Old 10-14-2007, 05:32 PM   #1
mel t vin
Member#: 159299
1998 Legacy Wagon
Green
Default Flat-bedding a '95 wagon
Hi folks,
My girlfriend is having her '95 wagon flat-bedded to the dealer so they can rectify a technician's "oversight". It looks like there are two 1/2-inch u-bolts tied to the frame rails at the rear corners of the car but only a small 1/4-inch eye bolt tied to the right front radiator support [this point doesn't look very strong].
It appears the approved solution is to have the vehicle pulled onto the flatbed via the rear 1/2-inch u-bolts. Is this the general consensus? In a pinch, where have you folks attached the chains to pull the vehicle from the front? Obviously, it would be prudent to stay away from steering and suspension components. Thanks for your time.
Allen
mel t vin is offline   Reply With Quote
Old 10-14-2007, 11:38 PM   #2
98legwag
Member#: 160325
09 Legacy 3.0R
had to have my 98 towed when the battery exploded last winter . my tow hooks were in the front. check behind the bumper. i know i can see mine when i look behind it. best way i can explain it is they are on the sides of the radiator, not attached to it.
just ran out to check, mine are directly below the headlights under the bumper. i actually have to reach under the bumper to get to them. hope this helps.
98legwag is offline   Reply With Quote
Old 10-14-2007, 11:44 PM   #3
98legwag
Member#: 160325
09 Legacy 3.0R
also, if it was a technician's oversight at the dealer argue with them about getting them to pay for the towing. if they didnt screw up the car wouldnt need to be towed. doubt youll get anything, but id try it.
Old 10-15-2007, 12:17 AM   #4
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
Ooohhhh, man... I thought you were about talk about cutting up your car and turning it into a baja-style flatbed. That would've been a great thread to read (especially if it had pictures).
janikphoto is offline   Reply With Quote
Old 10-15-2007, 12:26 AM   #5
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
You can use either towhooks. There are two in the front and two in the back.
Definitely pursue the dealership about paying for the towing, unless you have AAA platinum or something...
Wiscon_Mark is offline   Reply With Quote
Old 10-15-2007, 12:42 AM   #6
mel t vin
Member#: 159299
1998 Legacy Wagon
Green
Thanks for the replies. For some reason, her wagon only has one tow hook up front located on the passenger side of the radiator support under the headlight. To be safe, I suppose we will pull it onto the flatbed from the rear.
Old 10-15-2007, 12:57 AM   #7
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
She might have had the other cut off. There was a recall about the tow hooks setting off the airbags if you run up on a curb. The solution the dealers came up with was cutting them...
Plays_With_toys is offline   Reply With Quote
Old 10-15-2007, 12:04 PM   #8
US2JDM
Member#: 5893
1997 Black GC4
1995 White BK6
Yeah, mine had that done. IIRC the actual tow points are higher up, those are just tie-downs for easier transport from the factory.
US2JDM is offline   Reply With Quote
Old 10-15-2007, 12:50 PM   #9
janikphoto
Member#: 10471
2000 BMW Z3
have you thought about attaching the tow strap to the rear view mirror? That's one of the strongest points on a subaru! It's either that, or wrap it around the intake manifold and start pulling.
Sorry, but for some reason I just had to be stupid on at least one post today. Your thread was the winner...
Old 10-15-2007, 04:43 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
I've scraped, slammed, and bumped those hooks so much that I don't know whether it's a good thing or not that the airbags didn't go off...
Old 10-15-2007, 08:00 PM   #11
mel t vin
Member#: 159299
1998 Legacy Wagon
Green
For the archives, we found two holes [sealed with rubber plugs], one on each frame rail, right around the front door handles [IIRC]. We were going to insert the tow trucks J-hooks in those until we found two more holes, also on the frame rails, about 18" further to the rear that weren't plugged. Those are the ones we hooked up to. And just to report, absolutely no problems getting on or off the tow truck. Thanks again!
wtb: local in tri-state flat bed car trailer jeffsnyder Tri-State Area Forum 3 01-14-2005 05:48 AM
Need Flat Bed this Weekend JessesTalon North West Impreza Club Forum -- NWIC 0 01-11-2005 04:45 PM
Anyone have a flat bed and want to go to Lewisburg, PA? Sports Wagon South East Region Forum 2 02-19-2004 09:26 PM
Flat Bed Scanner and Radar Detector FatCatTurbo Private 'For Sale' Classifieds 6 12-27-2003 04:07 PM
Gauging Interest on Slim Flat Bed Scanner BigElm Tri-State Area Forum 5 01-31-2003 09:36 PM
