Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Commercial ECU Reflashes
Old 06-18-2007, 01:12 PM   #1
KSTech
Member#: 143570
Default Surging on decelleration.. especially downhill...
After installing bigger injectors - Helix 860cc (no other mods at the same time), my car tends to surge (or lightly buck) at about 18-20inHg of vacuum when decellerating and/or going downhill. It is not going in and out of overrun fuel cut like I thought it might be. Injectors are working great at idle, part throttle, and on boost. Fuel trims are pretty much within 5%, except during this decel surging- where they shoot up to +25% and then back down and into the negative and then back up/down again - this is causing the surging. Engine hunts a little bit at idle too, but not too bad.
Any ideas what to do to fix this?
Details: '04 STI with SB GT13 turbo, APS FMIC, Helix 860cc injectors, 1-step cold plugs, Cobb intake, APS BOV, TB exhaust, etc. ECU tuned with Enginuity for the injectors, and a UTEC only for open loop. Approx. 5000 feet elevation (about 12psi atmospheric pressure).
KSTech is offline   Reply With Quote
Old 06-22-2007, 07:36 PM   #2
KSTech
Member#: 143570
bump...
Any help? I think I need to change where the ECU shuts off the injectors when decelerating. Anybody know how to do this?
Old 06-22-2007, 10:04 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
Only map I know if is Decel Fuel Resume and that map is only accessible on ECUTek at the moment. What RPMs is this surging happening at? And have you logged throttle percentage during the surging to see if you've got a possible electrical problem?
Master2192 is offline   Reply With Quote
Old 06-23-2007, 12:30 PM   #4
KSTech
Member#: 143570
It happens mostly around 3k rpm, but I have felt it from 2500 - 4000.
I logged it versus throttle parameters yesterday. The throttle voltage stays rock steady at around 14V, but the duty cycle is constantly varying from 15% to 25%, and the throttle opening is varying along with the surge by almost 0.5 degrees - 9.02 to 9.41 on one log, and 9.80 to 10.20 on another. Could this small change in angle be felt that much? Could this also be related to my idle hunting too?
Old 10-11-2007, 07:40 PM   #5
blah0r
Member#: 106122
can i buy an 06 hood scoop delete off u?
blah0r is offline   Reply With Quote
up-pipe...odd noise on decelleration miniclip Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2006 09:04 PM
Log shows knock on decelleration 69_Lex AccessPort 4 11-13-2006 11:06 PM
valvetrain sound on decelleration? happasaiyan Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 01-18-2005 01:07 PM
WRX Oil Surge on the track ? nabsie Impreza Forum 0 04-14-2004 08:38 AM
compressor surge on stock bpv? ZoomnWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 12-14-2003 08:55 PM
