Old 10-11-2007, 10:36 AM   #1
kleen
Member#: 69959
02 WRB Impreza WRX
03 Dodge SRT-4
Default Head Bolts Question
Ok, so I finally got everything put back together after replacing some bent valves. I go to turn it over and get the oil pressure up. Oil starts spewing out of my LH head between the head and block. I think *hoping* that its just the head bolts were not torqued enough. These are the instructions I followed:
1. Apply a coat of engine oil to washers and bolt threads
2. Tighten all bolts to 29N*m (22ft-lb) in alphabetical sequence.
Then tighten all bolts to 69N*m (51ft-lb) in alphabetical sequence.
3. Back off all bolts by 180deg first; back them off by 180deg again.
4. Tighten the bolts (A) and (B) to 34 N*m (25ft-lb).
I think they're really weird instructions because I've never heard of backing off the bolts. Does anyone have a more precise way of doing this?
Thanks,
Colleen
kleen is offline   Reply With Quote
Old 10-11-2007, 11:15 AM   #2
MasterKwan
Member#: 98961
2003 WRX
You're missing a couple steps which means they'er way under-torqued. This is the sequence for an STI.
2) Tighten the cylinder head bolts.
(1) Apply a coat of engine oil to the washers and bolt threads.
(2) Tighten all bolts to 29 Nm (3.0 kgf-m, 22 ft-lb) in alphabetical sequence.
(3) Tighten all bolts to 69 Nm (7.0 kgf-m, 51 ft-lb) in alphabetical sequence again.
(4) Back off all bolts by 180 first; back them off by 180 again in reverse order of installation.
(5) Tighten all bolts to 49 Nm (5.0 kgf-m, 36 ft-lb) in alphabetical sequence.
(6) Tighten all bolts 80 to 90 in alphabetical sequence.
(7) Tighten all bolts by 40 to 45 in alphabetical sequence again.
NOTE:
Do not tighten the bolts by more than 45.
(8) Further tighten all bolts (A) and (B) by 40 to 45.
NOTE:
Ensure that the total “re-tightening angle” in the previous two steps do not exceed 90.
Old 10-11-2007, 11:43 AM   #3
kleen
Member#: 69959
02 WRB Impreza WRX
03 Dodge SRT-4
Actually, that might have been my fault when I typed the steps. This is the page that I went by:
Old 10-11-2007, 12:01 PM   #4
MasterKwan
Member#: 98961
2003 WRX
You need the next page too... Yeah, I just checked, you missed a page.
Head bolt question PSolbergfan Built Motor Discussion 14 11-23-2009 03:50 PM
Stupid cylinder head bolt question - 14mm x 12-point socket? root Built Motor Discussion 3 07-03-2007 07:56 PM
question about 02 wrx head bolts Subynut Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 01-30-2007 11:29 PM
head bolt question?? Pacobeagle Subaru Conversions 2 01-28-2006 04:14 AM
Head Bolts & Cams Bolts Torque Specs Imprezd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-20-2003 07:30 AM
