Old 10-11-2007, 01:57 PM   #1
nperkins
Member#: 135812
90 Miata
04 Evo Rally Car
Default ARP Head Studs... Are they seated enough??
Im in the middle of reassembling my motor out of my 04 STi (Did Head Gaskets)... On the passenger side, one head stud was fairly difficult to install, and finger tightening all of the studs left them at different heights... I ended up having 4 1/8" from deck height to top of the stud on the passenger side... I didnt feel comfortable going any more as it would have taken alot of force (Took 2 hours of working 1 stud back and forth to get it to that height)...
The drivers side threaded in much easier, and ended up at 3 7/8" from deck to top of stud without much difficulty... Is it okay that I have them 1/4" difference?
There doesnt appear to be any type of cam interference or anything on the passenger side, so I dont see any reason it wont work...
nperkins is offline   Reply With Quote
Old 10-11-2007, 02:06 PM   #2
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
you want to have them seated all the way down. pull the head studs out that haven't bottomed out and run some compressed air into the holes...you might have some water or something down in them.
SloRice is offline   Reply With Quote
Old 10-11-2007, 02:20 PM   #3
wrxzzz
Member#: 137105
You should remove all the studs and chase the threads to clean them out very thourouhgly. Sears sells a thread chasing kit you can use. This is important because if the threads aren't clean then your torque measurements don't mean a thing. Also clean the threads on your studs and put the lubricant the manufacturer calls for on them. Then thread and torque them in the order called for in the service manual.
wrxzzz is offline   Reply With Quote
Old 10-12-2007, 06:23 AM   #4
Legacy_H6TT
Member#: 137502
1990 Legacy GT-t
Blue over silver
2nd that. Make sure your threads are spotless. ARP actually give the correct torque figures with the studs, so make sure you follow them, it will be the one for 10mm studs... If you don't have any of the lube that comes with the studs, thin engine oil is ok to use.
Legacy_H6TT is offline   Reply With Quote
Old 10-13-2007, 09:08 AM   #5
crashtke
Member#: 120912
Might find this thread of interest...http://wrxatlanta.com/forums/showthr...t=15209&page=2
It is a little discussion on ARP studs.
crashtke is offline   Reply With Quote
ARP head studs V's OEM sti head bolts bugeyes Built Motor Discussion 88 04-24-2016 06:40 PM
Are ARP head studs a need? BlackFighter Built Motor Discussion 17 11-29-2009 02:10 PM
ARP head studs. Are they drop ins? modaddict Built Motor Discussion 28 05-04-2009 11:10 PM
***Innovative Tuning crate engines, head work, NEW ARP Head Stud Kits, and MORE!!!*** Innovative Tuning Engine/Power/Exhaust 17 07-22-2008 03:33 PM
head porting and arp head studs..... ejsportcom Built Motor Discussion 6 03-24-2006 12:05 PM
