Old 10-12-2007, 12:12 AM   #1
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
Default How do you replace the parking light switch?
I found out that I fried my parking light switch(Long Story). I was wondering if it is necessary to take the steering wheel off because it looked that way when I took apart the plastics around the steering column.
Bobert540 is offline   Reply With Quote
Old 10-12-2007, 10:45 AM   #2
Cougar4
Member#: 53443
2001 LL Bean Outback
Winestone
Before you get into that are you sure that the switch itself is bad. Normally other things go bad with the circuit unless the switch has been damaged due to excessive current running through it or physical damage has occured.
Old 10-14-2007, 10:09 PM   #3
Bobert540
Member#: 82281
2013 WRX Ltd. Hatch
it is def. the switch we used a multi meter to problem solve it.
How do you replace the clockspring on a 04 sti? wantsti Interior & Exterior Modification 7 09-24-2009 09:35 AM
How do you replace the glass in a broken side mirror? stephan Interior & Exterior Modification 5 04-14-2006 01:26 AM
04 REX how do you change the fog lights? kitbar Interior & Exterior Modification 2 04-12-2004 11:38 PM
How do you make the trunk light sound the alarm? RSarte Car Audio, Video & Security 1 08-30-2002 08:51 PM
how do you remove the fog light grilles? FormerSubTech Forester Forum 9 01-29-2002 07:15 AM
