Old 10-13-2007, 07:41 PM   #1
ejh25
Member#: 65267
Default Rubbing in Reverse now in in Forward
I used to have a little rub in reverse. What I thought to be the Toyo R888 235/17s rubbing against the strut (struts and springs are V8 Spec C). Today, I loaded the car with 4 passangers and a full trunk. The car started rubbing in forward gear. After I let my passangers out and it was just me, the rubbing continued. It is definitely much worse.
Any thoughts?
I'll check undertrays and plastic pieces tomorrow, as well as the inner sidewalls.
Thanks,
Eric
ejh25 is offline   Reply With Quote
Old 10-14-2007, 09:41 PM   #2
ejh25
Member#: 65267
Well the rubbing is definitely bad. It looks to be the left rear tire rubbing the strut when the left springs unload while turning left.
Taking the car into Andrewtech tomorrow. Hopefully they can alleviate the problem in short order.
Old 10-14-2007, 11:26 PM   #3
waktasz
Member#: 86356
2015 s1000r
wheelie monster
Something bent? This really shouldn't happen, ever, with 235 size tires.
waktasz is offline   Reply With Quote
Old 10-15-2007, 09:49 AM   #4
ejh25
Member#: 65267
Not sure... car is at Andrewtech and diagnosis should come soon.
- Eric
Old 10-15-2007, 02:14 PM   #5
ejh25
Member#: 65267
Rear camber bolt backed out!
clanking noise and vibration in reverse wheels turned, sometimes in going forward. NITROS Transmission (AT/MT) & Driveline 6 07-24-2008 05:02 PM
Clink in reverse then forward Genner Newbies & FAQs 10 05-17-2007 02:33 AM
My car sounds like in reverse gear but when moving forward sonicowrx03 Transmission (AT/MT) & Driveline 4 06-20-2004 12:22 AM
Imprezas in Europe. Now available in Lifesaver colors! Matt Off-Topic 9 09-28-2003 02:42 AM
Stalling in reverse and rough in reverse... Evaider Transmission (AT/MT) & Driveline 5 01-23-2002 07:32 PM
