Welcome to the North American Subaru Impreza Owners Club Sunday September 21, 2014
South West Impreza Club
Go Back   NASIOC > NASIOC Chapters > South West Impreza Club Forum -- SWIC
Old 10-12-2007, 12:14 AM   #1
dunc_b
Member#: 154343
Default rattle noise as boost comes on
Does anyone else have a slightly annoying rattle (turbo heat sheild?) at around 3k to 4k when accelerating? wanted to ask before I mention it to dealer at next oil change...
dunc_b is offline   Reply With Quote
Old 10-12-2007, 12:51 AM   #2
r0bman
Member#: 87015
What year / car? Fill out your profile a bit and help us out
... if it's an '07 STi... you need to talk to Travis. And stay off of WOT until you do.
r0bman is offline   Reply With Quote
Old 10-12-2007, 01:57 AM   #3
sunnyniazi
Member#: 136438
RIP: 2004 WRX STi
WRB/G, 322whp/330wtq
Yeah heat shield will do that or if you have a heat shield for your intake, when I had a heat shield for my intake (K&N typhoon) it made that rattling sound I tightened up the bolts and it went away, is your boost affected?
sunnyniazi is offline   Reply With Quote
Old 10-12-2007, 11:16 AM   #4
boostedsti06
Member#: 128677
2006 Subaru WRX STI
obsidian black pearl
this happened to me after i got my downpipe put on cause they cut the stock heat shield so there werent as many mounting points. that was part of it and the o2 sensor wasnt screwed in all the way either
boostedsti06 is offline   Reply With Quote
Old 10-12-2007, 12:50 PM   #5
dunc_b
Member#: 154343
It's an 06 stock STI, boost doesn't seem to be effected - it's juddered a tiny bit once or twice but that was when it was extremely hot outside too...
Old 10-12-2007, 12:57 PM   #6
r0bman
Member#: 87015
OK, if it's an '06 then my previous comment is void. Does it happen no matter what at that engine speed (i.e. doesn't matter if you're flooring it or not, etc)? If so, then you've got a loose heat shield... there's only, oh, about 4 of 'em... good luck figuring out which one it is
If you're in the West Valley, you can swing by my place this weekend and we'll put it up on ramps (as long as it's not lowered) and I'll try to tighten them all down for you.
... And don't take your car to the dealer for an oil change It's the easiest thing in the world, takes all of 30 minutes (and 25 of that is waiting for the oil to drain).
Old 10-12-2007, 12:57 PM   #7
02WRX06STI
Member#: 115023
2006 STI
possible detnation????
cuz i also had this problem, and took it in they told me it was my splash shield, even though it did it only when it was hot out. i would say try mixing gas to get at least a 93 octane rating, that is what i did and it stopped till i filled up with 91 again...
02WRX06STI is offline   Reply With Quote
Old 10-12-2007, 12:59 PM   #8
r0bman
Member#: 87015
That's where I was going with my first post... could still possibly be it, but not having the lovely '07 ECU tune is a plus in his case.
Old 10-12-2007, 01:01 PM   #9
dunc_b
Member#: 154343
It only does it under boost/with my foot down - it used to be sporadically but now it's all the time I'm flooring it...
it could be some turbo system component I'm not used to hearing...
Old 10-12-2007, 01:03 PM   #10
r0bman
Member#: 87015
... uh oh. If you're only hearing it at WOT then it could possibly be detonation. Your car is completely stock?
Old 10-12-2007, 01:05 PM   #11
dunc_b
Member#: 154343
Yeap... What WOT?
Old 10-12-2007, 01:07 PM   #12
r0bman
Member#: 87015
WOT = Wide Open Throttle. Gas pedal floored.
Old 10-12-2007, 01:10 PM   #13
dunc_b
Member#: 154343
d'uh... it does sound like something is literally rattling loose between 3k & 4k then it goes away... I'll get the girl to rev it up this weekend and see if it does it when the hood's open...
Old 10-12-2007, 01:11 PM   #14
dunc_b
Member#: 154343
I'm in north central phoenix - Where are you on the west side robman?
Old 10-12-2007, 01:15 PM   #15
r0bman
Member#: 87015
If it does it w/ the hood open, then I'd say its a heat shield. You're not going to get detonation in Neutral without boost building unless there is something really wrong.
I'm in Goodyear, right off the 10. Let me know if you need any help this weekend, I'll be around.
Old 10-12-2007, 01:30 PM   #16
dunc_b
Member#: 154343
are you near avondale subaru?
Old 10-12-2007, 01:32 PM   #17
r0bman
Member#: 87015
5 Exits past it, yeah.
Old 10-12-2007, 01:34 PM   #18
dunc_b
Member#: 154343
are you in the dealer then Rob? What do you do there?
Old 10-12-2007, 01:35 PM   #19
dunc_b
Member#: 154343
I might have my boy this weekend but if I can swing by I will...
d
Old 10-12-2007, 01:39 PM   #20
r0bman
Member#: 87015
Haha, no, I don't work there... I just have a garage, and $40 walmart ramps, and hundreds of hours of experience working on turbocharged Subaru exhausts I'm no expert, but it doesn't take much to figure out a heat shield, IF that's your problem.
Old 10-12-2007, 03:40 PM   #21
gormonk
Member#: 98960
1978 brat (fo realz)
red
shoot me a pm and ill see if i can hook ya up
gormonk is offline   Reply With Quote
Rattle noise under boost... 4S-TURBO Factory 2.5L Turbo Powertrain 8 05-24-2007 02:03 PM
rattling noise when boosting WOT generalganja Newbies & FAQs 6 04-23-2007 09:12 PM
Boost coming on late, found bad upppipe gasket roybfr Factory 2.5L Turbo Powertrain 3 07-26-2006 12:11 AM
Boost coming on late? Mzacharski Factory 2.5L Turbo Powertrain 7 11-13-2005 08:28 PM
What's wrong? Boost coming on late. wrxlvr Factory 2.0L Turbo Powertrain 2 06-18-2003 01:57 PM
