Old 10-12-2007, 02:44 AM   #1
kirkeemonster
Member#: 113721
WRBP
Have a Nice Day? power steering??? ebrake and batt. light on! whats going on? :(
Well, as im coming home from BK Im just cruisin, normal speed, cc on. All of a sudden i hear a loud whining/whisteling like my intake is just sucking everytime i give gas. anyways I look down at my cluster and see that my batt. light and ebrake light is on..... im like, oh **** wtf... and then as I turn around the corner, i try to turn, and its stiff as ****, im like, wtffff no power steering ftl and so i pull over, turn my car off, wait, and turn it on to see if it could reset itself or w/e, turn it on and see that the lights are still on..... sooo just go all the way home basically... my tranny is feelin a little wierd coming home, and my clutch grab is pretty sooner than normal, What is this problem?? It's night time but tomorrow im going to check my motor, but can anyone find this source? thanks in advance!!
kirkeemonster is offline   Reply With Quote
Old 10-12-2007, 02:58 AM   #2
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
your alternator belt broke.
z is offline   Reply With Quote
Old 10-12-2007, 03:24 AM   #3
kirkeemonster
Member#: 113721
WRBP
Oh and might I add before this happened, my belts were squeeking for about a week, and the oil change dude said I needed to replace my wheel bearing in a few more thousand miles, but since then I've only gone about 500mi....
Old 10-12-2007, 11:19 AM   #4
chewbakarox
Member#: 25478
2003 WRX Sport Wagon
Yeah, definitely sounds like a belt problem. I doubt that the belt completely "broke", but it's either shredding or loose. I would check the belt tension and see what kind of shape the belt is in.
From my past experience, my battery and e-brake lights turned on when my alternator wasn't providing any charge to the system (odd how the e-brake light comes on, huh?). So it sounds to me like your alternator belt is slipping to the extent that the alternator pulley isn't turning enough to provide a charge to the car.
chewbakarox is offline   Reply With Quote
Old 10-12-2007, 11:22 AM   #5
chewbakarox
Member#: 25478
Oh, one more thing. I wouldn't drive the car around for very much longer without taking care of this. With the battery/e-brake lights on, it means your car is running on the battery only with little to ZERO alternator charge. Pretty soon you'll have a dead batt - no fun when you're driving and everything goes haywire (and then dies).
Old 10-12-2007, 11:43 AM   #6
z
Member#: 41762
04 STi
^ same belt turns the power steering pump
Old 10-12-2007, 11:46 AM   #7
rkramer
Member#: 118209
2015 WRX Limitec
not to mention the engine itself won't run without battery power... no power = no fuel pump or injectors
Old 10-12-2007, 12:55 PM   #8
kirkeemonster
Member#: 113721
WRBP
So just needa replace both belts? Part # plz.
Old 10-12-2007, 01:26 PM   #9
z
Member#: 41762
04 STi
did you check the belt? is it even there? (alternator belt is the one that goes from the main pulley to the left, the other is your AC belt)
Old 10-12-2007, 01:28 PM   #10
kirkeemonster
Member#: 113721
WRBP
alright let me go see what actually went wrong... since it's morning, i'll go take pics as well.
Old 10-12-2007, 02:02 PM   #11
kirkeemonster
Member#: 113721
WRBP
hahaha had to break my ****ing belt cover off because both screws were seriously like stuck, prolly stupid ass stealership used lock tight or some ****. But anyways yeah, one of the belts is.... shredded/gone LOL, pics as follows.
Old 10-12-2007, 02:21 PM   #12
z
Member#: 41762
04 STi
^ easy as pie to fix. Same happened to me over the summer.
It's funny, mine exhibited the same symptoms right as i was pulling into my place after a 4 hour drive...I would have been f'd if it broke on the NJ turnpike because it was past midnight.
It was the last turn into the driveway that all of a sudden, the power steering went out and I almost hit the curb.
Old 10-12-2007, 02:26 PM   #13
kirkeemonster
Member#: 113721
WRBP
yeah I just watched the tutorial video from HSPN website and it seems like a 10 minute job.... LOL, so should I just replace both belts? Or just the alternator belt? if thats the one thats broke? Are these $$$$$ or can be bought both under 50 bucks?
Old 10-12-2007, 02:30 PM   #14
chewbakarox
Member#: 25478
Might as well replace both - both of the belts are pretty inexpensive and you might as well change the other belt while the P/S/alternator belt is off. It's super easy....
Old 10-12-2007, 02:38 PM   #15
kirkeemonster
Member#: 113721
WRBP
ok so when looking for the belts am i looking for alternator belt and ac belt?
Old 10-12-2007, 02:41 PM   #16
z
Member#: 41762
04 STi
yup alternator belt is what broke... should be around $16-17 from the dealer.
If you feel like it, do the AC (although it's not something that is critical and will leave you stranded if it breaks) about $16 also.
fwiw, I almost bought a pep boys special and it was a couple bucks more than the dealer.
Old 10-12-2007, 04:28 PM   #17
kirkeemonster
Member#: 113721
WRBP
Thanks for all the replies and I went down to the dealership, $32 bucks later and both belts are replaced, and all I have to say is.... so far the squeeking is GONE, car is WAAAAY smooooother, and for some reason I hit peak boost a lot... easier, I didn't know how tight to tighten the belts down but I have them pretty snug, im bringin my 12mm socket wrench with me just in case....
edit: I forgot to check if this solved my AC problem as well, squeeky belt when AC is on, clutch is 3x stiffer when AC is on... It's cold here that's why I didn't check, but next time I go outside i'll be sure to play with the AC to see whats up :P
Old 10-12-2007, 04:44 PM   #18
z
Member#: 41762
04 STi
good deal...not too snug or you'll put too much stress on the bearings.
The belt should deflect about 5mm or so when you push on the center of the span.
Old 10-12-2007, 05:38 PM   #19
chewbakarox
Member#: 25478
Good to hear you solved everything. Glad we could be of assistance!
Old 11-04-2007, 04:25 PM   #20
fastwrx
Member#: 7398
2004 2004 WRX-STi
Same thing just happened to me (about 1 hour ago). Had the car towed to my house. Oddly, enough, the SAME belt broke on me about 1 year ago. I would think a belt would last longer than that. I checked to see if any of the pulleys were seized. All turn freely. Last time I had it towed to the dealer. This time I'm doing it myself. Very easy job.
Man, that steering gets HEAVY without power assist!
Mike
fastwrx is offline   Reply With Quote
power steering failure AND 3 lights that don't go away mannyOlicious Newbies & FAQs 3 04-12-2011 06:20 PM
WTB: 2004 subaru TS AC Condensor, Power Steering Pump & Fog Lights. themadeguy Private 'Wanted' Classifieds 2 10-20-2009 08:33 PM
Stiff Steering fixes itself... Whats going on? vica153 Service & Maintenance 7 10-29-2008 03:09 PM
Blew a fuse. Now ABS, Ebrake, and CE light are on? drapes Electrical & Lighting 0 01-20-2008 09:12 PM
First log, let me know what you think and whats going on. wrxracer519 Open Source Reflashes 5 01-09-2008 01:51 PM
