Old 10-13-2007, 04:15 PM   #1
Sausage
Member#: 104998
2007 vf39 SuperWagon
I haz teh bed gramers
Default DIY Solid Front Lip : The Writeup
This is your goal:
What you need:
Cost:
~ $30 or so for raw materials
15 hours of your time
Some measuring skills and patience...no experience
Materials:
Foam garage door sealer from home depot
1 fiberglass matte
1 can of resin
1/6 can bondo (so new can or leftover will work)
sanding disks
truck bed coating
hardware bolts and nuts for mounting
Pegboard or other flat piece of wood
Equipment:
Sander
Sanding block
Dremel with cutting wheels
Rubber body filer tool thingy (or anything to spread bondo evenly)
Drill with various bits
The procedure:
- Find some leftover flat piece of wood and make sure it's bigger then the underside of your car.
- Hold it in place and trace the bumper line onto the wood.
- cut out the frame so it's easier to work with
- brake the frame in half, clamp together, and sand both sides at the same time to ensure symmetry between the halves.
- Put the frame back together, cut out a plug for the dip in the front, and secure it in place.
- take some screws, nut and bolts you have lying around and secure the garage door sealer to the frame. Make sure you use a boat load, about 1 every 2in. Then go back through them and realign them to get the soothes curve possible. Work out the bulges and odd humps as best as you can.
- Flip the frame over and cover the whole back with fiberglass matte and resin. Do about 2 layers. Make sure you use matte, not cloth.
- Once that dries, take everything down, and reposition it so that the top is now exposed.
- lay down a layer of matte and resin over the whole top.
- lay down another layer of resin to smooth things out.
- Sand it till everything is near smooth
- Go over and fill the divits with bondo. More then likely the foam sealer will deform, this is a good time to fill in those depressions with bondo as well.
- Sand like hell till everything is near smooth
- Lay down 2 more layers of resin then sand smooth (Stop at 120 grit)
- Test fit against the bottom of the car. This is a good time to dry mount the diffuser, drill all your holes, and make sure everything is lined up properly.
- Hang up and paint with truck bed liner spray on coating (this stuff rocks) Tough and dries in 5 min
- Mount and you're done.
Sausage is offline   Reply With Quote
Old 10-13-2007, 04:15 PM   #2
Sausage
Member#: 104998
More pics:
The gap in the middler FiXoR3D:
Old 10-13-2007, 04:15 PM   #3
Sausage
Member#: 104998
Room for advice
Old 10-13-2007, 04:18 PM   #4
I Love Boobies
Member#: 146137
06 WRX R.I.P.
06.06 - 10.08
you are my hero. iv already got a poly vlim but i am making your diffuser over winter break. what else do you plan on making? my vote would be a defi style clock gauge pod for 52mm gauges
I Love Boobies is offline   Reply With Quote
Old 10-13-2007, 04:30 PM   #5
simplebirdy
Member#: 102996
2009 Legacy
looks as if this can be added to and made even better
simplebirdy is offline   Reply With Quote
Old 10-13-2007, 04:38 PM   #6
Sausage
Member#: 104998
^ You could, but I kinda like it like this. I test fitted some material to see what it would look like and I decided against it.
Old 10-13-2007, 04:51 PM   #7
indelible
Member#: 99573
2015 FXT
too bad this write-up wasn't done 2 weeks ago, i just bought a lip, lol. Great job! I'll be doing this if my lip ever breaks. I think I'll attempt the rear diffuser sometime this month. Can't wait to see more DIY projects from you.
indelible is offline   Reply With Quote
Old 10-13-2007, 04:58 PM   #8
ilikesubaru
Member#: 160085
2002 Bug Face
looks great, good job man
ilikesubaru is offline   Reply With Quote
Old 10-13-2007, 05:11 PM   #9
Sausage
Member#: 104998
I'm not sure what to do next. My initial though was underbody panels to make the whole bottom of the car one flat piece. But that would require covering up the holes on the bottom of the enigne bay, the trans, pretty much everything between the front and the rear axels - the ehaust.
But I'm not sure how beneficial it would be since it might increase under the hood temps. The air usually comes in the front of the car, goes through the radiator and engine bay. And through the hood scoop, through the tmic.
Either way it exits from underneath the car. I'm not sure I wanna block that.
