Old 10-12-2007, 02:33 PM   #1
Midnight25rs
Member#: 39701
2003 2.5RS
Midnight Black
Impreza WRX Not going into gear when car in running...
The car is a 02 WRX and the tranny was just rebuilt. When we got everything put back together and fired the car up, everything sounded and felt fine. With the car not running, the tranny goes into all gears nicely.
The Problem: With the car running, clutch down, we couldn't get the car to go into any gear. So, we did some testing...
Test#1: Start the car in gear with clutch down. With the car in first gear, motor running, we can slowly let off the clutch and the car wants to move.
Test#2: Same as Test#1 but we pulled the car out of first gear into neutral and then tried to go but into first. This did not work. Once we got the car out of gear we couldn't get it back in without turning the car off and restarting the car in gear.
Is it possible something in the clutch area isn't completely disengaging and the input shaft is still turning enough where the syncros are not allowing the car to go into first with the motor running?
Any help would be greatly appreciated
Thanks
Midnight25rs is offline   Reply With Quote
Old 10-13-2007, 07:27 PM   #2
2.2 awd
Member#: 120954
1991 subaru legacy
gray taupe
I really don`t know but mayb i can help you a little Mine is a 91 legacy 2.2 if I started my car with it in gear and the clutch peddle to the floor it will go. The same with me i can`t get it in gear with the motor running not running great smooth
2.2 awd is offline   Reply With Quote
Old 10-14-2007, 05:15 PM   #3
outlwstr
Member#: 102201
i had a trouble getting into first at a light.. i missed the light completely. hate this transmition
outlwstr is offline   Reply With Quote
Old 10-14-2007, 05:34 PM   #4
Mulder
Trust no one
Member#: 11170
02 WRX
05 GTO/11 Sonata(!)
The clutch is not releasing fully, due to either a hydraulic or mechanical issue.
Old 10-14-2007, 07:38 PM   #5
AncientRS
Member#: 161758
2000 GM6
BRP
I agree with Mulder; it seems the clutch is not fully disengaged. You said that as soon as you let off the clutch pedal, the car starts moving; that's not good. How does the pedal feel? Got too much/little free play on the top?
AncientRS is offline   Reply With Quote
Old 10-20-2007, 04:04 AM   #6
KairaWRX
Member#: 162284
1995 Tommy Kaira WRX
Bleed the slave-cylinder - there's probably air got into the system during the tranny work. After that, pump it a few times and see how it goes.
KairaWRX is offline   Reply With Quote
Help! Car wont go into gear when started! AjIsDope Transmission (AT/MT) & Driveline 15 11-13-2009 10:30 AM
clutch cylinder or release bearing?, not going into gear. Cushman Transmission (AT/MT) & Driveline 1 08-09-2007 12:54 PM
Clutch isn't slipping, but not going into gear Major Johnson Transmission (AT/MT) & Driveline 21 10-02-2006 08:38 AM
JDM 4.44 Will not go into gear moss Transmission (AT/MT) & Driveline 9 05-28-2006 10:23 PM
Probs w/ Factory Short Throw - Not Going into Gear,Too "Hard" stabone Transmission (AT/MT) & Driveline 4 10-24-2002 03:38 PM
Message Board Statistics All times are GMT -4. The time now is 08:14 AM.
