Welcome to the North American Subaru Impreza Owners Club Tuesday October 25, 2016
Old 10-13-2007, 08:40 PM   #1
Member#: 125226
Default motor swap ?
i posted before but no ones helping maybe if i through some detail it can help u help me
i had a 02 rex and some one cut me off on the highway when it was raining and i hit a wall right side sorta kinda bad ehh whatever
i have a 00 2.5rd and i would like to put the rex motor in there but im not sure if every things going to match up
some people are telling me to use the 2.5 trans other telling me to swap the motor and trans from the rex idk
wireingharness ?? no idea what i need, should i use the stock ecu fromt he rex or should i go for axis port or idk
if someone could help me out that would be greatly appreciated
Garsha02rex is offline   Reply With Quote
Old 10-14-2007, 10:31 AM   #2
sense of nature
Member#: 112759
2002 STi Mikey Tuned
Pull motor ,trans crossmember, driveshaft , axles ,rear diff ,axles (?) ecu & harness .
That would be most cost efficient since you already have all that stuff .
you may have to use the control arms also I think there is a difference in sizes . I'm sure if you look around more there is oodles of info on the materials needed Good luck
sense of nature is offline   Reply With Quote
Old 10-14-2007, 10:39 AM   #3
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
this really needs to be moved to the conversions forum...
you will have to wire the wrx and RS harness together...its simple for 96+ cars...
Homemade WRX is online now   Reply With Quote
Old 10-14-2007, 08:19 PM   #4
Member#: 130973
mostly everything bolts up the biggest part is the wiring.you have to merge the 2 harnesses.
doesnt matter what trany you have because neither can hold any power
access port is a tuner not an ecu u would use the rex ecu.
check out the conversion section and read up it will help a lot
acidrain088 is offline   Reply With Quote
Old 10-14-2007, 10:10 PM   #5
Member#: 41477
2006 Tahoe that
will pull your bumper off
What are you basing this on? What kind of HP do you consider "power"? I have an STi block pushing ~310whp on a stock wrx tranny with 116,xxx miles on it.
dropmech is offline   Reply With Quote
Need more info for sti motor swap - hvac, motor and so on. hybrid gti 2 Subaru Conversions 4 09-29-2008 10:41 PM
dash swap and motor swap questions aka_tur Subaru Conversions 6 02-27-2007 05:21 PM
Hypothetical...swapping cams when doing motor swap kaisersouse Normally Aspirated Powertrain 0 04-14-2006 07:54 AM
('93-'01) WRX motor SWAP??? AWDBOY Impreza Forum 19 05-22-2001 12:57 AM
('93-'01) Emissions after motor swap mykrrrr Impreza Forum 8 04-27-2001 12:31 AM
