Old 10-10-2007, 06:39 PM   #1
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
Default Anyone need ECUExplorer, I have it
I found it, It was on a 5 month backup on a external hard drive so with that being said I thought I would share!!!
Donations appreciated lol....
I'll try to keep the link up as long as possible but if it goes over I'll move it elsewhere!!!!
http://webpages.charter.net/noeladam...er.v3.0.25.exe
Documentation
ecuExplorer comes fully documented and the pdf is copied during installation. Everything from opening saved log files to querying the RAM content of the ECU is covered in the manual. If you've read the manual and are still having problems please visit the blog, email me or visit some of the enthusiast sites that refer to tari.co.za as others may have had the same issues.
Diagnostics
Real-time diagnostics are retrieved using the Subaru proprietary SSM protocol. A large number of data items are able to be retrieved but their availability depends on your ECU type. ecuExplorer can also read the current and historic trouble codes recorded by the ECU. It will read both traditional OBDII codes as well as those defined by Subaru.
OBD Cable Support
ecuExplorer supports a wide range of OBD cables and Serial to USB convertors. As long as the cable is ISO9141 compliant it will work for real-time diagnostics. To use the ecuFlash module your cable must have the required flash voltage across the correct pin. ecuExplorer was developed using OpenPort cable from Tactrix Inc. I have developed and tested with versions 1.0 and 1.2 and they support all ecuExplorer functionality.
ecuFlash
The ecuFlash modules are courtesy of Colby Boles at OpenECU.org. They are the first public release of his flashing modules. His ECUFlash application will have the latest flash modules and may support other vehicles. Follow the documentation I have provided for ecuExplorer and the ecuFlash modules and you will not have any problems.
Open-Source
The source code is freely available here. If you search the blog you will find a number of posts that explain some of the source architecture. If you have a question please either post it on the blog or email me and I'll help as best I can. Enjoy!
The Future..?
Unfortunately I am no longer developing this application. I released the source code in the hopes that others would continue development. If you have made changes or know of someone who has I would be interested to see how the application has evolved.
Core Features
* SSM real-time diagnostics lets you know how the engine is performing
* Live adjustment offers fine-tuning of certain parameters
* ecuFlash functionality lets you decide the power output of your engine
Real-time Diagnostics
* View saved log files
* Capture real-time data for analysis
* User-defined data items
On-the-fly changes
* Reset ECU to clear trouble codes
* Set idle speeds
* Set ignition timing
Flash memory
* Download ROM image
* Compare ROM image to flash memory
* Upload ROM image to flash memory
Requirements (Diagnostics)
* Windows XP (Service Pack 2)
* OBD cable with ISO9141 support
Requirements (Flashing)
* OBD cable with neccessary flash voltage
* Flash block connector
Noeladams is offline   Reply With Quote
Old 10-11-2007, 02:32 PM   #2
AK WRXer
Member#: 124473
2005 Legacy GT
Atlantic Blue
I am looking for EcuExplorer as well......Just formatted my laptop and forgot to back it up.
Anybody?
AK WRXer is offline   Reply With Quote
Old 10-11-2007, 03:20 PM   #3
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
Anybody?
i can host it if anyone has it.
Old 10-11-2007, 09:23 PM   #4
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
Version 3.0.25 anyone????
Old 10-11-2007, 10:49 PM   #5
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I've been hunting for it for a while now but no one seems to have it. Ill see if I can grab it from a member of another forum.
/Brox
Broxma is offline   Reply With Quote
Old 10-12-2007, 10:59 AM   #6
06rexwagon
Member#: 114730
2006 WRX Limited Wag
[email protected]
06rexwagon is offline   Reply With Quote
Old 10-12-2007, 11:28 AM   #7
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
Originally Posted by 06rexwagon View Post
could you zip the ecuexplorer directory from program files? It comes up with about 7 errors then runs.
I do appreciate the help!!!!!
Old 10-12-2007, 11:41 AM   #8
06rexwagon
Member#: 114730
[email protected]
I'm looking for it.
Old 10-12-2007, 12:13 PM   #9
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
I'm looking for it.
thank you!
Old 10-12-2007, 02:17 PM   #10
06rexwagon
Member#: 114730
[email protected]
Can't find it on my laptop. I'm out of town so I can't check my desktop. Anyone else have it?
Old 10-12-2007, 07:06 PM   #11
Noeladams
Member#: 121517
2003 Subaru WRX
World Rally Blue
bump I have it up for now.......
Old 10-12-2007, 07:24 PM   #12
mixmastermatt
Member#: 137506
Awesome, Ive been looking all over for this.
mixmastermatt is offline   Reply With Quote
Anyone see the latest "To Catch a Predator" last night? dmross Off-Topic 6 06-12-2007 02:50 PM
Does anyone have the link to the picture with all of the bands???? ducmaan748 Off-Topic 6 05-16-2006 05:03 AM
Anyone seen the latest SCC? IronMonkeyL255 South East Region Forum 1 01-28-2004 05:55 PM
Anyone seen the latest issue of SCC? Gummy Bear Off-Topic 28 07-15-2003 03:00 AM
anyone have the ALPINE SEC-8063 security system?? i have Qs scoobie ownz Car Audio, Video & Security 6 10-01-2001 09:00 PM
