Welcome to the North American Subaru Impreza Owners Club Wednesday October 26, 2016
Old 10-16-2007, 12:33 PM   #1
Member#: 113698
Default my car developed a whining noise (it is RPM dependent)
Like I stated in the thread title, my car has developed a whining noise from under the hood. It can easily be heard with the windows up through the firewall and seems to be RPM dependent. It doesn't seem to match the RPMs but definitely accelerates with them. It seems that it most likely is coming from the top of the motor but I didn't start to rule anything out. I am feeling it is a belt or motor accessory. Anyone have this happen to them and what was it?
I hate the fact that my car has a turbo and sounds like an '04 Cobra!
dubya-R-ex is offline   Reply With Quote
Old 10-16-2007, 03:25 PM   #2
Member#: 5810
2001 S366 2.5RS
say goodbye to your timing belt pulleys
sidewayz is offline   Reply With Quote
Old 10-16-2007, 05:06 PM   #3
Member#: 422
1998 Legacy 2.5GT
Rio Red
It's pretty easy to pull the alternator and A/C belts. The car will run with them off. That will eliminate your A/C compressor, alternator and power steering pumps as possible culprits.
If that doesn't eliminate the noise, pop off the timing belt cover and see if the noise is coming from there (bad idlers / tensioner, perhaps).
mattwalters is offline   Reply With Quote
whining noise that is affected by RPM timmah Service & Maintenance 15 03-08-2009 08:17 PM
I just washed my car five minutes after driving it for a few hours; is this ok? Neo Maikeru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 12-26-2004 07:35 PM
ok what the &#*@ is wrong with my car turboed first time starting it GregBolby Normally Aspirated with bolt-on Forced Induction Powertrain 29 02-11-2004 09:28 AM
more n00bness OR my car makes a whining sound! mr_yellow Normally Aspirated Powertrain 12 09-15-2003 07:27 PM
My car developed a "sneeze" Daveish Normally Aspirated Powertrain 11 09-27-2001 03:52 PM
