Old 10-10-2007, 06:23 PM   #1
Gerkins31
Member#: 52337
OMGHi2U What does it mean when my download speed it fast and my upload speed is slow?
My browsing speed is painfully slow all of the sudden on my cable broadband. I wen to speedtest.net, and found out that my download speed is ~850k/sec, but my upload speed is ~85k/sec. What does this mean? Any ideas before I call the cable guy?
Gerkins31 is offline   Reply With Quote
Old 10-10-2007, 06:25 PM   #2
CSULBwagon
Member#: 95428
02 WRX wagon STG2
Dirty Silver
they cap the upload.
CSULBwagon is offline   Reply With Quote
Old 10-10-2007, 06:26 PM   #3
Gerkins31
Member#: 52337
So that's no indication of my problem then?
It certainly doesn't download anything at 800k/sec, I don't understand why it reads as that on speedtest.net
Old 10-10-2007, 06:27 PM   #4
Fach
Member#: 17133
stop uploading pr0n
Fach is offline   Reply With Quote
Old 10-10-2007, 06:28 PM   #5
r0bman
Member#: 87015
kilobits vs. kilobytes, my friend... little b vs. big B.
... you would do well to make the distinction.
r0bman is offline   Reply With Quote
Old 10-10-2007, 06:30 PM   #6
Gerkins31
Member#: 52337
kilobytes.
Does it say anything that all three speed tests I've tried rated me at almost 1 meg/sec, but the actually download speed is much slower?
Old 10-10-2007, 06:42 PM   #7
outferno
Member#: 27469
2004 Forester XT
Download speed is dependent upon the server you're downloading from as well.
No servers, aside from major sites like cnet, download.com, Microsoft, have given me my full 8 megabits (about 1 megabyte per second). Other websites, are around 100kilobytes to 400. Some other sites, I get 600-800.
It all depends on where you're downloading from. In addition, if you're constantly uploading at 85k, you won't be downloading or even moving on the internet, since you won't be able to communicate with any servers since your upload bandwidth is already used up.
Also, your download/upload ratio is very good. My guess is the server you're trying to access, there's a break somewhere within the route, or you're uploading constantly.
outferno is offline   Reply With Quote
Old 10-10-2007, 06:52 PM   #8
Speedinticket
Member#: 76596
Originally Posted by Gerkins31 View Post
kilobytes.
8 bits in a byte. If you're reading 85 kilobytes up , and your provider sold you 768 kilobits up. It's about right. 85 kilobytes = 680 kilobits. You'll most likely not reach the full 768, due to protocol overhead (IP addressing info and such) and and any number of other factors, including things running in the background on your PC that you might not even know about. Most providers will not roll a truck out for less than a 10% difference.
Also, actual download speed factors in the speed of the source of the file, traffic between you and it, and distance to the server. For instance; you may have 1 meg of bandwidth, but actual throughput to a distant or busy server may only be 500 kilobits or less.
Speedinticket is offline   Reply With Quote
Old 10-10-2007, 07:16 PM   #9
markman
Member#: 93623
it means the RIAA has found yore pRonz
markman is offline   Reply With Quote
Old 10-10-2007, 07:18 PM   #10
Reflex-Arc
Lord of the Gilf
Member#: 1703
2012 Fiat 500 Sport
Copper
You need drain-o. yore series of tubes are clogged.
Reflex-Arc is online now   Reply With Quote
Old 10-10-2007, 07:34 PM   #11
Gerkins31
Member#: 52337
I'm not uploading anything, but my browse speed and download speeds are retardedly slow, no matter what page I'm accessing. So what does that leave me with?
I'm gonna try the draino thing though. Do I pour it into this little retractable cupholder thingy?
Old 10-10-2007, 07:53 PM   #12
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
could be just a crappy cable line going into your house if your download speed is slow. (slow upload is normal though)
Cable company can come hook a meter up to your cable line and check that. Do you have the cable split a bunch of times?
z is offline   Reply With Quote
Old 10-10-2007, 08:11 PM   #13
Speedinticket
Member#: 76596
Possibly. He can get readings himself by logging into the modem (assuming your provider/modem maker allows that) Most modem websites are at 192.168.100.1, but you can check the modem maker's webpage if that doesn't work. You're looking for signal levels and signal to noise ratio (snr). Downstream signal should be between -15 and +15, but ideally between -5 and +5. Upstream signal can vary by provider, but is usually between 35 and 50db. You can check www.dslreports.com to find what your local provider requires for signals. Also, you want to make sure your downstream SNR is above 25db.
Most speed issues are caused by the computer itself, or another computer sharing the Internet connection through a router. You should scan for virii, or any other kind of malware. Also, if you're running any kind of file sharing, turn it off. Those take up bandwidth like nobody's business. Also make sure you're running all the latest updates for any software that connects to the Internet.
