Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 10-11-2007, 06:50 AM   #1
Member#: 109527
1997 GC8 [email protected]
Default APS twin fuel rail setup with TGV deletes
Is anyone running this setup I would like to go to a 8 injector setup and this seems to be an easy way to do it.
If so how is it fit finish ext and what size injectors are you running?
The second set of injectors look a bit cheesy though I would like to be able to run 8 1200 injectors so I can run 100% meth. I am not sure if you can run large injectors in the second upper bank?
saintluciascooby is offline   Reply With Quote
Old 10-11-2007, 06:43 PM   #2
Member#: 72680
2013 Subaru STi
Satin White Pearl
I actually picked this up a while ago so here is what I can tell you so far.
The fuel rails and tumbler valves bolt up to the motor very nicely no real fitment issues there.
However you will have some fitment issues with FMIC piping and the coolant tank can no longer be mounted to the manifold. The engine wiring harness also gets stretched out a bit trying to get over or around the second set of fuel rails. Maybe extend it a little bit if you have to.
As far as injectors go I have a set of stockers in the primary location and a set of 1600cc ford motorsport bosch injectors for the secondaries. I decided to stick with an actual bosch injector but any bosch style should fit.
snwman is offline   Reply With Quote
vf39, perrin side feed fuel rails, ks tech tgv delete plates arrowscooby Engine/Power/Exhaust 11 12-26-2012 11:20 PM
Deatchwerks 850cc sidefeeds, complete APS sidefeed fuel rail kit, tgv deletes, sti im methaddict SCIC Private Classifieds 7 06-04-2010 11:58 PM
Socal: Deatchwerks 850cc sidefeeds, complete APS sidefeed fuel rail kit, tgv deletes, methaddict Engine/Power/Exhaust 14 05-24-2010 09:10 PM
FS: (NJ) Perrin Side Fuel Rails and JDM TGV Deletes PartySTi Engine/Power/Exhaust 6 08-09-2009 04:34 PM
Ver7 manifold with TGV deletes and jdm fuel rails car_cursed Private 'For Sale' Classifieds 18 04-25-2006 05:49 PM
