Welcome to the North American Subaru Impreza Owners Club Sunday July 31, 2016
Old 01-17-2002, 01:39 AM   #1
funscooby
Member#: 11325
2000 Impreza RS-NT
Orange
Default Reset airbag light?
Hi The passenger side airbag was remove now the airbag light is on is it possible to reset or shut this light off somehow?
Thanks!
funscooby is offline   Reply With Quote
Old 01-17-2002, 02:22 AM   #2
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
Somewhere out there somebody can tell you what you would need to make a test thingy. Basically I think it's just a resistor that you place in where the airbag used to be. (on the wires, doesn't have to be in the same physical position)
How much resistance? That I don't know.
CosmoTheCat is offline   Reply With Quote
Old 01-17-2002, 11:46 AM   #3
Alan
Member#: 3601
2006 WRX Wagon
BRIGHT BLUE!
You need a 3 ohm resistor to "fool" the airbag computer into thinking there is an airbag connected. Otherwise it will output an error and light the warning light.
Or use a little black tape and cover the warning light.
Alan is offline   Reply With Quote
How to reset SRS airbag light? RUN4BUX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 11-12-2012 06:33 PM
steering wheel airbag light fix jsnm Interior & Exterior Modification 9 07-22-2010 05:55 PM
resetting your airbag light vien Interior & Exterior Modification 0 03-04-2010 03:01 PM
Airbag light having nothing to do with airbags? coloradosti Interior & Exterior Modification 2 06-27-2004 05:02 PM
SRS Airbag light came on. How do I reset? cybin Service & Maintenance 7 12-20-2003 11:40 PM
