Go Back   NASIOC > NASIOC Chapters > New England Impreza Club Forum -- NESIC
Old 01-17-2002, 11:38 AM   #1
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
Default Anyone need to buy a computer power supply?
I posted in classified, and getting no love...so I thought about how many computer geeks we had, and figured I'd post a link.
http://www.i-club.com/forums/showthr...eferrerid=1904
ps. please don't shoot me
JGard is offline   Reply With Quote
Old 01-17-2002, 12:01 PM   #2
sorbee711
Member#: 14259
OT, we're a-holes
b/c we are bored at work
Smile
Ahhh, if I hadn't just built myself a new one I would have been...
(built a new computer, not power supply)
sorbee711 is offline   Reply With Quote
Old 01-17-2002, 12:03 PM   #3
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
How much would you take for it? Mine is making some funny noises
-tim
TimStevens is offline   Reply With Quote
Old 01-17-2002, 12:06 PM   #4
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
hmm...since I'd have to ship it to you...I'm thinking $25.
that sound fair enough?
Old 01-17-2002, 12:18 PM   #5
TimStevens
Member#: 4817
2012 STI, '02 WRX
Hmm... maybe. We'll see if it's still making a funny noise when I get home tonight
-tim
Old 01-17-2002, 12:22 PM   #6
Wheels
Member#: 5410
2008 BMW 335XI
-tim
Hey why not just replace the fan. Cost you about $4
Wheels is offline   Reply With Quote
Old 01-17-2002, 09:36 PM   #7
SoobATV
Member#: 6883
MY04 Foz XS
MY02 Imp TS
I could use one, but I'll probably hold off until I build that AMD 1700 system I want. (Asus A7M motherboard, 512 ddrram, ATI 8500 video card, some sort of sound card ish, and about 10 fans) ahhh.... if only I had the funds
SoobATV is offline   Reply With Quote
Old 01-18-2002, 10:48 AM   #8
TimStevens
Member#: 4817
2012 STI, '02 WRX
Hey man... still might be interested. Just wondering how you can tell it won't be enough for your sytem? 300 watts should be enough for just about anything unless you're running a 5-drive RAID or something.
-tim
Old 01-18-2002, 10:51 AM   #9
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
well, from what I've read, the new high-speed AMD chips require a TON of power to keep running.
I actually tried to turn it on last night, and it did work, though my CD-ROMs were not being seen by the motherboard.
I have also read problems with under-powered AMD boards and chips...and something about the chips burning out quickly that way...so I figure better safe than sorry.
So it should be good enough for most systems...like my last one, which was an AMD 650 with 2 hard drives, and 2 CD-ROMs, this power supply would be quite sufficient.
Yeah, so if you want it, $25 shipped...
Old 01-18-2002, 11:07 AM   #10
Wheels
Member#: 5410
2008 BMW 335XI
Default 300Watt
It will work any athlon on the market. A cpu still uses the same voltage as the 700 athlon. I don`t understand where your getting the crap from about underpowered psu`s burning out the cpus.
Old 01-18-2002, 11:19 AM   #11
Charge
Member#: 3313
The power issue isn't the total wattage. It's the voltage rails. How tightly the power supply can adhere to the 12 or 5 volts it needs to output. An example: Let's says it's pushing 11.9 volts, which would be sufficient. Suddenly, it begins to draw more power. For a split second, the power devlivery drops down to 11.2, before the power supply beefs up the output to bring it bac, to 11.9 again. That causes problems with the AMD chips. The power supply needs to be able to respond quicker, never letting it drop below, say 11.7(these numbers are just examples, not specifics).
It doesn't matter if it's 300 watts or 500 watts, it's how tightly/quickly it can keep the 12 and 5 volts of power going.
Neil
i just felt like making a useless information post
Charge is offline   Reply With Quote
Old 01-18-2002, 11:23 AM   #12
JGard
pooptastic
Member#: 1904
2011 E70 X5 35D
E36 M3/4/5
gotcha.
but the wattage will make a difference in the peripherals, no? seeing as how I have 2 cd's, and will have 2 hdd's soon...
either way, I've already bought the 400W supply...so that's why I'm just going to try to sell the cheaper of the two
Old 01-18-2002, 11:52 AM   #13
Charge
Member#: 3313
Yep. Total wattage would make a difference in the number of accessories you can run. That's why the higher watting have more Molex connectors. However, 300 watts is enough to drive 2 Ultra wide SCSI HD's, 3 IDE HD's, a floppy drive, Ultra Scsi CD-Rom, Scsi CD-Recorder, two fans, dual-processor system for myself. Reason is, not all of those devices are pulling full current all the time. If I was running RAID, they'd be going non-stop, and constantly pulling over 300 Watts, but they probably rarely approach that on a home computer.
However, it doesn't hurt to buy a higher wattage power supply. Also, if it's a good brand it probably will run a little cooler, and we all know heat is normally what destroys electronics.
Neil
CHI West Burbs: Anyone need to buy a laptop? Enquire within kyledooley MWSOC Private Classifieds 1 07-01-2008 08:35 AM
Hello? Yes, I need to buy a computer... WHTWRX Off-Topic 2 01-30-2008 10:11 PM
I need to tap my battery/power supply behind the radio, what color? Gso2k Car Audio, Video & Security 4 12-07-2007 07:23 PM
[ATX] Need 300+ watt computer power supply treybomb Texas Impreza Club Forum -- TXIC 7 12-08-2003 10:29 AM
Wanted: Computer power supply. alexs001 Vancouver Impreza Club Forum -- VIC 4 09-17-2003 06:20 PM
