Old 10-12-2007, 09:20 AM   #1
04subyrex
Member#: 144873
2004 WRX evoIII/meth
66 Mustang 408w
Default Car cranks but wont start up!!
Thanks for all the help and comments. It ended up being the alternator.
So i was getting ready to go home from work the Tuesday evening and got in my car cranked it right up and let it idle for a minute or so when it just goes dead........ I tried to start it up again and no dice. Im thinking that the fuel pump may have gone out on the car because i couldnt hear it on crank but not entirely sure. I got no CELs and it has been running perfect since i got it. But here is the kicker I ordered a new walbro 255 pump and it is taking a couple days to get here so i am letting the car just sit up here in the parking lot till i get it and install it to save a towing fee. but i go out this morning and now my battery is DEAD. no power whatsoever. I cant even use the remote to unlock the car. What could be draining the power like this??? This cant be normal, could it? Could it be something other than the fuel pump in this case??????? Has anyone experience something like this before???
Thanks and all help is appreciated!
04subyrex is offline   Reply With Quote
Old 10-12-2007, 01:05 PM   #2
04subyrex
Member#: 144873
66 Mustang 408w
Anyone have any advice?? electrical possibly??
Old 10-12-2007, 01:10 PM   #3
boostdog
Member#: 149752
2017 wrx
ICE ICE BABY SILVER!
list mods and stereo upgrades please....
also make sure that you interior lights are not on and w/a burnt bulb...I have seen that happen ...open circuit putting a constant draw on the bat.
boostdog is online now   Reply With Quote
Old 10-12-2007, 01:13 PM   #4
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
IB fuel pump or starter
Sausage is offline   Reply With Quote
Old 10-12-2007, 01:19 PM   #5
04subyrex
Member#: 144873
66 Mustang 408w
would a bad fuel pump or starter drain the battery though while the car is off?????
Mods are
stage 2 stock turbo
grounding mod
aps turboback
stock cd changer with aftermarkert alpine speakers just in doors no subs
and thats about it...
Old 10-12-2007, 01:23 PM   #6
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
how long since the grounding mod?
shootinsoobie is offline   Reply With Quote
Old 10-12-2007, 01:40 PM   #7
04subyrex
Member#: 144873
66 Mustang 408w
maybe 3 weeks or so. Its seemed to be running a lot smoother with it. I talked to someone about it and he thought it might be my alternator. It might have gone bad a couple days ago and the battery just finally drained of power??? does this sound right?
Old 10-12-2007, 02:09 PM   #8
shootinsoobie
Member#: 71170
04 JBP
All Murdered Out
honestly, i could be a lot of things but unfortunately guessing at it will not get it fixed. get that new battery, have someone that knows what they are doing look at it and hopefully it can get fixored
Old 10-12-2007, 02:54 PM   #9
JDM555
Member#: 151449
2007 Nissan 350Z
Carbon Silver
Hmm, That's weird. Good Luck fixing it though.
JDM555 is offline   Reply With Quote
Old 10-12-2007, 04:28 PM   #10
04subyrex
Member#: 144873
66 Mustang 408w
The guy told me that with the ecu on new car that if it does not have adequate power (i.e. alternator) then it would have shut the car off or cause it not to startup. Meaning no fuel so i guess that would explain not hearing the fuel pump running??? Can anyone relate maybe to this??
Old 10-12-2007, 05:37 PM   #11
Clayton
Member#: 121184
2004 WRX
Make sure none of your dome lights are on but with a burnt bulb.
Also inspect the wires between your battery, alternator, starter motor, and fuse box for possible short to body grounds.
Possible to also take your battery and alternator down to autozone or something to get them tested...
Clayton is offline   Reply With Quote
Old 10-12-2007, 07:57 PM   #12
Haps
Member#: 144617
Charge the battery, leave the key out and use an amp meter to find out what circuit is drawing current.
Haps is offline   Reply With Quote
Old 10-12-2007, 08:06 PM   #13
bugeye829
Member#: 81995
2008 Impreza
02 WRX 247k RIP
charge the battery & test it. also test the alternator and test for a draw.
then when you get it to crank and it still won't start, check for spark and fuel.
bugeye829 is offline   Reply With Quote
Old 10-13-2007, 01:15 AM   #14
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
Hard to tell, but I had a similar problem and it turned out to be a short in one of my gauges.
I used this thread to track down the culprit.
http://forums.nasioc.com/forums/show...=battery+drain
beaviscih is offline   Reply With Quote
Old 10-13-2007, 02:41 AM   #15
wrxSIN
Member#: 157818
did you do your
kegels today?
happended once or twice on my civic i used to own. problem was worn spark plugs/wires, low fuel and distributor going to crap.
wrxSIN is offline   Reply With Quote
Old 10-14-2007, 11:17 PM   #16
cangrisWRX
Member#: 150069
i also need some help please , somebody
cangrisWRX is offline   Reply With Quote
Old 10-14-2007, 11:21 PM   #17
cangrisWRX
Member#: 150069
after installing a fmic on my 07 wrx took it for a ride and was working super, went for a ride and after bout 25 to 30 min of driveing i stop for bout 15 min and then left the place and was ready to stop at a red light when i hear bout 2-3 loud back fire and then the car died. it cranks but wont start...anyone have anything that could help????
Old 10-14-2007, 11:40 PM   #18
04subyrex
Member#: 144873
66 Mustang 408w
I dont know but i would get the alternator tested. Thats what mine ended up being. If the ecu doesnt have enough power It will shut you car off in the middle of the road. Scary but it happens...
Old 10-15-2007, 05:15 AM   #19
SuperDuper
Member#: 131101
2004 AW STi
We hooked up jumper cables from my car to his to see if it would help any but it wouldnt start. We also checked the crank sensor, the fuel lines, we changed the spark plugs just in case. I found something really strange though..When we took out the spark plugs they were dripping wet with fuel EXCEPT cyl#4 (rear driver side) it barely smelled of fuel. Could an injector be bad on such a new car? We have never touched or come close to them. Would this keep it from coming on? I would have thaught it would come on and run like crap. Anybody???
SuperDuper is offline   Reply With Quote
Old 10-15-2007, 12:05 PM   #20
SuperDuper
Member#: 131101
2004 AW STi
Help?
Car won't start - cranks but won't start dave_88 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-12-2007 10:29 PM
Cranking but not starting up vinceGC8 Subaru Conversions 10 06-07-2007 12:42 AM
Car has power but wont start... IEScooby Newbies & FAQs 2 12-16-2006 02:35 PM
Running Link car cranks but will not start subaru mike Engine Management & Tuning 31 02-15-2005 09:57 PM
Subaru WRX Cranked but not start and Dealer won't even look at the car! mo168 Warranty Issues & SOA Problems 60 07-12-2002 01:20 PM
