Old 10-12-2007, 02:06 AM   #1
suby_will
Member#: 131816
Default injector duty cycle high on stage 2?
I took some data logs of my Stage 2 WRX a few days ago and I cant figure out why my injector duty cycle is at 92%. I'm running a basic stage 2 map from OSEcu roms.
Is there a certain reason why it would be so high? I'm a newb to Subarus (only had mine for 1 year) and extremely new to tuning and data logging.
Any help/constructive comments are welcome and appreciated.
suby_will is offline   Reply With Quote
Old 10-12-2007, 07:04 AM   #2
dynamix
Member#: 122603
It is purely because the std injectors are too small. Either bigger or modded injectors will give you more headroom.
dynamix is offline   Reply With Quote
Old 10-14-2007, 06:38 PM   #3
Murf_68
Member#: 71191
2005 WRX Wagon
Platinum Silver Metallic
I logged some WOT runs in my stock 2005 and saw 93% injector duty cycle briefly. I'm about to go to stage 2 and I'm interested to see what happens!
Mark
Murf_68 is offline   Reply With Quote
Old 10-15-2007, 01:13 AM   #4
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I just got finished logging a few WOT runs and my max injector duty cycle only hit about 85. I have stock injectors running 16 PSI. The map is my own custom stage 2 map though. Your numbers seem high, but not that high, maybe 5-10%. Are you using the XPT Map or the one free from the forums?
/Brox
Broxma is offline   Reply With Quote
Old 10-15-2007, 02:27 AM   #5
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
keep in mind a pro-tuned or a tuned stg 2 will have lower overall IDC's because you are leaning out the Air/Fuel ratio on the top where it's overly rich from the factory.
Jeremy
Old 10-15-2007, 04:28 PM   #6
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
I agree with the above post in alot of cases, but I still think IDC over 90 is alot, even on a stock fuel map.
On my map I didn't drop the fuel all that much for safety sake. My EGT's, which is how I tune mostly, are pretty low even at WOT which means I do have alot of headroom to work with. My fuel map is not as dialed in as I would like, but it is still in its first revision and I can't complain. As I get more seat time and dyno time and with the addition of my WB02 I'll dial them in alot better.
/Brox
Old 10-17-2007, 01:29 AM   #7
suby_will
Member#: 131816
Right now I'm on the free map. But I have the XPT stage 2 on my computer.
Old 10-17-2007, 01:35 AM   #8
Prevent
Member#: 149114
iirc you don't want your injectors to be more then 80% duty cycle "cruising"
Prevent is offline   Reply With Quote
Old 10-17-2007, 01:47 AM   #9
krambte79
Member#: 97452
05 STi, 02 STi
& 09Ltd Tribeca
i agree w/ the above statement but keep in mind guys when you are full throttle running a protune stage two (speaking for STi's) you will see high 90's in the duty cycle. unless of course you have larger injectors. the nice thing is adding meth to a stage 2 STi then you can run full throttle in the low 80's for your duty cycle.
krambte79 is offline   Reply With Quote
Old 10-17-2007, 03:15 AM   #10
Broxma
Member#: 158006
2003 WRX IdleWagon
1992 GVR4 379/1000
Kram has it right in the high 90's for the STI for sure.
I flashed a Stage 2 map on an 04 STI the other night and the IDC maxed out at about 93. I was watching the logs but from what I saw the driver was WOT through 2nd, 3rd, and 4th, and the IDC does get pretty high. I was a bit concerned about it, so I checked the Base fuel map of the stock ROM and compared it to the Stage 2 one and the difference was pretty slight, so I figured that it was meant to be.
I know that Honda's run a very high IDC from the factory with not alot of overhead. I suppose it's possible Subaru gave at least a few models the bare minimum as far as overhead on the IDC as well.
/Brox
Old 10-17-2007, 04:06 AM   #11
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
umm, if your IDC is running 80% at cruise you've got problems.
Normally you don't want to design a fuel system to run your injectors past 85% although it's been shown that Subaru injectors don't fail at 85% infact it's been shown that the stock ECU displays 100%+ IDC's while still being able to increase the duty cycle further
Old 10-17-2007, 04:26 AM   #12
dynamix
Member#: 122603
Mine was getting 103% on stage 2 tune. Ideally you dont want to run over 90% so I added a fuel pressure regulator and ran increased fuel pressure.
This worked for a while (until the turbo boost was upped)
Now I have larger injectors and loads fo headroom.
