Old 10-13-2007, 04:41 PM   #1
triguy
Member#: 27109
2002 WRX Wagon
2.5L Crawford, 6 spd
Default Is everything coming off drive side fuse box 12 volt?
I've connected an aftermarket DCCD controller that requires 12 volt and my multimeter isn't working. To provide the power, I went to Pep Boys and picked up this neat replacement fuse that comes with a power wire attached to it and I inserted it the radio fuse outlet on the drivers side. Am I safe to assume that it is a 12 volts?
triguy is offline   Reply With Quote
Old 10-13-2007, 08:19 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The vehicle electrical system is 12V, so everything connected to it will be 12V.
Should I be at all mad that this is slowly coming off? nxttruck2002 Interior & Exterior Modification 7 06-15-2008 01:23 PM
Fused 12 volt ignition supply? decaman Electrical & Lighting 6 01-01-2008 03:55 PM
How do you tell when a 12 Volt 20 Amp battery is going bad? Cjchaps Off-Topic 10 04-21-2006 10:30 PM
Can you recharge a 12 volt motorcycle battery with a 12 volt car charger? Cjchaps Electrical & Lighting 3 07-01-2003 01:55 PM
Need fuse box diagram for the engine side Pakin Legacy Forum 3 05-22-2003 08:16 AM
