Old 10-15-2007, 02:42 PM   #1
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Default '06 STi with SR56 and Aquamist
This car was a car with minimal mods and ran really great on the dyno
It is a 2006 STI
SR56 Turbo
AP2
3" turbo back exhuast
APS 65 mm cold air intake
Walbro Fuel pump
Aquamist HFS 5 - Two spray nozzels - one on each end of the stock sti tmic
24 - 25 psi on Pump gas
Stock injectors 100% maxed out and mass air flow at limit with this power level
A nice quick spooling simple street set up that results in a very fast car on pump gas
Video of the dyno
http://www.youtube.com/watch?v=rWqx_vuPTfo
Dyno Flash is offline   Reply With Quote
Old 10-15-2007, 02:46 PM   #2
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
Holds power very nicely. Would you say the torque drop off is attributed to the cams? TMIC?
DoctorNick is offline   Reply With Quote
Old 10-15-2007, 03:19 PM   #3
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
Probably both
I am going to suggest a V mount ic set up we have here to the customer which would aide the charge temps and help keep the fast response
Old 10-15-2007, 03:23 PM   #4
scooter29
Member#: 110418
2006 Sti
white
stock injectors???
scooter29 is offline   Reply With Quote
Old 10-15-2007, 03:29 PM   #5
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
I really dont know much about this stuff, but Ive been taught that its not good to run injectors above 80% duty cycle. Ive also herd that the STi's can flow around 600cc's, although theyre only rated to 565cc's. If you dont mind, could you share some of your knowledge on this to shed some light on it? Im planning an 06 STi build right now with a friend of mine. Thanks in advance.
trex616 is offline   Reply With Quote
Old 10-15-2007, 03:45 PM   #6
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
It is always recomended to maintain injectors at around 85% duty cycle as a confortable max operational zone to allow sufficient off time (cooling) and to maintain proper control
The reality is that many cars we see are running near 95% or more duty cycle with no issues what so ever
If you search back on the archives here you will find a old debate between Cobb and Vishnu on this subject about the old Cobb kits which used unichips - back before the Access Port about the saftey and reliability of running high injector duty cycles. Here is a link to that discussion which was very informative - from back in 2001
http://forums.nasioc.com/forums/show...e+cobb+unichip
With hind sight I have not seen too many injectors go bad
In the case of this car what we will prob do on the street is lower the boost slightly to get the injector max duty cycle to about 90% and also include a fuel cut in both the tune and the EBC to prevent the customer from turning up the boost to exceed about 95% duty cycle - what ever that works out to on the road. We might also up our alcohol jet size as well.
Going down the road, this customer must upsize his injectors if he does any other mods such as a larger tmic or fmic of a v mount etc.
With larger injectors come slight losses in idle control and partial tps response and slight losses in atomization ability. With careful tuning larger injectors can be made to run very well - we did a car with 800's last week which made over 460 tq and 417 whp with a Donminator 2.5 and Aquamist which ran really well. (Same AP2)
Old 10-15-2007, 05:59 PM   #7
GBX
Member#: 132764
07 STI Ltd
UGM
nice al! Still leaning towards a green myself though
GBX is offline   Reply With Quote
Old 10-15-2007, 08:11 PM   #8
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
I like the Green and the Dominator 2.5 and 3 myself - this SR56 was something wehad in inventory and the customer wanted to stay with a full APS set up - the car has all APS all the way around from the 3.5 " Exhaust to the cold air intake so the nice res turbo was a logical step
Maybe the APS tmic will be the customer's next step
Al
Old 10-15-2007, 08:32 PM   #9
norexyet
Member#: 39149
11 elantra
yea i said elantra
very nice tune Al.
norexyet is online now   Reply With Quote
Old 10-15-2007, 09:18 PM   #10
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Why wouldn't you run this setup on the 70mm CAI and some bigger injectors?