Old 10-29-2007, 07:26 PM   #13
jhargis
Member#: 110304
2004 Volvo S60R
No more Subie
I got it right up to 99% IDC @ 16 psi, but I prefer leaving the fueling stock, which is pretty rich... It gets hot here, so leaving it a little richer than the normal staged tune gives me some knock safety when it's 110 degrees out in the summer. But yeah, IDCs in the high 90s on the '02 stock injectors with added boost is not at all unusual. Now with 625cc injectors I set a high of 62%.
jhargis is offline   Reply With Quote
Old 11-07-2007, 11:42 PM   #14
controler
Member#: 100271
What FPR did you use? How hard to install and was it worthwild over injectors or a fuel pump?
I just hit 101% tonight on my 03 wrx, stage 2. With just 16.5 psi and ~48 degrees F. I am not confident I will go past stage 2 with this car, so which would be more cost-effective for getting ~15% more headroom - injectors, FPR or fuel pump?
Also, I am on the OSECUROMs stage 2 R10 fueling, with a little more advanced timing and boost.
controler is offline   Reply With Quote
Old 11-07-2007, 11:53 PM   #15
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
I am running the same map, with an ebay topmount, up-pipe, and highflow catted DP, and my IDC are at 91% in a 3rd gear pull.
illmatic is online now   Reply With Quote
Old 11-08-2007, 04:56 PM   #16
gabedude
Member#: 10108
07 STI
60Trim spun rod bearing
LOL! The stock 07 STI injectors run in the 90's on a good day on the stock map. Low altitude, low temps they go into the 105+ range and start to lean out on the stock mapping (boom!). 100% is ok, above that you are in dangerzone.
gabedude is offline   Reply With Quote
Old 11-08-2007, 11:57 PM   #17
joe-6STi
Member#: 141590
2010 Silverado
2007 CRF250R
That makes me feel a bit better Gabe - Still loving the tune, but I have been logging mine alot lately - and have seen up to 96.5x IDC ! I am going to proabably go to a bit bigger injector after christmas...
joe-6STi is offline   Reply With Quote
Old 11-09-2007, 06:29 AM   #18
dynamix
Member#: 122603
I fitted a FuelLabs FPR running at 3.8 bar static pressure (with vacuum hose disconnected and Walbro 255 pump). It gave an extra 15% IDC and helps atomisation of the fuel for a better burn.
Old 11-15-2007, 01:08 AM   #19
reddoak
Member#: 147628
2014 Fiat Abarth 500
Rosso
Like Gabe said, I saw IDC% of 105+ on the stock tune, and Gabe's Stage 0 during the summer here. Scary stuff... With a catted DP and stage 2, I dropped into the 90's WOT. If I were running stock on any 07 STI, I'd take it easy in the hot and swampy weather. When summer comes around again (like in mid-April here) I'll start logging regularly in the heat to keep an eye on things.
To the OP, IMHO 92% isn't too much to fuss about. Keep an eye on it, your a ways away from running unintentionally lean.
reddoak is offline   Reply With Quote
Old 11-15-2007, 09:50 AM   #20
scraggy
Member#: 136384
06 WRX
Dipped with custom blend
Whats your AFR? If you are running really rich, your IDC will be higher than if you were running a better AFR. IF you are in the 11.2-11.8 range, and your IDCs are in the high 90's then you should prob look into getting injectors. If your AFRs are in the low 10's, and IDC is in the high 90's, then get a better tune and they will drop.
scraggy is offline   Reply With Quote
Old 11-15-2007, 12:07 PM   #21
MasterKwan
Member#: 98961
2003 WRX
Yeah I'm thinking about pulling back my mixture to 10-10.5's from 9.5. I notice the JDM WRX ECU's are all leaner for the same cell's in the fueling table.
Old 11-18-2007, 06:11 PM   #22
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
check the injector size in the rom file..
Old 11-19-2007, 10:33 AM   #23
gabedude
Member#: 10108
07 STI
You have to watch it when it is cold out as well.
high injector duty cycle on stage 2? suby_will Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-12-2007 02:02 AM
Injector Duty Cycle - TXS Stage 2 InfamousDX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-11-2004 10:23 AM
maximum injector duty cycle on stock injectors? inpreza kid Normally Aspirated with bolt-on Forced Induction Powertrain 5 09-17-2003 03:10 AM
Stage 3 Injector Duty Cycle Confusion Wrxified Engine Management & Tuning 2 03-08-2003 08:05 PM
Does obd-2 software read injector duty cycle snookem Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-12-2002 01:11 PM
