Old 10-10-2007, 09:39 PM   #1
bbarnett83
Member#: 149357
2004 Impreza WRX STI
Default sti motor build
OK i blew my sti motor early this summer and its time to build it. Should i build a stroker with stock head parts or should i build a strong bottom end with cams and etc.? Don't have the money to do both. Any body have any ideas or suggestions ?
bbarnett83 is offline   Reply With Quote
Old 10-11-2007, 10:19 AM   #2
wcbjr
Member#: 4001
2006 Legacy GT
Obsidian black
How did you blow your motor? That will kind of give us a clue as to what you are trying to do with the car.
And go look in the Built Motor Discussion forum.
Generally, strokers are only for those people that are looking for every single last ounce of power from a built engine and have the deep pockets to back it up. If I were to guess, just get some forged rods and pistons and call it a day. From what I have read, cams don't do very well unless you have a decent amount of headwork, which is very pricy.
What turbo are you working with?
wcbjr is offline   Reply With Quote
Old 10-11-2007, 10:59 AM   #3
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
Just do a new shortblock with drop in forged pistons unless you are going bigger than a 20G. If you install it yourself, you can get it all done for ~2500 bucks. There are many 07 STIs that are having to do this.
gabedude is offline   Reply With Quote
2.6l Track Motor build 2008 STi Maxwell Power Services EtoS Built Motor Discussion 33 06-05-2013 10:53 AM
Who builds big valley/georgie performance sti motors??? Copper Rex Built Motor Discussion 15 12-28-2009 03:08 PM
sti motor build bbarnett83 Built Motor Discussion 1 10-12-2007 03:30 PM
junkyard motor build (used parts budget build!!!) shipjumper Built Motor Discussion 17 06-15-2006 06:35 AM
The car i've been thinking of building - impreza L with WRX STi motor swap OneArmedScissor Normally Aspirated with bolt-on Forced Induction Powertrain 7 05-20-2002 11:56 AM
