Old 10-12-2007, 01:50 PM   #1
upjeeper
Member#: 150205
Sedona Red
Default what is in an overhaul gasket kit?
I'm hoping to start the rebuild this weekend on my 2.0/2.5 hybrid, but the dealership hasn't got the overhaul gaskets in yet.
Can I reassemble the crank/rods/pistons/block or are there o-rings, gaskets, etc that need to go in there?
thanks
upjeeper is offline   Reply With Quote
Old 10-12-2007, 03:52 PM   #2
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
There are 3 o-rings sandwiched between the block halves and a bunch of fujibond.
SloRice is offline   Reply With Quote
Old 10-14-2007, 11:51 PM   #3
Acostafan
Member#: 67398
2002 Now with 100%
RDA of 2.5l Goodness!!!
Yeah, you're def gonna need that kit. If you can't get it locally, call Tristan at www.thekingofparts.com. They usually keep that stuff in stock and cheaper than any dealer. I got all my gear from them for my hybrid build. Can't recommend them highly enough!
Acostafan is offline   Reply With Quote
Old 10-15-2007, 11:27 AM   #4
Spec V to Wagon
Member#: 129715
03 Wagon
I picked up my overhaul kit from Tristan as well. I think I spent $600 for the overhaul and all exhaust gaskets.
You'll need 2.5 overhaul kit and make sure you get 2.0 valvecover seals.
KOP has everything you need.
Spec V to Wagon is offline   Reply With Quote
Old 10-15-2007, 05:23 PM   #5
inyoface59
Member#: 95972
2012 Legacy
subarugenuineparts.com also has they in their catolog, i think its about 230-245$, comes with head gaskets and everything to completely rebuild the short block and heads.
inyoface59 is offline   Reply With Quote
Old 10-15-2007, 06:38 PM   #6
Acostafan
Member#: 67398
2002 Now with 100%
IIRC, I paid right at about $200 from Tristan @ King of Parts
Old 10-16-2007, 05:54 PM   #7
Spec V to Wagon
Member#: 129715
03 Wagon
Yeah I paid $203
Old 10-17-2007, 10:43 AM   #8
ec2k1gt
Member#: 129631
06 Obp Sti
back to slow lolz
Tristan is the man def order through him
ec2k1gt is offline   Reply With Quote
Old 10-17-2007, 08:29 PM   #9
inyoface59
Member#: 95972
2012 Legacy
haha i guess i over paid, order through him
STi 11mm Oil Pumps - CP Pistions - OEM Subaru Engine Overhaul Gasket Kits FredBeansParts Engine/Power/Exhaust 0 07-20-2009 08:52 PM
FS: Hundreds of New Gaskets, Overhaul gasket kits, BIG Turbos, Little Turbos. Drink Engine/Power/Exhaust 27 12-19-2008 08:28 AM
WHICH overhaul gasket kit?!? PeteDucati Built Motor Discussion 2 09-21-2006 10:32 PM
04 sti overhaul gasket kit wrspeed Private 'Wanted' Classifieds 3 08-02-2006 09:27 PM
Buying an Sti....what is the most all-inclusive kit right now? almschadblock Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 06-19-2004 12:12 PM
