Old 01-17-2002, 09:12 PM   #1
ort5
Member#: 3706
2000 VW Golf TDI
5mt Red
Default Shift interlock problems...
Hey all,
My friends 94 Legacy automatic just developed a problem. The automatic disengagement of the shift interlock no longer works. Meaning if you step on the brake, the shifter will still no longer come out of park. There is a small button on the front of the shift column that you can press to manually release the lock, but this is not much fun. The owners manual says that this is an electrical problem and I agree. Anybody have knowledge of the wiring of the system. Pehaps it is a bad switch, or solenoid?
Thank you very much,
Dave
ort5 is offline   Reply With Quote
Old 01-17-2002, 09:33 PM   #2
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
Can you still hear the 'click' when you step on the brake?
There is an actuator attached to the brake pedal and a solenoid on the shifter. It's easy for soda or something to get spilled into the shifter and gum up the solenoid - I've had to fix our GT once for that, and looks like a second time is coming up.
Anyway, in our case the solenoid would click but not move so the shifter was stuck in park.
[RICHR]
rrubel is offline   Reply With Quote
Old 01-17-2002, 09:46 PM   #3
rrubel
Member#: 4643
2008 Legacy Outback
Atlantic Blue Pearl
[RICHR]
Old 01-18-2002, 10:29 AM   #4
ort5
Member#: 3706
2000 VW Golf TDI
5mt Red
Nope, no click to be heard.
Can you give me some instructions on how to go about fixing this?
Thank you!
Dave
Old 01-18-2002, 01:10 PM   #5
subarurabbit
Member#: 4083
2006 OBS SE
regal blue
Get a flatbed to carry it to Exeter Subaru.
You can press that black button the in front of the shift assembly to manually bypass the interlock.
Roger
subarurabbit is offline   Reply With Quote
Old 01-19-2002, 08:23 AM   #6
2001LegactGT
Member#: 5089
2002 Audi A4
Denim Blue
Do your brake lights stilll work when u press the brake?
I had a problem like this but mine was the fuse blew and basically welded itself into the slot. With that fuse blown the shifter can't be moved. Could be worth looking into
2001LegactGT is offline   Reply With Quote
Shift lock problem Rebellion Transmission (AT/MT) & Driveline 3 12-07-2005 09:37 PM
Shift Interlock Al_Smokemcrack Transmission (AT/MT) & Driveline 2 08-03-2004 12:50 PM
Momo shift knob problem Chizzow Vancouver Impreza Club Forum -- VIC 2 07-21-2003 01:50 PM
Momo Race Air shift knob problem ilmaestro Interior & Exterior Modification 10 06-25-2003 09:45 PM
Shift linkage problem ?? DannyGT Transmission (AT/MT) & Driveline 4 06-10-2003 01:48 AM
Message Board Statistics All times are GMT -4. The time now is 05:21 PM.
