Old 10-12-2007, 11:54 AM   #1
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
Default Installing a trubo into 2.5i
I was looking at maybe putting a turbo into my 2.5i and was wondering what would be required to place a turbo into a not previously turboed system. I read the unabombers manifesto but only saw stuff about upgrading a turbo.
07imprezadrifter is offline   Reply With Quote
Old 10-12-2007, 11:57 AM   #2
JLwrx06
Member#: 117952
06 ltd. wrx awdm'd
CobB StG. 2 SgM
ok well before u hear the many comments saying it is not good to do that i am going to say it. it is not worth the money because what u will spend will net u around what u could get a wrx for and more. but if u really want to do it go a head.
oh yea also why didn't u get a wrx if u wanted a turbo car?
JLwrx06 is offline   Reply With Quote
Old 10-12-2007, 11:58 AM   #3
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
A wrx motor swap or forged piston swap (forged and lower compression) at the minimum. NA subby motors dont hold up well to boost, most blow within 10k miles, many in under 5k. Even when "done right" and "tuned conservatively"
Many hundreds before you have tried, all but a handful (litterally a handful, I know of like 3 guys) have had the motor let go in very short order. Most run an intercooler, only 4-7PSI and tune it well, and it still blows pretty fast. And for your hard work and money, you end up making less power than a stock WRX.
From a financial standpoint, if you want a turbo, you are FAR better off heading back to the dealership and trading it in on a WRX, even a low milage used one. Heck even a 50k mile old one.
Sorry man, I know its not what you want to hear but you need to hear it before you spend a bunch of money.
Here is the rest of the bad news. There is very little you can do to gain any power on that motor. NA subbies dont seem much of anything from bolt on power mods. You can do an intake, header/full exh and cams. You will have spent EASILY 2k, have no powertrain warranty, and if you are lucky, you will have 15whp worth of gains. Pull the motor and do forged high compression pistons, and you have to run 93 octane, and you STILL dont make 200whp. A stock 06+ WRX makes @200whp.
You can improve throttle response a bit with an intake and catback, but thats pretty much it. Beyond that you are throwing money away on power mods.
Now on to the good news. WRX parts bolt up from a suspension and braking standpoint. You can make your car handle INSANELY well, and stop on a dime.
Defiant Autospeed is offline   Reply With Quote
Old 10-12-2007, 12:18 PM   #4
07imprezadrifter
Member#: 147720
2007 Impreza 2.5i
Urban Metallic Gray
OK well I figured I would get replies like this. I figured it wouldn't work I was just wondering. I don't really have money for any mods. So even if it would have worked I wouldn't have been able to afford it anyways. Thanks guys.
Old 10-12-2007, 12:27 PM   #5
conker69
Member#: 59692
2005 Impreza WRX STi
WRB-Gold
Then why ask?
conker69 is offline   Reply With Quote
Old 10-12-2007, 12:32 PM   #6
bindriftin
Member#: 106411
2001 GM6
Silverthorn
WTF you fail
bindriftin is offline   Reply With Quote
Old 10-12-2007, 12:44 PM   #7
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
Sorry man
Dont count yourself out on mods totally. There are a ton of used STI and WRX parts out there cheap that would provide nice improvements on your 2.5i
Old 10-12-2007, 12:48 PM   #8
Rizen
Member#: 157002
2011 STI Sedan
Satin White Pearl
To be perfectly honest, you'd probably just be better off saving money through college and then when you land a job, buy a WRX. I spent all of HS working on my 73 Duster (it has over 9k in it atm) and then in college I never could afford to work on it. I ended up selling the Duster to my dad, taking my graduation money, and when I landed a job after graduation I bought the WRX.
Also, I spent a ton of money trying to make the Duster into a decent handling car. And I learned the hard way that trying to force a car into something it wasn't designed to do is extremely expensive and usually really not worth it. That would apply to turboing a 2.5i. Trust me, I've been there.
Rizen is offline   Reply With Quote
Old 10-12-2007, 12:54 PM   #9
Defiant Autospeed
Vendor
Member#: 155450
2007 FXT
why Rizen dont 440+powerglide?
can i install 2.5L stuff into 2.5i?? kansai104 Newbies & FAQs 19 05-06-2010 09:15 AM
wxr into 2.5i kmilenco Subaru Conversions 7 10-30-2008 08:47 PM
WRX LSD into 2.5i zavier Subaru Conversions 2 01-17-2008 10:52 AM
Scoop into 2.5i hood... mxtwoforty Interior & Exterior Modification 7 02-05-2007 01:15 AM
WRX Rack Into 2.5i? modernist Brakes, Steering & Suspension 2 04-08-2006 10:11 AM
Message Board Statistics All times are GMT -4. The time now is 09:41 PM.
