Old 10-15-2007, 02:54 PM   #1
pignoseSTI
Member#: 100834
2006 Subaru STI
Steel Grey Metallic
Default APS inlet STU legal?
Hello all I was wondering if the APS turbo inlet pipe was legal for STU? I know you can change everything up to the compressor inlet, however i'm not sure if the modifications needed to install the pipe (moving the FPR, cutting this/splicing that, etc.) would render this pipe illegal. Thanks!
pignoseSTI is offline   Reply With Quote
Old 11-17-2007, 11:45 PM   #2
pinkertonpunk
Member#: 62386
2008 Honda S2000
Chicane Silver
Anyone actually know the answer to this yet?
-Colin
pinkertonpunk is offline   Reply With Quote
Old 11-18-2007, 12:21 AM   #3
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
I can't remember the details, but I know some of the inlets hook up to all five of the factory spots, and some of them only hook up to four. IIRC the Samco is legal, but I forget the rest.
Old 11-18-2007, 11:37 AM   #4
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
The APS is definitely not ST* legal because you have to move things you aren't allowed to touch. The Samco and GPMoto inlets are legal.
PhilC is offline   Reply With Quote
Old 11-18-2007, 09:10 PM   #5
WJM
Guest
Member#:
Screw that. ST rules are such BS.
The emissions system still works as originally intended. Anyone who would protest you over that must be driving a BMW or a RX8.
Old 11-18-2007, 09:29 PM   #6
kursplat
Member#: 89528
2005 sti
crystal grey
or playing by the rules...
kursplat is offline   Reply With Quote
Old 11-19-2007, 12:21 PM   #7
WJM
Guest
Member#:
Thats like the whole ECU/P0420 thing.
Its illegal, but 90% of ST players do it anyhow.
Old 11-20-2007, 09:14 AM   #8
PhilC
Member#: 35190
2003 WRX STX #77
www.soloracer.com
It's nothing like that at all. The whole ECU/O2 sensor thing wasn't illegal until the clarifichange. Those who compete at the National level in STX at least all had legal cars up until that change and all had illegal cars after it.
The APS inlet is clearly illegal and always has been because of the other modifications required to fit it. In this situation it's not a big deal since the APS isn't going to work as well as the legal options that you have and it costs more to boot.
Old 11-20-2007, 09:39 AM   #9
WJM
Guest
Member#:
Since I wont have a WRX anymore, it really doesnt matter I could care less if I were in STX and someone were running an APS inlet, I know its not going to give a winning margin in power. N/A cars are much easier to make competitive and remain legal.
Old 11-21-2007, 09:17 AM   #10
stil2stock
Member#: 51870
06 STI
anyone know if the gimmick motorsports ones are legal?
stil2stock is offline   Reply With Quote
Old 11-21-2007, 09:22 AM   #11
WJM
Guest
Member#:
Looks like minimal modification needed.
Altho you are still deleting the 'blow by connector' and you've had to fool the ECU by thinking its still there.
I'd say illegal on that part for all 2004+ WRX and STi.
Would be 100% legal for 02~03 WRX tho.
Old 02-15-2008, 05:26 AM   #12
-OneWay-
Member#: 70128
I found this thread while searching for more information about the APS Inlet in STU class.
Is the issue having to move the fuel pressure regulator out of the way to fit the inlet in place then relocating it?
http://www.airpowersystems.com/wrx/intake/install.htm
You may be able to make a bracket to hold it in the stock location if that is the issue but, I am not seeing where in the Rules prohibits the use of a turbo inlet because of needing to relocate the FPR.
14.10c
" The air intake system up to, but not including, the engine inlet
may be modified or replaced. The engine inlet is the throttle body,
carburetor, compressor inlet, or intake manifold, whichever
comes first. The existing structure of the car may not be modified
for the passage of ducting from the air cleaner to the engine inlet.
Holes may be drilled for mounting. Emissions or engine management
components in the air intake system, such as a PCV
valve, or mass airflow sensor, may not be removed, modified, or
replaced, and must retain their original function along the flow
path."
That sounds to me like as long as I am not modifiying the body structure of the car or modifying emissions or EM components and everything retains it's original function along the flow path, it's allowed.
for the FPR itself
14.10f.3
"Fuel pressure regulators may be replaced in lieu of electronic
alterations to the fuel system. It is not permitted to electronically
modify the fuel system AND replace a fuel pressure
regulator."
Anyone able to explain why the APS Inlet IS or IS NOT allowed and maybe shed some light on this?
-OneWay- is offline   Reply With Quote
Old 02-15-2008, 08:02 AM   #13
KC
Member#: 442
16 SS
00 S2000
Fuel pressure regulators may be replaced in lieu of electronic alterations to the fuel system. It is not permitted to electronically modify the fuel system AND replace a fuel pressure regulator
That might have something to do with it. If you're running a modified ECU, I read that as you've electronically modified the fuel 'system'. Since the rules say you can't do both... (that and the rules don't say you can relocate the FPR, but only 'replace').
--kC
KC is offline   Reply With Quote
Old 02-15-2008, 08:56 AM   #14
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
What options work better? Why are they better options?
Yes, these probably are stupid questions, but I don't know the answers and would like to know.
speedyHAM is offline   Reply With Quote
Old 02-15-2008, 09:06 AM   #15
68Cadillac
Member#: 95901
Of pictures I've seen of the Gimmick Motorsports Inlet, it appears to be legal for STX/STU. Specifically for my 2004 WRX. It fits with minimal modification. It doesn't require modification of the turbo (big no no), and all OEM hoses that fit up to the factory inlet have a place to attach without being blocked internally or plugged with an 10mm screw.
68Cadillac is offline   Reply With Quote
WRX trunk & wing--STU legal? ScoobyTodd Autocross 149 03-19-2009 11:59 AM
STU Legal? OEM Fog Bezel, No Light (Ram Air) S1MPSONS Motorsports 13 05-20-2008 04:56 PM
Outrigger bushings STU legal? pinkertonpunk Motorsports 9 03-11-2008 04:04 PM
Heat Wrapped Up-pipe/downpipe, STU Legal? S1MPSONS Motorsports 4 11-06-2007 12:19 PM
Check setup for STU legality and competitiveness Call_me_Tom Motorsports 19 07-21-2006 05:53 PM