Just a few ideas to keep ya busy for tonight.
Old 10-10-2007, 08:16 PM   #14
Nasiocks
Member#: 62023
2013 ST
Most residential service providers do this. People download more then they upload so they allocate more bandwidth to the download.
Nasiocks is online now   Reply With Quote
Old 10-10-2007, 08:47 PM   #15
jasonallenross
Member#: 125978
2002 WRX Wagon
I think it has a lot more to do to with ISP's wanting to charge more for people running servers, or preventing people from running servers at all.
jasonallenross is offline   Reply With Quote
Old 10-10-2007, 08:58 PM   #16
Gerkins31
Member#: 52337
Here's the data from the site you mentioned. The downstream snr is fine, but I'm not sure about the rest of it. Anything strike you as weird?
Downstream Value
Frequency 735000000 Hz
Signal to Noise Ratio 35 dB
QAM QAM256
Network Access Control Object ON
Power Level 1 dBmV
Upstream Value
Channel ID 1
Frequency 34000000 Hz
Ranging Service ID 388
Symbol Rate 2.560 Msym/s
Power Level 38 dBmV
edit: now every time I refresh it the Downstream power level is 0 dBmV
no file sharing software is up...
Old 10-10-2007, 09:04 PM   #17
Prevent
Member#: 149114
if its 85kb/sec than thats amazing, if its 85kbps tha nthat sucks balls. for cable you should atleast be seeing 364kbps or 44kb/sec
Prevent is offline   Reply With Quote
Old 10-10-2007, 09:07 PM   #18
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
You're not using anything wireless, are you?
wagman01 is offline   Reply With Quote
Old 10-10-2007, 09:18 PM   #19
Gerkins31
Member#: 52337
Nope, and no router of any kind. And this is the only computer in the house. Two TVs have cable split to them, though.
Old 10-10-2007, 09:23 PM   #20
outferno
Member#: 27469
2004 Forester XT
If you're experiencing terrible slow downs on every site but did not experience this before - you may need to restart your modem.
This happens from time to time, sometimes my router needs a restart, sometimes my modem needs a restart. If it's got a battery in it, go ahead and pull it out and kill the power to it. Then replug the battery and turn it on plugged in (I have to do this with my cable modem from time to time, don't know what causes it, but restarting it seems to help it).
Old 10-10-2007, 09:25 PM   #21
Speedinticket
Member#: 76596
Downstream Value
QAM QAM256
Power Level 1 dBmV
Upstream Value
Channel ID 1
Power Level 38 dBmV
In the system I work for, 38 up isn't bad at all. 42 or so is ideal. Your cable system may vary. There's many of factors that decide on what they use for upstream levels. 0 down is perfect. According to the techs I've talked to from Motorola, -5 to 0 is perfect. It's normal for that to fluctuate a little, up to 3db a day or so. Your SNR of 35 is great. I don't think you have a signal issue, unless it's in the upstream. You'd be best to check DSLreports or something similar to find out what users in your area have.
There's also a thread on here with some good info, started by alacrity024 earlier today.
Old 10-10-2007, 10:13 PM   #22
Mad06STi
Member#: 123324
2006 STi
07 Daytona 675
85KB/sec is amazing!?
I pull my hair out at anything less than 120 and average around 200, from a good site I get a steady 400KB sustained.
P.S. KB and kb are the proper abbreviations for kilobyte and kilobit, respectively.
Mad06STi is offline   Reply With Quote
Old 10-10-2007, 10:15 PM   #23
wagman01
Member#: 3894
2002 WRX Wagon
Battlewagon Black
I think he's referring to upload speed. I hope.
Old 10-10-2007, 10:15 PM   #24
Mad06STi
Member#: 123324
2006 STi
07 Daytona 675
D'oh, yeah, that would make more sense. My reading comprehension is a little lacking.
Old 10-10-2007, 10:32 PM   #25
henryh
Member#: 13457
Since you mentioned your browsing speed is slow, but your results from Speedtest.com look ok, it could be the DNS server you're using (or the one that your cable/DSL defaults to) is crap.
Try setting your DNS servers manually to:
208.67.222.222
or
208.67.220.220
OpenDNS
Or maybe this doesn't work. What am I, a doctorB?
henryh is offline   Reply With Quote
What does it mean when the tornado siren is going off? HalfBaked Off-Topic 33 02-17-2008 09:23 PM
what does in mean when a sub is tunes to.. ironfinger Car Audio, Video & Security 5 12-22-2006 02:04 PM
what does it mean when an Ex contacts you over the holidays? ColinL Off-Topic 45 12-31-2002 12:15 AM
What does it mean when something is typed like _this_ Andrew Newbies & FAQs 2 03-30-2001 10:34 AM
