015 Wrx
how much boost on c16?
Old 10-11-2007, 07:04 PM   #11
poormansporsche
Member#: 79798
It seems to me that when running 2.0 heads with a 2.5 shortblock you lose out on a lot of torque. I'm assuming this must be because of the 8.6:1 CR?
cheers
poorman
Old 10-12-2007, 01:30 PM   #12
WrXtaCy2003
Member#: 85036
2013 PBP sti ltd
05 LGT 35r 30psi..busted
i have a 35r .82ar on my hybrid and put down 409 psi with 19psi with conservative a/f's, this was the last pull done while tuning then the next pull my AEM EMS fried.
WrXtaCy2003 is offline   Reply With Quote
Old 10-12-2007, 06:00 PM   #13
99subi
Member#: 78118
2002 Corvette coupe
05 Legacy
im lookin for 400-425 whp on 93 pump with meth
Has anyone run a GT30R on a 2.0L bigwem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 06-01-2009 12:32 PM
Anyone running a TD04 or 5 on their Legacy SS? 00boostedRS Pre-2002 Factory Turbo Powertrain 33 12-10-2008 11:34 PM
GT30R or GT35R 9vapors Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 02-20-2006 09:52 AM
GT30R or GT35R? Taking suggestions.... riggs Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 34 12-24-2005 03:44 AM
Anyone Running 300hp and Similar Torque On Stock WRX Tranny? MY99 2.5GT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 18 12-28-2001 03:45 AM
