Old 10-12-2007, 04:11 PM   #1
tothaneck
Member#: 147721
Default 98 legacy l - radio install
ok i know im doing except for oen part
getting the main wire into the car- now i know i can drill into the firewall but i dont wanan do that
by the clutch/pedals - i see like three plastic circle things - two are white and one is black
would either or them be ok to drill into and whats the diff between the white and black ones?
tothaneck is offline   Reply With Quote
Old 10-12-2007, 04:42 PM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Why do you need to drill through the firewall for a radio install?!
Here you go though:
http://sl-i.net/FORUM/viewtopic.php?t=465
Wiscon_Mark is offline   Reply With Quote
Old 10-12-2007, 05:31 PM   #3
runninstrong
Member#: 121474
1991 SS & 2013 STi
Red & Blue
If you get the wiring harness adapter for the car, all wires connect right up to it. The only wire you should have left over is the ground to a clean metal part of the car. No need to get through the firewall. Unless, you are hooking up an amp and maybe you left that part out.
runninstrong is offline   Reply With Quote
Old 10-12-2007, 06:52 PM   #4
tothaneck
Member#: 147721
yea it is for an amp but actually i found the perfect spot
thankyou for your input regaurdless...
So who's good with radio installations- 05 Legacy GT? brandonroy New England Impreza Club Forum -- NESIC 11 03-24-2009 11:20 AM
Metra 98-8999 radio install kit (new) and harness buri73 Interior/Dressup/Audio & Security 2 01-23-2008 12:45 AM
98 legacy - help removing stock radio tothaneck Legacy Forum 8 10-01-2007 10:45 AM
98 Legacy - Removing OEM radio DanCT Legacy Forum 12 04-13-2006 02:12 PM
Installing a transmission temp gauge in a 98 Legacy White2.5GT Transmission (AT/MT) & Driveline 0 07-08-2004 08:33 PM
