Old 01-17-2002, 11:03 AM   #1
WR-REX
Member#: 5250
2007 Tundra RCSB 5.7
Default Anyone done the stock column gauge housing and and omori 43 mm gauge?
WR-REX is offline   Reply With Quote
Old 01-17-2002, 11:36 AM   #2
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Me. Although, not column mounted....
The Omoris are actually 45mm. Different to the stock size. I bought the Omori DIN panel too, and I'm well pleased with the results. They match the OEM gauges very well.
I got mine through the Malaysian dealer. $200 cheaper. The service was excellent.
Scoob.
Scoob is offline   Reply With Quote
Old 01-17-2002, 11:58 AM   #3
WR-REX
Member#: 5250
pics?
Old 01-17-2002, 12:41 PM   #4
wrx182
Member#: 9531
2002 WRX Sport Wagon
I just got my Omori 52mm boost gauge today and my VDO pod...I'll be mounting it on the steering column tonight and will take pics for all....I'm going to do a bomb ass job on it too - it's going to look excellent!
wrx182 is offline   Reply With Quote
Old 01-17-2002, 01:21 PM   #5
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
This isn't of my car, but they're the same.... This picture's been posted a few times now.
Scoob.
Old 01-17-2002, 04:34 PM   #6
BlueWRX
Member#: 7898
2008 g37s
does omori make single DIN sized panel? How much was it? and how many gauges can you fit in there? i'm looking to add 2 more gauges for egt and something else... Also how was the fitment?
thanks
-James
BlueWRX is offline   Reply With Quote
Old 01-17-2002, 04:39 PM   #7
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
Yes, the one pictured is from Omori, part number P-107. It's designed for their line of 45mm gauges though. Can't remember the individual price, but you can check it out here.
Fitment was reasonable. By that I mean that the opening was just a tad small in the OEM hood. I got around this by turning the brackets around on the DIN panel. Hard to explain really unless you've seen the components you get with the DIN panel.
Scoob.
Old 01-18-2002, 02:43 AM   #8
wylie
Member#: 7387
02 wrx wagon
blue
Scoob-
Did you get the mechanical or electrical boost gauges? What are the pros and cons of each anyway? Did they come with decent instructions?
wylie is offline   Reply With Quote
Old 01-18-2002, 09:28 PM   #9
Scoob
Member#: 6204
2002 WRX Sedan
WR Blue
I got mechanical boost. There are instructions, but not specific to our car. It was easy to install. There's lots of good info on this board for install. Just search gauge AND install and you should turn up the threads I found to be most useful.
There's a connector behind the radio that you can connect into to get dimming illumination. In one of the threads, there's another link for the factory boost gauge installation.
As far as electronic or mechanical, there is a different opinion from whoever you ask. Ultimately, I don't think the differences are worth forking out all that extra cash for on the electronic. Obviously, the EGT and Temp gauges are all electronic, and the price shows it. All in all, I'm quite pleased with the overall set up. Anybody who gets in the car comments on how nice they look. I think they're tons better than the OEM gauges!
Hope this was of help.
Scoob.
Old 01-19-2002, 02:15 AM   #10
wylie
Member#: 7387
02 wrx wagon
blue
Thanks, Scoob.
I like the fact the Omori gauges match the dash gauges and the boost gauge is in psi and not bar.
Omori 52 mm gauges (boost and EGT) and autometer guage pod Bman Interior/Dressup/Audio & Security 22 06-07-2010 02:57 PM
two 52mm gauges and a center 60 mm gauge? pics? Uber-Charged Interior & Exterior Modification 9 12-23-2007 06:51 PM
almost done changing interior lighting, has anyone done the power window switch? Tobey Electrical & Lighting 24 08-25-2004 04:11 PM
Has anyone done the TXS Unichip resistor mod in the Bay Area? hkwan Bay Area Impreza Club Forum -- BAIC 1 03-18-2002 09:12 PM
Anyone rotate the stock turbo housing? Rovah Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 03-05-2002 08:01 AM
