Old 10-11-2007, 07:38 PM   #1
Spitulski
Member#: 111667
2002 Impreza 2.5RS
Platinum Silver Metallic
Default High Flow vs. OEM fuel pump?
Kind of a spin-off from the car won't start thread - problem's been diagnosed as an intermittently crappy fuel pump that needs to be replaced.
I have an 02 2.5RS, which - from what I can find - has a 190 Liter per hour fuel pump as OEM equipment. An OEM replacement, at best, appears to be $300 or so. A Walbro 255LPH replacement is under $100, making it the most cost effective replacement I can find.
Question - are there any ill side-effects if I upgrade to 255LPH on what is basically a bone-stock engine with an aftermarket exhaust system? I've read that the FI system that Subaru uses will only run the fuel pump for the amount of fuel needed, and that the extra LPH will basically never be used and will not affect engine performance...I'd like to verify that before going ahead with the installation.
Thanks!
Spit
Spitulski is offline   Reply With Quote
Old 10-11-2007, 07:59 PM   #2
mattwalters
Member#: 422
1998 Legacy 2.5GT
Rio Red
Consider it verified. The extra flow will be bled off by the FPR at the end of the fuel rail and sent back to the fuel tank. Le voila!
-Matt
mattwalters is offline   Reply With Quote
Old 10-12-2007, 12:25 AM   #3
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
The only downside is that you're pumping more fuel through the system that you need and thus recirculating more than you would with the stock pump, so theoretically the fuel will be warmer. Warmer fuel = less dense = less energy being injected with each pulse of the injectors.
Would you ever notice the difference? Almost certainly not.
As for replacement pumps, does Walbro not make a 190 for these cars? I know for my trusty ole 5.0 Mustang the stocker was an 88, and one could buy 110, 155, 190, and 255lph pumps from Walbro that were all direct replacements for the stock pump.
Patrick Olsen is online now   Reply With Quote
Old 10-12-2007, 01:33 AM   #4
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
Why not buy a used WRX pump on the forums here for like $40 or so? It's a direct drop-in.
PhilSine is offline   Reply With Quote
Old 10-12-2007, 11:31 AM   #5
Spitulski
Member#: 111667
2002 Impreza 2.5RS
Thank you all for the information...I might do that Philsile, if I can find one that I can pay for. I don't have, nor do I intend to sign up for, Paypal...thus why I started looking at vendor availabilities first.
Cheers,
Spit
2009 STI Fuel Rails, 2002 OEM Fuel Pump Assembly, Uppipe w/ Cat Alex_Kors Engine/Power/Exhaust 5 04-18-2010 01:49 AM
FS Perrin Fuel Rails, Short Ram, Blues, Walbro, OEM Fuel Pump, Cat back rotorhead24 Engine/Power/Exhaust 19 09-11-2009 02:40 PM
Cobb high flow vs. cattless nineleft Newbies & FAQs 33 11-10-2006 12:48 PM
STi fuel pump vs. WRX fuel pump WRXVII Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-02-2005 08:05 PM
