Old 10-11-2007, 05:29 PM   #1
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
Default sunroof drainage, leakage problemo - BG
Does anyone else have the problem of dampness around the two front pillars of the car (at the top)? I don't want to get a moldy headliner.
My BG wagon with the sunroof has dampness in this area and I want to try to fix it. My brother told me that the moonroof drains through the A and B pillar and that the drains might be clogged. Has anyone else seen this?
any info would be appreciated.
thx.
-sf
monovich is offline   Reply With Quote
Old 10-11-2007, 05:40 PM   #2
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
Yeah, my drains were clogged and it caused the rainwater to get backedup inside of the car. If you open the sunroof all the way and look facing the hood, you'll see there are two small circles on each end of the sunroof opening inside. What I did was get my air compressor air nozzle and blow them out a few times. That worked no problem, and it was a very easy fix.
runninstrong is offline   Reply With Quote
Old 10-11-2007, 06:01 PM   #3
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
perfect! thanks! will try that.
Old 10-12-2007, 10:49 AM   #4
linsavy
Member#: 11620
1997 GF4-STiV3 clone
The hoses could be off the nipples on the otherside of those drains. You would have to take down the A piller trim to check for that. Blasting air or a wire down the drain may knock them off too.
The hose being off was the problem on mine.
linsavy is offline   Reply With Quote
Old 10-13-2007, 03:33 AM   #5
CRAZY KEN
Member#: 1176
2012 MB E550 4M
2015 P85D
Default a few possible reasons for your problems...
...on my car my moonroof visor had a couple of clips that caused a slight opening for rain water or car wash water to come in. I removed it IMMEDIATELY!!!
...the rubber aroung the moonroof dries up and looses its ability to seal properly...replace it!
...lastly the draining tube on the front left and right side of the moonroof...get a compressor with an extension and blast the shiatzu out of it...lots of stuff will come out...pour water down and compress again...repeat until water is clear...
...oh yeah lube/grease your tracks while you are there!
CRAZY KEN
CRAZY KEN is offline   Reply With Quote
Old 10-21-2007, 09:43 PM   #6
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
1. I blasted my drain lines out today, so we'll see if that helps. where does the other side come out so I can see if they are draining?
2. Taking the a-pillar apart... I'll look into that. Whenever I take trim off I break the clips. Does anyone know where to get new clips that hold the trim together? I've probably busted at least 15 and parts of my car just rattle and dangle. It's sad.
3. I pulled up my rubber foot mats, and to my surprise there was a LOT of water in the foot well, it wasn't quite a puddle but it was absolutely drenched. I haven't spilled anything down there. Could the moonroof hoses be detached and leaking down into the foot well? I need to nip this one because it will cause rot or rust.
4. A bit OT, but does anyone know where to refill the rear wiper fluid? I CAN'T FIND IT. AHHHH. I looked in the manual, but there is only a diagram for the sedan.
5. CRAZY KEN - where you you get new rubber for the moon roof? While I'm at it, does anyone know where to get new rubber for the door surrounds where the window seals? Mine are getting a bit tattered and foamy, and road wind is getting though
thanks all! Gotta keep the old mule clicking along...
Old 10-22-2007, 06:26 AM   #7
JoKerNZ
Member#: 140342
1998 Legacy GTB JDM
your washer bottle has 2 pumps on it & feed rear from front
new rubber: just pick up a 2nd hand roof from wrecker (they com with glass attached)
JoKerNZ is offline   Reply With Quote
Old 10-23-2007, 03:12 AM   #8
subydude13
Member#: 134858
1995 legacy
wintergreen met
like every one else my mine did that so i cleaned out my drains and that worked
subydude13 is offline   Reply With Quote
Old 10-23-2007, 05:11 AM   #9
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
they drain out into the wheel wells, to the rear of the tire, about shin height. You have to pull back the fender liner to see it. Obvious once you do. And the water could be running down the pillar, on the inside of the car, between the plastic and the frame, and ending up there. I'm not going to explain why I know this can happen, but it does and can.
Good luck,
Jared
gtwagon941 is offline   Reply With Quote
Old 10-23-2007, 01:45 PM   #10
monovich
Member#: 8124
1998 Old Grey Mule
Regacy Rype R
thanks guys. I just got the carpet dry yesterday, so I'll pry the a-pillar off today and see if the hose is attached or not.
OT Handymen: Help me figure this out- roof and deck drainage issue (MSPAINT inside) beachbum Off-Topic 44 05-08-2006 02:53 PM
Clip for the A/C drainage line near Down pipe... jay25RS Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 06-09-2005 03:05 PM
bc/bf sunroof vs bd/bg sunroof legacy2003 Legacy Forum 4 08-12-2003 01:32 AM
leaking/drainage fluid from hose? talefish Newbies & FAQs 1 11-03-2001 02:29 AM
transmission drainage reqd for clutch install? efoo Technical Forum Archive 2 08-04-2000 10:51 PM
