Old 09-19-2007, 12:23 PM   #1
vipergtrdj
Member#: 131770
2001 Subaru Impreza
Default ej22 na turbo build
I am starting this thread because I am in the process of rebuilding my ej22 with ej22t heads, pistons, and dropping a vf11 turbo in it. any suggestions such as how to achieve 15psi of boost would be much appreciated.
how hard is it to do a valve job - is it mandatory ?
pistons rings replaced ?
anything elses i should know about ?
vipergtrdj is offline   Reply With Quote
Old 09-21-2007, 08:56 PM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
if i were you i would use a td04. are you going to get new bearings also? its a good idea to have the cylinders honed a little bit(not too much so you'll need bigger pistons) and replace the rings since you are swapping pistons. make sure to clean the ring grooves really good.
~Josh~
ballitch is offline   Reply With Quote
Old 10-11-2007, 10:11 AM   #3
Rick Gendreau
Member#: 161500
Default Can you sell me a stock ej22 piston?
Good luck with your conversion. I'm investigating putting stock or turbo ej22 pistons in an eg33 engine. Could you sell or lend me one of your removed stock ej22 pistons so I can test the fit?
Rick
Rick Gendreau is offline   Reply With Quote
Old 10-11-2007, 09:41 PM   #4
simple monkey
Member#: 81067
1989 RX, FX16
both white
i would suggest leaving the na ej22 heads on it. they flow better.
simple monkey is offline   Reply With Quote
Old 10-11-2007, 09:44 PM   #5
simple monkey
Member#: 81067
1989 RX, FX16
both white
i would suggest leaving the na ej22 heads on it. they flow better, but for documentation purposes, i would put the ej22t cams in in those heads. i think the cams would help the low down power.
Old 10-11-2007, 11:48 PM   #6
silentt
Member#: 119995
2004 Outback XT
Peachy
I was about to suggest the exact same thing.
silentt is offline   Reply With Quote
Old 10-11-2007, 11:59 PM   #7
dropmech
Member#: 41477
2006 Tahoe that
will pull your bumper off
Isn't the na 22 block an open deck?
dropmech is offline   Reply With Quote
Old 10-12-2007, 01:34 AM   #8
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
I have run an ej22 NA block and made about 320 whp with stock ej22t pistons. And yes, it didnt last long, but that wasnt the fault of the internals.
reddevil is offline   Reply With Quote
Whose boosting an EJ22 NA? Turbo GC4 Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-11-2014 04:07 PM
ej22 na turbo build vipergtrdj Built Motor Discussion 0 09-05-2007 10:24 PM
Going from NA build to Turbo build G.Subramaniam Normally Aspirated with bolt-on Forced Induction Powertrain 33 07-16-2005 10:47 AM
WTB EJ22 na Turbo GC4 North West Impreza Club Forum -- NWIC 0 03-27-2003 04:53 AM
Power on EJ22 NA? oldpreza Normally Aspirated Powertrain 1 05-03-2001 10:05 PM