-- Ed
Old 10-15-2007, 09:22 PM   #11
gotti
Member#: 62956
06 sti rally car
gottiracing
very nice bro.....i guess tuning is like baseball...bat .300 and you get into the hall of fame.
(3/10 cars tuned stay running) get it
gotti is offline   Reply With Quote
Old 10-15-2007, 09:55 PM   #12
norexyet
Member#: 39149
11 elantra
yea i said elantra
how long it take you to think of that one. saw it on tv perhaps and wrote it down?
Old 10-15-2007, 10:02 PM   #13
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Thanks a lot for that! Really insightful info, and thats hard to come by these days on NASIOC. Keep up the good work guys.
Old 10-15-2007, 11:04 PM   #14
gotti
Member#: 62956
06 sti rally car
gottiracing
lots of practice and years of meditation
Old 10-15-2007, 11:10 PM   #15
BrentS
Member#: 96601
2004 WRX
This looks like a fun shop, all kinds of cool videos coming from there.
BrentS is offline   Reply With Quote
Old 10-15-2007, 11:15 PM   #16
AspenWhite_STi
Member#: 97616
2005 AW STi - GONE
2009 Black 135i
Nice numbers Al, but 373whp on a stock maf, injectors, and fuel pump is a little hard to swallow.
AspenWhite_STi is offline   Reply With Quote
Old 10-16-2007, 12:09 AM   #17
Madhouse
Member#: 122996
2006 STI
Thanks for posting the vid, there's not a lot of info on the SR56 and it seems to inherit the reputation of the SR55 still.
I'm running that same turbo, with a fmic, 70mm cai, 740cc nismos, hsf-5 injected at the throttle body with 50/50 mix, tgv deletes and port, boost control solenoid, fuel pump, and a twin vent recirc bov. I hit 353whp uncorrected on the Rocket Rally Dyno Dynamics and have no issues with creep at all with IWG. I'm running at 1.5bar ... 21.7psi
It pulls hard all the way into redline and wants to keep going.
Madhouse is offline   Reply With Quote
Old 10-16-2007, 01:34 AM   #18
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
-- Ed
No doubt it would be a good plan to set it up that way but in this case the customer is trying to work with his existing parts and wants to stay on a more limited budget.
He just decided to add this turbo to his set up and see how much power it coul make with his current intake and injectors.
Turns out it made decent power this way and the customer MAY just decide to leave it the way it is now. OR he may do some more upgrades in which the larger intake and injectors will be required.
Al
Old 10-16-2007, 02:16 AM   #19
wuuusaa
Member#: 92894
2015 Wrx
was there alot of heat soak?
what size turbo is the sr56 equal to?
wuuusaa is offline   Reply With Quote
Old 10-16-2007, 02:21 AM   #20
wuuusaa
Member#: 92894
2015 Wrx
btw couldn't you have went a little more aggressive on the timing? by the look of the afr's during dyno pull
Old 10-16-2007, 02:19 PM   #21
Dyno Flash
Vendor
Member#: 73568
'05 STI 11.1 @ 127
03 Evo 8 9.5 @ 149
On every street car I set up, there is a lot of room to go more agressive. The idea is to leave a signifiant margin of saftey for long term reliability and for adaption to varying fuel octane levels and climatic conditions. How agressive to set up a car is a art to itself.
Al
'06 Sti, stock turbo w/ Aquamist alfriedesq Proven Power Bragging 33 05-11-2009 01:33 PM
Into the 10's w my Full Weight STI on pump and Aquamist ! alfriedesq Proven Power Bragging 135 10-17-2008 08:22 PM
448 TQ P '07 STI Stage II with pump and Aquamist Dyno Flash Proven Power Bragging 149 05-07-2008 02:30 PM
06 STI APS SR56 and more.... Fine Line Imports Member's Car Gallery 11 04-11-2008 08:13 PM
'07 STI with SR56, TMIC, Alchy Injection on pump with AP2 Dyno Flash Proven Power Bragging 46 01-05-2008 12:53 AM