Old 10-13-2007, 05:15 PM   #10
jdubya301
Member#: 139076
2002 stg2 wagon
03 suzuki sv650s
dude you are my hero. ive been looking for a lip like this for my 02 wagon. there arent any. i didnt want to do the diy garage foam lip cuz i think it looks flimsy, but i like this idea.
i would add some vertical pieces to go down the center, so theres not that awkward space between the lip and the bumper. what do you think?
jdubya301 is offline   Reply With Quote
Old 10-13-2007, 05:24 PM   #11
iheartmysuby
Member#: 83638
that does not look good. if you fill it it should look better
goo idea though.
iheartmysuby is offline   Reply With Quote
Old 10-13-2007, 05:32 PM   #12
Handsdown
Member#: 29355
mess and hassle.
the only wood i want on my car is on the dash.
but hey, at least yours isn't foam, because we all know how terrible foam is for aerodynamics.
Handsdown is offline   Reply With Quote
Old 10-13-2007, 05:34 PM   #13
Sausage
Member#: 104998
It's easy to just throw in a verticle piece. It'd take about an hour to do. I didn't do it because I was going for efficiency. I wanted to lip to smooth the airflow under the car. If I throw a vertical piece in, it'll just bring the air to a dead stop...
Old 10-13-2007, 05:36 PM   #14
Handsdown
Member#: 29355
I'm almost positive your splitter won't smooth airflow under the car better than if it had that hole above it plugged.
Old 10-13-2007, 06:25 PM   #15
th3loadr
Member#: 155457
2007 mustang
performance white
dont mind the flamers, it worked out well.
th3loadr is offline   Reply With Quote
Old 10-13-2007, 06:27 PM   #16
JBravo920
Member#: 73420
2008 Camry XLE
& 10' Kawasaki Vulcan 900
When is someone gonna come up with a DIY lip for the 04-05 with STi splitters?!?!?!?!
JBravo920 is offline   Reply With Quote
Old 10-13-2007, 07:22 PM   #17
iheartmysuby
Member#: 83638
lol. but seriously what doyou think the front of the car does to air. comes to a dead stop and throws air around it. so a little piece covering up that gap wont do much.. and it will look a ton better
Old 10-13-2007, 07:36 PM   #18
Sausage
Member#: 104998
Cool, after all the feedback, I'm gong back to the garage and making an insert. Stay tuned...
Old 10-13-2007, 08:53 PM   #19
xdrian
Member#: 104200
828 WHP BUGEYE
Street Proven Performance
came out nicee!!!!
xdrian is offline   Reply With Quote
Old 10-13-2007, 09:06 PM   #20
ATK
Member#: 123698
2004 WRX Sportwagon
Looks pretty nice, but I think I would have tried to make the sides flat that go along the fender like the V-limited lip. Maybe you could have even just pushed it down and braced it with aluminum strips or something then fiberglassed it to hold its form....idk, but I'd try to get away from it still looking like the garage door sealer.
Overall great effort.
My vote for the next DIY item if you are to stay with exterior design, is the front or rear strakes. Now that would present a bad ass challenge.
ATK is offline   Reply With Quote
Old 10-13-2007, 10:17 PM   #21
aspenw06sti
Member#: 104779
2009 RIP Sil STI/NAV
06 W STI:07 LIMITED #374
Too much hassle! Ebay dude!
Besides the space left open leaves for strain on your bumper at medium speed which means that your bumper will flap around!
Make some bumper protector!
aspenw06sti is offline   Reply With Quote
Old 10-13-2007, 10:31 PM   #22
BlueF
Member#: 45324
Damn. That's a lot of criticism for an impressive home fab job!
BlueF is offline   Reply With Quote
Old 10-13-2007, 11:03 PM   #23
indelible
Member#: 99573
2015 FXT
how about rear side skirts to go along with the rear diffuser for the next project?
Old 10-13-2007, 11:14 PM   #24
nightcrawler60
Member#: 126438
2004 Impreza
#Winning
Wow man...how do you come up with this stuff? Thumbs up from over here!
nightcrawler60 is offline   Reply With Quote
Old 10-14-2007, 01:16 AM   #25
WRex06
Member#: 118537
Good work man!
Do you do requests?
You should make these rear spats that can fit on WRX models 04+
WRex06 is offline   Reply With Quote
DIY Rear Diffuser : The Writeup Sausage Interior & Exterior Modification 193 03-17-2016 08:37 PM
new DIY bugeye front lip Frank A Interior & Exterior Modification 58 02-21-2012 07:06 PM
DIY painting front lip sovietjet Interior & Exterior Modification 12 02-22-2006 02:19 PM
PURE blitz style front lip : SOCAL 5zigenwrx Private 'For Sale' Classifieds 6 08-20-2004 01:36 PM
Does anyone have the Greddy Front Lip for the WRX in Stock??? dman918 Interior & Exterior Modification 1 01-08-2003 11:02 AM
